* | 2011-03-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-29 | 2 | -41/+45 |
| | | | | * Makefile.am: Use '|' as sed-delimiter. | ||||
* | 2011-03-29 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-03-28 | 2 | -12/+25 |
| | | | | * shared/lpc/network/lpc-ethernet.c: Support multicast. | ||||
* | 2011-03-29 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-03-28 | 15 | -103/+223 |
| | | | | | | | | | | | | | | * configure.ac, include/bspopts.h.in: New BSP option LPC32XX_SCRATCH_AREA_SIZE. Disable BSP option LPC32XX_DISABLE_READ_ONLY_PROTECTION for all BSPs. * include/boot.h: Removed application specific defines. * include/nand-mlc.h, misc/nand-mlc.c: Changed configuration layout. * include/mmu.h, misc/mmu.c: Documentation. Bugfix. * include/bsp.h, startup/bspstarthooks.c, misc/restart.c, startup/linkcmds.lpc32xx_mzx, startup/linkcmds.lpc32xx_mzx_stage_1, startup/linkcmds.lpc32xx_mzx_stage_2, startup/linkcmds.lpc32xx_phycore: Support for scratch area. Moved code into macros for reusability. | ||||
* | 2011-03-29 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-03-28 | 3 | -131/+151 |
| | | | | | | | * shared/start/start.S: Default exception handler will result in bsp_reset(). * shared/startup/linkcmds.base: Move unsupported sections into read-only section. Changed barrier sections. | ||||
* | Regenerate. | Ralf Corsepius | 2011-03-26 | 14 | -191/+135 |
* | Reflect gcc-4.6.0 is out. | Ralf Corsepius | 2011-03-26 | 14 | -98/+42 |
| | | | | Abandon newlib-1.18.0 | ||||
* | Reflect gcc-4.6.0 is out. | Ralf Corsepius | 2011-03-26 | 12 | -24/+24 |
| | | | | Bump GCC_RPMREL. | ||||
* | New. | Ralf Corsepius | 2011-03-26 | 1 | -0/+433 |
* | newlib-1.19.0-rtems4.11-20110323.diff. | Ralf Corsepius | 2011-03-26 | 1 | -1/+1 |
* | gcc-core-4.6.0-RC-20110321-rtems4.11-20110323.diff | Ralf Corsepius | 2011-03-25 | 12 | -13/+13 |
* | Add missing dirent.h patch. | Ralf Corsepius | 2011-03-24 | 1 | -127/+143 |
* | New. | Ralf Corsepius | 2011-03-24 | 1 | -0/+3688 |
* | Regenerate. | Ralf Corsepius | 2011-03-24 | 14 | -112/+112 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-03-24 | 14 | -14/+14 |
* | newlib-1.19.0-rtems4.11-20110323.diff. | Ralf Corsepius | 2011-03-24 | 14 | -14/+14 |
* | Regenerate. | Ralf Corsepius | 2011-03-24 | 1 | -13/+0 |
* | 2011-03-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-24 | 4 | -786/+6 |
| | | | | | | * include/rtems/bsd/sys/queue.h, include/rtems/bsd/sys/cdefs.h: Remove. * Makefile.am: Reflect changes above. | ||||
* | 2011-03-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-24 | 1 | -0/+2 |
| | | | | | * libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_dd.c: Add local version of __unused macro. | ||||
* | Add local version of __unused macro. | Ralf Corsepius | 2011-03-24 | 2 | -1/+8 |
| | | | | | * libcsupport/include/sys/ioccom.h: Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h). | ||||
* | Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h). | Ralf Corsepius | 2011-03-24 | 41 | -40/+44 |
* | 2011-03-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-24 | 1 | -0/+8 |
| | | | | | | | | | | | * librpc/include/rpc/auth.h, librpc/include/rpc/auth_unix.h, librpc/include/rpc/clnt.h, librpc/include/rpc/clnt_soc.h, librpc/include/rpc/pmap_clnt.h, librpc/include/rpc/pmap_prot.h, librpc/include/rpc/pmap_rmt.h, librpc/include/rpc/rpc_com.h, librpc/include/rpc/rpcent.h, librpc/include/rpc/svc.h, librpc/include/rpc/svc_soc.h, librpc/include/rpc/xdr.h, librpc/include/rpcsvc/ypclnt.h: Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h). | ||||
* | 2011-03-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-24 | 1 | -0/+16 |
