* | Added prototype for _Thread_Reset() and numerous comments. | Joel Sherrill | 1999-11-16 | 2 | -8/+56 | |
* | Only check for System V IPC if multiprocessing is enabled. The unix | Joel Sherrill | 1999-11-16 | 5 | -3/+26 | |
| | | | | | | | | port only uses System V IPC for shared memory and semaphores to communicate between nodes in a multiprocessor configuration. If you disable multiprocessing, then this code should be unused. Thus systems like Cygwin which are POSIX but do not support System V IPC should not work. | |||||
* | Fixed so can be included multiple times in the executive source. | Joel Sherrill | 1999-11-16 | 2 | -0/+18 | |
* | Works now. | Joel Sherrill | 1999-11-16 | 4 | -76/+48 | |
| | | | | | Removed times() since the version in the C Library support code is fine. | |||||
* | Return a reasonable error other than ENOSYS. | Joel Sherrill | 1999-11-16 | 2 | -2/+2 | |
* | Added call to _Watchdog_Remove to remove the sporadic timer. It was | Joel Sherrill | 1999-11-16 | 2 | -0/+2 | |
| | | | | being reinserted onto the ticks chain. | |||||
* | Moved utsname from "build for now" (unimplemented files) to the main | Joel Sherrill | 1999-11-16 | 1 | -4/+5 | |
| | | | | list of C_PIECES since it is now implemented. | |||||
* | Comment fixed when adding prototype for | Joel Sherrill | 1999-11-16 | 2 | -4/+22 | |
| | | | | _ITRON_Message_buffer_Translate_core_message_buffer_return_code. | |||||
* | New file. | Joel Sherrill | 1999-11-16 | 2 | -0/+132 | |
* | Patch rtems-rc-19991105-1.diff.gz from Ralf Corsepius | Joel Sherrill | 1999-11-16 | 28 | -110/+129 | |
| | | | | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> which does the following: This is the configuration cleanup patch: Main changes: * TARGET_ARCH removed * target.cfg.in moved to c/make/target.cfg.in (Only configured once for all BSPs of a target) * BARE_XXX variables appended to bsp.cfg.in * autogen renamed to bootstrap * removed stray variables from make/custom/*.cfg To apply: cd <source-tree> rm c/src/make/target.cfg.in cp autogen bootstrap mkdir c/make cp make/target.cfg.in c/make/target.cfg.in rm make/target.cfg.in rm autogen patch -p1 < rtems-rc-19991105-1.diff | |||||
* | Modified file to match seen output. | Jennifer Averett | 1999-11-16 | 2 | -184/+322 | |
* | Modified output file to match seen output. Added comment to all ino | Jennifer Averett | 1999-11-16 | 2 | -612/+564 | |
| | | | | values that they may change slightly on a processor basis. | |||||
* | Removed compiler warning. | Jennifer Averett | 1999-11-16 | 2 | -2/+2 | |
* | Changed asserts to tmmacros. | Jennifer Averett | 1999-11-16 | 4 | -16/+14 | |
* | Updated scn file to match new output. Left out unemplemented | Jennifer Averett | 1999-11-16 | 2 | -34/+24 | |
| | | | | parts as a reminder to fix when these routines became implemented. | |||||
* | + Changed ID to 1. ( Compilation error introduced by modifications. ) | Jennifer Averett | 1999-11-16 | 2 | -2/+2 | |
* | Modified scan file to match. | Jennifer Averett | 1999-11-16 | 2 | -4/+4 | |
* | New file. | Joel Sherrill | 1999-11-16 | 3 | -0/+339 | |
* | Added. | Joel Sherrill | 1999-11-16 | 16 | -3/+619 | |
* | Source and destination arguments to strncpy were swapped. This mistake | Joel Sherrill | 1999-11-16 | 3 | -3/+3 | |
| | | | | was made in the conversion of bcopy() to strncpy(). | |||||
* | Added itron tests. | Joel Sherrill | 1999-11-16 | 2 | -2/+2 | |
* | Changed to call tmmacros instead of assert. | Jennifer Averett | 1999-11-16 | 2 | -282/+306 | |
* | Patch rtems-rc-19991105-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-11-16 | 1 | -1/+6 | |
