* | Use rtems_get_version_string() | Sebastian Huber | 2020-05-06 | 5 | -7/+7 |
| | | | | Update #3970. | ||||
* | libtest/dl09: Test trampolines only when supported | Chris Johns | 2020-05-06 | 1 | -4/+20 |
* | testsuite/dl06: Add a local define to control tracing | Chris Johns | 2020-05-05 | 1 | -0/+2 |
| | | | | Closes #3969 | ||||
* | libdl/rap: Correctly check the return enum from rela calls | Chris Johns | 2020-05-05 | 1 | -4/+13 |
| | | | | | | | | - The change from bool to an enum did not trip a compiler warning and only the rel path was changed. The rela path was missed so archs like SPARC failed. Updates #3969 | ||||
* | libdl/obj-comp: Add trace prints when decompressing | Chris Johns | 2020-05-05 | 2 | -0/+33 |
* | libdl/obj-cache: Fail if the read offset is past the file length | Chris Johns | 2020-05-05 | 1 | -4/+5 |
| | | | | | | - The check was for greater than and not equal or greater Updates #3969 | ||||
* | libdl/obj: Fix RAP format call table. | Chris Johns | 2020-05-05 | 1 | -1/+0 |
* | libdl/sparc: Print trace message of reloc failture path | Chris Johns | 2020-05-05 | 1 | -1/+4 |
* | libdl: Fix comment. | Chris Johns | 2020-05-05 | 1 | -1/+1 |
* | rtems-bsps: Add markdown support | Chris Johns | 2020-05-01 | 1 | -49/+320 |
| | | | | - Convert to python for better performance | ||||
* | libtests/heapwalk: Fix for RTEMS_DEBUG | Sebastian Huber | 2020-04-29 | 1 | -0/+3 |
| | | | | Update #2962. | ||||
* | doxygen: Switch @brief and @ingroup | Sebastian Huber | 2020-04-28 | 393 | -393/+786 |
| | | | | This order change fixes the Latex documentation build via Doxygen. | ||||
* | libdl/mips: Fix MIPS16hi/lo relocation support. | Chris Johns | 2020-04-28 | 1 | -24/+45 |
| | | | | | | | | This patch is an updated version from: https://lists.rtems.org/pipermail/users/2016-January/029740.html Closes #3693 | ||||
* | README: Fix the rtems.git line | Chris Johns | 2020-04-27 | 1 | -1/+1 |
| | | | | Updates #3231 | ||||
* | bsps/arm: Fix uninitialized value in generic timer | Christian Mauderer | 2020-04-20 | 1 | -4/+10 |
| | | | | | | | | _CPU_Counter_frequency() can be called by the rtems_counter initialization before arm_gt_clock_initialize() initializes the value used in _CPU_Counter_frequency(). Closes #3961. | ||||
* | sapi: Add param check to rtems_extension_create() | Sebastian Huber | 2020-04-17 | 2 | -4/+15 |
| | | | | | | Check that the extensions table is not NULL. Change format. Update #3953. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1324 | -1520/+1520 |
* | libnetworking: Remove config.h include in header | Sebastian Huber | 2020-04-16 | 1 | -4/+0 |
* | bsp/imx: Add an extra ecspi clock. | Christian Mauderer | 2020-04-15 | 4 | -1/+12 |
| | | | | | | Some imx chips or boards don't use the same frequency for ECSPI and IPG. Update #3869 | ||||
* | libmisc/shell: Fix the handling of joel scripts in telnet | Chris Johns | 2020-04-15 | 3 | -105/+394 |
| | | | | | | | | | | | | - Fix the passing of std[in/out] to child threads - Fix deleting of managed memory in the key destructor - Only set the key in the main loop thread - Only allocate a shell env outside of the main loop - Fix memory leak if the task start fails - Remove error level from shell env, it cannot be returned this way. Add exit_code but the API is broken so it cannot be returned. Closes #3859 | ||||
* | config: Fix typo | Sebastian Huber | 2020-04-14 | 1 | -1/+1 |
| | | | | Update #3875. | ||||
* | score: Check time of day in _TOD_Set() | Sebastian Huber | 2020-04-14 | 3 | -4/+45 |
| | | | | Close #3949. | ||||
* | score: Return status in _TOD_Set() | Sebastian Huber | 2020-04-14 | 6 | -51/+48 |
| | | | | Update #3949. | ||||
* | bsps/riscv: Fix multiple definition | Sebastian Huber | 2020-04-10 | 1 | -2/+0 |
* | bsp/raspberrypi: Fix build warnings. | G S Niteesh Babu | 2020-04-10 | 2 | -1/+5 |
| | | | | | | 1) _Memory_Initialize makes pointer from integer without a cast. 2) printf format error, expects %u but %lu provided. | ||||
* | score: Delete RTEMS_DECLARE_GLOBAL_SYMBOL() | Sebastian Huber | 2020-04-08 | 2 | -27/+0 |
| | | | | | | Delete unused RTEMS_DECLARE_GLOBAL_SYMBOL(). Update #3799. | ||||