| | | | | | | | | | | | | | | | | | | | * libnetworking/ifaddrs.h, libnetworking/netdb.h, libnetworking/resolv.h, libnetworking/arpa/inet.h, libnetworking/arpa/nameser.h, libnetworking/libc/gethostbydns.c, libnetworking/libc/getifaddrs.c, libnetworking/libc/if_indextoname.c, libnetworking/libc/if_nameindex.c, libnetworking/libc/res_stubs.c, libnetworking/machine/in_cksum.h, libnetworking/net/ethernet.h, libnetworking/net/if.h, libnetworking/net/if_dl.h, libnetworking/netinet/ip.h, libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_debug.c, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/libkern.h, libnetworking/sys/mount.h, libnetworking/sys/poll.h, libnetworking/sys/socket.h, libnetworking/sys/sysctl.h, libnetworking/sys/syslog.h, libnetworking/sys/systm.h, libnetworking/sys/uio.h, libnetworking/sys/un.h: Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h). | ||||
* | 2011-03-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-24 | 2 | -0/+21 |
| | | | | | * libnetworking/sys/linker_set.h: Add local versions of __used and __CONCAT macros. | ||||
* | Abandon | Ralf Corsepius | 2011-03-23 | 24 | -2618/+0 |
* | Abandon netbsd5.0.2. | Ralf Corsepius | 2011-03-23 | 2 | -5/+0 |
* | gcc-core-4.6.0-RC-20110321-rtems4.11-20110323.diff | Ralf Corsepius | 2011-03-23 | 2 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2011-03-23 | 2 | -16/+16 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-03-23 | 2 | -2/+2 |
* | 2011-03-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-23 | 2 | -9/+7 |
| | | | | | * make/custom/usiii.cfg (CFLAGS_OPTIMIZE_V): Replace -gstabs with -g. | ||||
* | 2011-03-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-23 | 2 | -8/+8 |
| | | | | | * make/custom/niagara.cfg (CFLAGS_OPTIMIZE_V): Replace -gstabs with -g. | ||||
* | 2011-03-23 Gedare Bloom <giddyup44@yahoo.com> | Ralf Corsepius | 2011-03-23 | 2 | -1/+6 |
| | | | | | PR 1769/bsps * make/custom/niagara.cfg (CFLAGS_OPTIMIZE_V): Add -O2 | ||||
| | | | | | PR 1769/bsps * make/custom/usiii.cfg (CFLAGS_OPTIMIZE_V): Add -O2 | ||||
* | 2011-03-22 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-22 | 2 | -6/+11 |
| | | | | | PR 1772/bsps * console/sci.c: Use same default baud rate as monitor. | ||||
* | Regenerate. | Ralf Corsepius | 2011-03-22 | 14 | -120/+279 |
* | Update to gcc-4.6.0-RC-20110321. | Ralf Corsepius | 2011-03-22 | 12 | -48/+48 |
* | Preps for gcc-4.6.0. | Ralf Corsepius | 2011-03-22 | 14 | -0/+98 |
* | Preps for gcc-4.6.0. | Ralf Corsepius | 2011-03-22 | 2 | -0/+5 |
* | 2011-03-21 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-21 | 6 | -240/+6 |
| | | | | | | * Makefile.am: Remove stub version. * shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: Removed. | ||||
* | Abandon. | Ralf Corsepius | 2011-03-21 | 24 | -2815/+0 |
* | Abandon freebsd8.1 | Ralf Corsepius | 2011-03-21 | 2 | -5/+0 |
* | Regenerate. | Ralf Corsepius | 2011-03-21 | 10 | -40/+142 |
* | GCC_VERS = 4.5.2. | Ralf Corsepius | 2011-03-21 | 10 | -20/+20 |
| | | | | GCC_RPMREL = 0.20110321.1. | ||||
* | Preps for gcc-4.5.2. | Ralf Corsepius | 2011-03-21 | 10 | -16/+78 |
* | 2011-03-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-03-21 | 2 | -1/+6 |
| | | | | | PR 1770/bsps * shared/console/conscfg.c: Rely on default device file registration. | ||||
* | 2011-03-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-03-21 | 2 | -3/+9 |
| | | | | * console.c: Make device file optional. | ||||
* | New. | Ralf Corsepius | 2011-03-20 | 24 | -0/+2596 |
* | Add netbsd5.1. | Ralf Corsepius | 2011-03-20 | 2 | -0/+5 |
* | Eliminate RPM_OS. | Ralf Corsepius | 2011-03-20 | 1 | -17/+0 |
* | Add config.status, config.sub, config.log. | Ralf Corsepius | 2011-03-20 | 1 | -1/+3 |
