* spurious/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Various fixes to get it compiling again.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* bootloader/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* motorola/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* openpic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* pci/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* residual/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* nvram/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* universe/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* PCI_bus/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Remove SORDID_HACK. Eliminate *_O_FILES.
* canbus/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dlentry/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* scv64/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* sonic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* flashentry/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* setup.def: Updated gcc 3.2.1newlib1.10.0 RPM to revision 4
to include m68k crti.o/crtn.o multilib patch.
* include/Makefile.am: Fix broken preinstall-deps.
* configure.ac: RTEMS_CHECK_CUSTOM_BSP.
* milli/Makefile.am: Ditto.
* semaphore/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* milli/milli.S: Per PR329, use GNU binutils assembler directives.
* Makefile.am: Remove CPU_MODEL_SUBDIR.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* i960ca/Makefile.am: Eliminate *_O_FILES.
* i960ka/Makefile.am: Ditto.
* i960rp/Makefile.am: Ditto.
* cache/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* reg_win/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* syscall/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* erc32sonic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* gnatsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* clock/Makefile.am: Eliminate *_O_FILES.
* sci/Makefile.am: Ditto.
* score/Makefile.am: Ditto.
* configure.ac: Apply 2002-11-07 patch (Apparently dropped by CVS).
* delay/Makefile.am: Ditto.
* scitab/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* wrapup/Makefile.am: Fix path to libxdr and librpc (Another typo in
from the 2002-12-12 patch).
* wrapup/Makefile.am: Fix typo in yesterday's patch.
Makefile.am: Don't create $ARCH.
* wrapup/Makefile.am: Don't create $ARCH.
Use install-data-local to install librtemscpu.a
* bsp.mak: Use ac_cv_env instead of ac_cv for cached vars.
* automake/compile.am: Remove creating $(ARCH) in compilation rules.
* wrapup/Makefile.am: Use install-data-local to install librtemsbsp.a.
Let all-local: depend on $(LIB).
* Makefile.am: Merge-in kern/Makefile.am, net/Makefile.am,
netinet/Makefile.am, netinet/Makefile.am, nfs/Makefile.am,
rtems/Makefile.am.
* kern/Makefile.am: Remove.
* net/Makefile.am: Remove.
* netinet/Makefile.am: Remove.
* nfs/Makefile.am: Remove.
* rtems/Makefile.am: Remove.
* configure.ac: Ditto.
* Makefile.am: Don't create $ARCH as side-effect of compilation.
Re-order all-local.
* src/imfs/Makefile.am: Eliminate C_O_FILES.
* src/dosfs/Makefile.am: Ditto.
* Makefile.am: Eliminate C_O_FILES.
Eliminate SRCS.
* configure.ac: Require autoconf-2.57+automake-1.7.2.
* capture/Makefile.am: Eliminate C_O_FILES.
* cpuuse/Makefile.am: Ditto.
* devnull/Makefile.am: Ditto.
* dummy/Makefile.am: Ditto.
* dumpbuf/Makefile.am: Ditto.
* monitor/Makefile.am: Ditto.
* rtmonuse/Makefile.am: Ditto.
* serdbg/Makefile.am: Ditto.
* shell/Makefile.am: Ditto.
* stackchk/Makefile.am: Ditto.
* untar/Makefile.am: Ditto.
* mw-fb/Makefile.am: Eliminate C_O_FILES.
Eliminate SRCS.
* Makefile.am: Apply install-data-local to install *.rels.
