* | Added Hitachi SH | Joel Sherrill | 1998-03-27 | 6 | -58/+60 |
* | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1998-03-27 | 9 | -89/+160 |
| | | | | and all directives start with rtems_. | ||||
* | Added POSIX 1003.1h and PowerPC supplement to internal manuals. | Joel Sherrill | 1998-03-27 | 1 | -2/+2 |
* | New file. Basically m68k version with Hitachi SH comments thrown in. | Joel Sherrill | 1998-03-26 | 1 | -0/+102 |
* | The script did not handle public distributions at all. | Joel Sherrill | 1998-03-26 | 1 | -1/+8 |
* | Added support for easily building different sets of the manuals | Joel Sherrill | 1998-03-26 | 1 | -7/+27 |
| | | | | for the public, support, partners, and internal use. | ||||
* | Better handling of local documentation tools and corrected invocation | Joel Sherrill | 1998-03-26 | 1 | -5/+14 |
| | | | | of texi2www to correct path information. | ||||
* | Updated for SH port and variable insertion of version. | Joel Sherrill | 1998-03-26 | 1 | -1/+2 |
* | Added build of tools to build procedure. | Joel Sherrill | 1998-03-26 | 1 | -5/+21 |
| | | | | Automatically insert version information into headers and footers.. | ||||
* | rtems.html renamed index.html since that is what httpd looks for | Joel Sherrill | 1998-03-26 | 1 | -0/+0 |
| | | | | | | automatically in a directory. rtems_full.html is an index.html for the full support documentation set. | ||||
* | Attempt at separating public, support, partners, and internal. | Joel Sherrill | 1998-03-26 | 1 | -3/+10 |
* | Added variables for dates and revision info | Joel Sherrill | 1998-03-26 | 13 | -43/+48 |
* | Enhanced. | Joel Sherrill | 1998-03-26 | 1 | -2/+5 |
* | Installed in partners subdirectory | Joel Sherrill | 1998-03-26 | 1 | -1/+2 |
* | removed @ifinfo around something needed for html structure | Joel Sherrill | 1998-03-26 | 1 | -2/+2 |
* | Do not copy headers, use make | Joel Sherrill | 1998-03-26 | 1 | -2/+1 |
* | More appropriate for public consumption | Joel Sherrill | 1998-03-26 | 1 | -1/+0 |
* | Made more appropriate for public consumption. | Joel Sherrill | 1998-03-26 | 1 | -19/+10 |
* | renamed to user's guide. | Joel Sherrill | 1998-03-26 | 6 | -30/+46 |
* | HAS_CPLUSPLUS should have been RTEMS_HAS_CPLUSPLUS. | Joel Sherrill | 1998-03-26 | 1 | -1/+1 |
* | Moved memcpy to newlib/libc/machine/m68k | Joel Sherrill | 1998-03-25 | 1 | -1/+1 |
* | m68k software interrupt stack support from Chris Johns and Eric Norum. | Joel Sherrill | 1998-03-25 | 6 | -40/+40 |
* | Added group and example around tree pictures in html. | Joel Sherrill | 1998-03-25 | 1 | -0/+16 |
* | Corrected argument passing. | Joel Sherrill | 1998-03-25 | 1 | -3/+2 |
* | Corrected definition of main and boot_card to be more ANSI compliant. | Joel Sherrill | 1998-03-25 | 1 | -3/+5 |
* | Corrected invocation of boot_card(). | Joel Sherrill | 1998-03-25 | 1 | -4/+6 |
* | Added _XOPEN_SOURCE definition to allow use of UNIX IPC. | Joel Sherrill | 1998-03-24 | 2 | -0/+2 |
* | changed version to 4.0.0-beta1 | Joel Sherrill | 1998-03-24 | 2 | -2/+2 |
* | Changed RTEMS cpu to hppa1.1. | Joel Sherrill | 1998-03-24 | 1 | -2/+1 |
* | Added rule to transform hppa1.1 to hppa1_1 since hppa1.1 is not a | Joel Sherrill | 1998-03-24 | 1 | -3/+12 |
| | | | | valid cpp symbol. | ||||
* | Real definition for the beginning of the data section per Eric Norum's | Joel Sherrill | 1998-03-24 | 3 | -6/+6 |
| | | | | suggestion. | ||||
* | Corrected register constraints per suggestion from Thomas Doerfler, IMD | Joel Sherrill | 1998-03-24 | 2 | -6/+6 |
| | | | | <td@imd.m.isar.de>. | ||||
* | More cpu model flags converted to using cpp predefines. | Joel Sherrill | 1998-03-24 | 1 | -2/+2 |
* | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1998-03-24 | 17 | -65/+62 |
| | | | | the CPU family name constants. | ||||
* | new file | Joel Sherrill | 1998-03-24 | 1 | -0/+54 |
* | Renamed hppa1_1 to hppa1.1 | Joel Sherrill | 1998-03-24 | 0 | -0/+0 |
* | Renamed hppa1_1 to hppa1.1 | Joel Sherrill | 1998-03-23 | 4 | -85/+73 |
* | renamed ppc to powerpc | Joel Sherrill | 1998-03-23 | 5 | -80/+72 |
* | Updated now that the phony crt0.c in newlib defines all odd symbols | Joel Sherrill | 1998-03-23 | 3 | -72/+4 |
| | | | | that gcc automatically generates references to. | ||||
* | *** empty log message *** | Joel Sherrill | 1998-03-23 | 1 | -101/+67 |
* | Converted to conditionally uses strerr code to better work with glibc2. | Joel Sherrill | 1998-03-23 | 2 | -8/+21 |
* | Patches from Eric Norum: | Joel Sherrill | 1998-03-23 | 9 | -174/+85 |
| | | | | | | | Here are some patches to the gen68360 BSP. The improvements include: Boot prom run-time selection of DRAM size (1/4/16 Mbytes) Full 32-bit ethernet address obtained from boot prom. Updated README. | ||||
* | Update from Eric Norum: | Joel Sherrill | 1998-03-23 | 1 | -12/+3 |
* | Added BSP specific start since it had become VERY complex to attempt | Joel Sherrill | 1998-03-21 | 3 | -1/+325 |
| | | | | to share the start code across i386 BSPs. | ||||
* | Corrected typo in copyright notice. | Joel Sherrill | 1998-03-21 | 2 | -2/+2 |
* | Switch to using a shared main() for all of the embedded BSPs | Joel Sherrill | 1998-03-21 | 70 | -463/+190 |
| | | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path. | ||||
* | Fixed spacing to be consistent with other CPUs. | Joel Sherrill | 1998-03-21 | 1 | -1/+1 |
* | Fixed RTEMS_PROG_CC_WORKS and RTEMS_PROG_CXX_WORKS so they could | Joel Sherrill | 1998-03-21 | 2 | -71/+133 |
| | | | | successfully work on powerpc-rtems and hppa1.1-rtems. | ||||
* | Added enough symbols to the conftest.c program to make sure it would | Joel Sherrill | 1998-03-21 | 2 | -3/+34 |
| | | | | successfully link on both the powerpc and hppa1.1. | ||||
* | POSIX not properly conditionalized | Joel Sherrill | 1998-03-21 | 2 | -2/+2 |