| | | | | | | | This is the gdb.spec.in fix patch: * install infos gzip-ed * add gdb to group rtems | |||||
* | Moved start code from lib/start to libbsp. | Joel Sherrill | 1999-11-16 | 14 | -7/+462 | |
* | Moved start code from lib/start to libbsp. | Joel Sherrill | 1999-11-16 | 5 | -274/+0 | |
* | Moved start code from lib/start to libbsp. | Joel Sherrill | 1999-11-16 | 14 | -829/+22 | |
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-16 | 7 | -1953/+0 | |
| | | | | Working Group. Included are tests. | |||||
* | Minor changes since new Makefile. | Joel Sherrill | 1999-11-16 | 1 | -4/+5 | |
* | Added start subdirectory. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-16 | 18 | -2098/+0 | |
* | Removed nanosleep() since it is now in its own file. | Joel Sherrill | 1999-11-15 | 2 | -42/+0 | |
* | Returned third parameter for a NULL name to the objects open call. | Jennifer Averett | 1999-11-15 | 2 | -2/+2 | |
* | + Fixed files to consistantly use a case of the location after calls | Jennifer Averett | 1999-11-15 | 22 | -162/+194 | |
| | | | | | | to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values. | |||||
* | + Modified to use new Thread_Reset routine instead of the restart method. | Jennifer Averett | 1999-11-15 | 2 | -2/+2 | |
* | Fixed verificaiton checks to call correct macro if dispatch is disabled. | Jennifer Averett | 1999-11-15 | 2 | -14/+24 | |
* | + Added check that a task could be sent to a dormant state | Jennifer Averett | 1999-11-15 | 8 | -24/+188 | |
| | | | | | | | | then sta_tsk used to restart the task to its initial state. + Added calls to ref_tsk to yellow paths for suspended and ready but not running tasks. + Fixed output file to correctly state test name + Added priority of preempt to the header file. Allows ref_tsk verification. | |||||
* | + Changed preempt routine into two dummy tasks one that is in dormant | Jennifer Averett | 1999-11-15 | 7 | -34/+164 | |
| | | | | | | | | state and one that is in non-dormant state. + Increased the priority of the Init task to force the dummy tasks to run first. + Added calls to ref_tsk to verify the state of the dummy tasks and test ref_tsk. | |||||
* | Added paragraph describing SUSP. | Joel Sherrill | 1999-11-15 | 1 | -0/+9 | |
* | Split ITRON Message Buffer Manager into multiple files. | Joel Sherrill | 1999-11-15 | 23 | -709/+1045 | |
* | Split ITRON semaphore manager into multiple files. | Joel Sherrill | 1999-11-15 | 17 | -569/+754 | |
* | + Modified calls to use TSK_SLF for calls to self. | Joel Sherrill | 1999-11-12 | 2 | -50/+48 | |
| | | | | + Modified calls to use the task id macro for calls to the PREEMPT task. | |||||
* | + Added comments on paths tested. | Joel Sherrill | 1999-11-12 | 4 | -2/+28 | |
* | + Added check for priority over 256. | Joel Sherrill | 1999-11-12 | 2 | -2/+8 | |
| | | | | + Modified output to correctly state the error. | |||||
* | Added comments for path's tested. | Joel Sherrill | 1999-11-12 | 2 | -0/+6 | |
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 8 | -74/+54 | |
| | | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | |||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 2 | -22/+22 | |
| | | | | + Removed error path that should never happen. | |||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 4 | -34/+16 | |
* | + Moved error checks to before the disable dispatch where possible. | Joel Sherrill | 1999-11-12 | 2 | -10/+10 | |
* | Added comment about the E_CTX error condition (Implementation dependent). | Joel Sherrill | 1999-11-12 | 2 | -0/+14 | |
* | + Moved error checks to before the dispatch disable where possible. | Joel Sherrill | 1999-11-12 | 2 | -26/+24 | |