* | config: Fix _ISR_Stack_area_end | Sebastian Huber | 2020-04-08 | 1 | -6/+9 |
| | | | | | | | | | | | | | | In the previous implementation, the _ISR_Stack_area_begin and _ISR_Stack_area_end symbols were in different sections. If they do not have the same alignment, then the following linker directive could separate them: *(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*))) Do not use different sections and instead define _ISR_Stack_area_end directly. Update #3799. | ||||
* | score: Add and use RTEMS_SYMBOL_NAME() | Sebastian Huber | 2020-04-08 | 1 | -10/+27 |
* | Tests for inttype.h methods | Eshan dhawan | 2020-04-07 | 2 | -2/+32 |
* | lpc23xx_tli800-testsuite.tcfg: Add psxaoi03 and psxsignal07 | Joel Sherrill | 2020-04-07 | 1 | -0/+2 |
| | | | | Updates #3938. | ||||
* | mcf52235-testsuite.tcfg: Add sp16 | Joel Sherrill | 2020-04-07 | 1 | -0/+1 |
* | lpc1768_mbed-testsuite.tcfg: Add psxaoi03 and psxsignal07 | Joel Sherrill | 2020-04-07 | 1 | -0/+2 |
* | lpc2362-testsuite.tcfg: Add psxaoi03 and psxsignal07 | Joel Sherrill | 2020-04-07 | 1 | -0/+2 |
* | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add psxsignal07 | Joel Sherrill | 2020-04-07 | 1 | -0/+1 |
* | lm4f120-testsuite.tcfg: Add psxsignal07 | Joel Sherrill | 2020-04-07 | 1 | -0/+1 |
* | tests: Exclude record02 for some BSPs | Sebastian Huber | 2020-04-06 | 13 | -0/+13 |
| | | | | Update #3938. | ||||
* | tests: Small memory exclude for record02 | Sebastian Huber | 2020-04-06 | 1 | -0/+1 |
* | sparc64: update linkcmds with missing sections for TLS | Gedare Bloom | 2020-04-06 | 1 | -52/+22 |
| | | | | Closes #3936. | ||||
* | Revert "score: Fix _ISR_Stack_area_end" | Sebastian Huber | 2020-04-05 | 3 | -37/+5 |
| | | | | | This reverts commit 8e80876bdd54e36fb668eee655eec1dd588daf13 which broke several architectures. | ||||
* | bsp/raspberry: Add a bsp_fdt_map_intr(). | Christian Mauderer | 2020-04-04 | 2 | -0/+27 |
| | | | | Fixes #3903 | ||||
* | cpukit/rfs: fix typo in header guard | Gedare Bloom | 2020-04-03 | 1 | -1/+1 |
* | score: Fix _ISR_Stack_area_end | Sebastian Huber | 2020-04-03 | 3 | -5/+37 |
| | | | | | | | | | | The _ISR_Stack_area_begin and _ISR_Stack_area_end symbols are in different sections. They must have the same alignment, otherwise the following linker directive could separate them: *(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*))) Update #3799. | ||||
* | bsp/shared/clock: Reset Clock_driver_isrs to correct value | Jan Sommer | 2020-04-03 | 1 | -1/+1 |
| | | | | | | | CLOCK_DRIVER_ISRS_PER_TICK is the configuration define, CLOCK_DRIVER_ISRS_PER_TICK_VALUE is the actual value of ISRS per clock tick, therefore use this one to reset the Clock_driver_isrs after each tick. | ||||
* | arm: ARMv7-M statically initialized vector table | Sebastian Huber | 2020-04-03 | 5 | -52/+93 |
| | | | | | | | Statically initialize the ARMv7-M vector table to allow a placement in ROM with read-only MPU settings. Change licence to BSD-2-Clause in some files. | ||||
* | config: Remove filesystem entry config options | Sebastian Huber | 2020-04-03 | 1 | -56/+14 |
| | | | | | | | | | | | | | | | | | | | | Remove the following undocumented configuration options: * CONFIGURE_FILESYSTEM_ENTRY_DOSFS * CONFIGURE_FILESYSTEM_ENTRY_FTPFS * CONFIGURE_FILESYSTEM_ENTRY_IMFS * CONFIGURE_FILESYSTEM_ENTRY_JFFS2 * CONFIGURE_FILESYSTEM_ENTRY_NFS * CONFIGURE_FILESYSTEM_ENTRY_RFS * CONFIGURE_FILESYSTEM_ENTRY_TFTPFS Update #3836. | ||||
* | libio: Remove RTEMS_FILESYSTEM_TYPE_MINIIMFS | Sebastian Huber | 2020-04-02 | 1 | -3/+0 |
| | | | | | This type is unused. Do not mention non-existing CONFIGURE_FILESYSTEM_MINIIMFS. | ||||
* | bsp/qoriq: Fix off by one error in clock init | Sebastian Huber | 2020-04-02 | 1 | -1/+1 |
| | | | | Close #3921. | ||||
* | rtems: Fix Doxygen comment | Sebastian Huber | 2020-04-02 | 1 | -2/+0 |
* | testsuites: Remove CONFIGURE_MALLOC_STATISTICS | Sebastian Huber | 2020-03-31 | 5 | -12/+0 |
| | | | | | | This configuration option is obsolete since 2014. Update #1367. | ||||
* | config: Remove CONFIGURE_FILESYSTEM_DEVFS | Sebastian Huber | 2020-03-31 | 2 | -12/+0 |
| | | | | | | | | This filesystem no longer exists. Remove unused RTEMS_FILESYSTEM_TYPE_DEVFS. Update #3894. |
