* bsp_specs: remove %lib.
* new-exceptions/cpu_asm.S: the book says a context
synchronizing instruction (isync) is necessary after flipping
certain bits (e.g, MSR_FP) in msr -- since this could happen as
part of a context switch I added 'isync'.
* configure.ac: New header guard for cpuopts.h.
* gccnewlib/gccnewlib.add: Rename src.rpm back to
gcc-newlib.src.rpm. Misc fixups.
* gccnewlib/target-c++.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-gfortran.add, gccnewlib/target-gnat.add
gccnewlib/target-objc.add: Add License.
* gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add,
gccnewlib/base-gnat.add: Add License.
* configure.ac: Re-add mptests*Makefile.am.
* mptests/Makefile.am: Re-add mp?? tests.
* mptests/mp02/Makefile.am, mptests/mp02/node1/Makefile.am,
mptests/mp02/node2/Makefile.am, mptests/mp03/Makefile.am,
mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am,
mptests/mp04/Makefile.am, mptests/mp04/node1/Makefile.am,
mptests/mp04/node2/Makefile.am, mptests/mp05/Makefile.am,
mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am,
mptests/mp06/Makefile.am, mptests/mp06/node1/Makefile.am,
mptests/mp06/node2/Makefile.am, mptests/mp07/Makefile.am,
mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am,
mptests/mp08/Makefile.am, mptests/mp08/node1/Makefile.am,
mptests/mp08/node2/Makefile.am, mptests/mp09/Makefile.am,
mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am,
mptests/mp10/Makefile.am, mptests/mp10/node1/Makefile.am,
mptests/mp10/node2/Makefile.am, mptests/mp11/Makefile.am,
mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am,
mptests/mp12/Makefile.am, mptests/mp12/node1/Makefile.am,
mptests/mp12/node2/Makefile.am, mptests/mp13/Makefile.am,
mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am,
mptests/mp14/Makefile.am, mptests/mp14/node1/Makefile.am,
mptests/mp14/node2/Makefile.am: New.
* samples/base_mp/node1/Makefile.am,
samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am,
samples/hello/Makefile.am, samples/ticker/Makefile.am,
sptests/sp01/Makefile.am, sptests/sp02/Makefile.am,
sptests/sp03/Makefile.am, sptests/sp04/Makefile.am,
sptests/sp05/Makefile.am, sptests/sp06/Makefile.am,
sptests/sp07/Makefile.am, sptests/sp08/Makefile.am,
sptests/sp09/Makefile.am, sptests/sp11/Makefile.am,
sptests/sp12/Makefile.am, sptests/sp13/Makefile.am,
sptests/sp14/Makefile.am, sptests/sp15/Makefile.am,
sptests/sp16/Makefile.am, sptests/sp17/Makefile.am,
sptests/sp19/Makefile.am, sptests/sp20/Makefile.am,
sptests/sp21/Makefile.am, sptests/sp22/Makefile.am,
sptests/sp23/Makefile.am, sptests/sp24/Makefile.am,
sptests/sp25/Makefile.am: Add scndir. Install *.scn to scndir.
* samples/base_mp/Makefile.am: Remove references to *.scn.
* samples/base_mp/node1/base_mp.scn: Remove.
* samples/base_mp/node1/base_mp-node1.scn: New.
* samples/base_mp/node1/Makefile.am: Eliminate NODE.
Reflect having renamed base_mp.scn.
* samples/base_mp/node2/base_mp.scn: Remove.
* samples/base_mp/node2/base_mp-node2.scn: New.
* samples/base_mp/node2/Makefile.am: Eliminate NODE.
* aclocal/prog-cc.m4: Remove RTEMS_USE_GCC.
Add RTEMS_RELLDFLAGS.
* automake/compile.am: Remove RTEMS_USE_GCC.
Remove RTEMS_RELLDFLAGS.
* configure.ac: Pass --enable-rtems-root to ada-tests/configure.
* configure.ac: Reflect changes to testsuites/automake,
testsuites/aclocal.
* rtems/score/cpu.h: Eliminate use of unsigned32.
* rtems.adb, rtems.ads: Remove initialization directives as
rtems_initialize_executive is obsolete and the other initialization
services should not be called from Ada anyway.
* libnetworking/rtems/rtems_mii_ioctl.h: Reflect mii.h and
if_media.h having moved.
* libchip/network/if_media.h, libchip/network/mii.h:
Remove (Moved to cpukit).
* libchip/Makefile.am: Reflect having moved libchip/network/mii.h
and libchip/network/if_media.h.
* libchip/network/elnk.c, libchip/network/if_dc.c: Reflect mii.h and
* libnetworking/net/if_media.h, libnetworking/dev/mii/mii.h:
New (Moved from c/src/libchip).
