* libchip/Makefile.am, libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am:
* mongoosev/Makefile.am, r46xx/Makefile.am, shared/Makefile.am,
tx39/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* m68040/Makefile.am, mcf5206/Makefile.am, mcf5272/Makefile.am,
shared/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* at91rm9200/Makefile.am, mc9328mxl/Makefile.am, shared/Makefile.am:
* mpc505/Makefile.am, mpc5xx/Makefile.am, mpc6xx/Makefile.am,
mpc8260/Makefile.am, mpc8xx/Makefile.am, ppc403/Makefile.am,
* httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am,
libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am,
libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am:
* Makefile.am: Fix typo.
* aclocal/prog-cxx.m4: Re-add am__fastdepCXX conditional.
* aclocal/rtems-flags.m4: Remove (Unused).
* aclocal/env-rtemsbsp.m4:
Remove CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V.
* aclocal/prog-cc.m4:
Don't invoke _RTEMS_FLAGS to set up RTEMS_CFLAGS.
* aclocal/prog-cxx.m4: Let CXXFLAGS default to CFLAGS.
Don't invoke _RTEMS_FLAGS to set up RTEMS_CXXFLAGS.
Remove am__fastdepCXX conditional.
* automake/compile.am: Remove CLEANDIRS (Unused).
Remove DEFS (Implicitly handled by automake).
* automake/compile.am: Remove CONFIG.CC (Unused).
Remove CPPFLAGS, CFLAGS, CXXFLAGS, ASFLAGS (Implicitly handled by
automake). Add CCAS. Use AM_*FLAGS = RTEMS_*FLAGS.
Remove LIB_VARIANT from LINK_*.
Cleanup comments.
* automake/compile.am: Remove AS, ASCOMPILE, make-rel (Unused).
Remove build-variants. Hard-code ARCH=o-optimize.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am:
Remove LIB_VARIANT.
* rtems++/Makefile.am: Remove LIB_VARIANT.
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am:
Remove $(LIB_VARIANT).
* configure.ac: Pass CFLAGS to testsuites configure.
* aclocal/prog-cxx.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CXXFLAGS. Setup CXXFLAGS from CFLAGS.
* Makefile.am: Remove build-variant support.
* autotools/automake-rtems.spec.in: automake-1.9.4.
* console/sci.c: Remove CVS Log.
* aclocal/rtems-flags.new: New (moved from ../aclocal).
* configure.ac: Pass CFLAGS to cpukit configure.
* aclocal/prog-ccas.m4: Remove $(GCCSPECS).
Comment out CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CPU_CFLAGS.
* aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CFLAGS.
* automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS. Add AM_CXXFLAGS.
Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE, ASFLAGS.
Cleanup comments.
* rtems/src/eventsurrender.c: Remove bogus type casts.
* sapi/Makefile.am: Eliminate *_FILES.
* aclocal/env-rtemscpu.m4: Remove CFLAGS_OPTIMIZE_V.
Remove CPU_CFLAGS.
RTEMS_CFLAGS.
Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE.
Cleanup comments.
* aclocal/env-rtemscpu.m4: Remove CFLAGS_DEBUG_V.
* aclocal/prog-cc.m4: Remove RTEMS_USE_GCC.
* automake/compile.am: Cleanup comments. Remove ASFLAGS.
* shared/Makefile.am: Fix typo.
* at91rm9200/clock/clock.c, at91rm9200/irq/irq.c, at91rm9200/pmc/pmc.c,
mc9328mxl/clock/clockdrv.c, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
shared/arm920/mmu.c: Remove warnings.
* ppc403/tty_drv/tty_drv.c: Remove warnings.
* ChangeLog, startup/bspstart.c, tod/todcfg.c: Remove warnings.
* startup/linkcmds: Remove warnings.
* console/config.c: Remove warnings.
* comm/gdb_glue.c, irq/idt.c: Remove warnings.
* console/keyboard.c, console/ps2_mouse.c, console/vt.c: Remove
warnings.
* console/sci.c: Remove warnings.
* console/leds.c: Remove warnings.
* console/console.c: Remove warnings.
* console/console-io.c, startup/init5272.c: Remove warnings.
