* user/conf.t: Add SMP Configuration parameters.
* user/conf.t: Slight rework to deemphasize not using confdefs.h
PR1797/bsps
* shared/bootcard.c: Fixed a typo (in code, not comment) which
I introduced with the last change.
* score/Makefile.am: Reformat.
* Makefile.am: Reformat.
* configure.ac: Require time.h to provide CLOCK_PROCESS_CPUTIME_ID,
CLOCK_THREAD_CPUTIME_ID.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* psxclock/init.c (Init):
Use CLOCK_PROCESS_CPUTIME_ID and CLOCK_THREAD_CPUTIME_ID.
* psxclock/psxclock.scn: Regenerate.
* sapi/Makefile.am: Reformat.
* libnetworking/sys/signalvar.h: Cosmetics from FreeBSD.
Comment out psignal().
tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c,
tools/build/cklength.c, tools/build/config.h.in,
tools/build/configure.ac, tools/build/cvsignore-add.sh,
tools/build/doxy-filter, tools/build/eolstrip.c,
tools/build/install-if-change.in, tools/build/multigen,
tools/build/packhex.c, tools/build/rtems-bin2c.c,
tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore,
tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac,
tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog,
tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac,
tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore,
tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am,
tools/cpu/nios2/README, tools/cpu/nios2/bridges.c,
tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c,
tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac,
tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h,
tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h,
tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h,
tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c,
tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c,
tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf,
tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING,
tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO,
tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h,
tools/cpu/sh/shgen.c: New files.
* tools/build/.cvsignore, tools/build/ChangeLog,
tools/build/cklength.c, tools/build/configure.ac,
tools/build/cvsignore-add.sh, tools/build/doxy-filter,
tools/build/eolstrip.c, tools/build/install-if-change.in,
tools/build/multigen, tools/build/packhex.c,
tools/build/rtems-bin2c.c, tools/build/search-id.sh,
tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog,
tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore,
tools/schedsim/ChangeLog, tools/schedsim/Makefile.am,
tools/schedsim/README, tools/schedsim/configure.ac,
tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog,
tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c,
tools/schedsim/rtems/rtems_init.c,
tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c,
tools/schedsim/rtems/sched_cpu/cpu.c,
tools/schedsim/rtems/sched_cpu/cpu_asm.c,
tools/schedsim/rtems/sched_cpu/rtems/asm.h,
tools/schedsim/rtems/sched_cpu/rtems/stringto.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h,
tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h,
tools/schedsim/rtems/sched_cpu/rtems/score/types.h,
tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog,
tools/schedsim/shell/Makefile.am,
tools/schedsim/shell/schedsim_priority/.cvsignore,
tools/schedsim/shell/schedsim_priority/Makefile.am,
tools/schedsim/shell/schedsim_priority/config.c,
tools/schedsim/shell/schedsim_priority/printheir_executing.c,
tools/schedsim/shell/schedsim_priority/schedsim.cc,
tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c,
tools/schedsim/shell/scripts/script01,
tools/schedsim/shell/scripts/script02,
tools/schedsim/shell/scripts/script03,
tools/schedsim/shell/scripts/script04,
tools/schedsim/shell/scripts/script05,
tools/schedsim/shell/scripts/script06,
tools/schedsim/shell/shared/.cvsignore,
tools/schedsim/shell/shared/Makefile.am,
tools/schedsim/shell/shared/commands.c,
tools/schedsim/shell/shared/getopt.c,
tools/schedsim/shell/shared/lookup_semaphore.c,
tools/schedsim/shell/shared/lookup_task.c,
tools/schedsim/shell/shared/main_clocktick.c,
tools/schedsim/shell/shared/main_echo.c,
tools/schedsim/shell/shared/main_executing.c,
tools/schedsim/shell/shared/main_heir.c,
tools/schedsim/shell/shared/main_help.c,
tools/schedsim/shell/shared/main_rtemsinit.c,
tools/schedsim/shell/shared/main_semcreate.c,
tools/schedsim/shell/shared/main_semdelete.c,
tools/schedsim/shell/shared/main_semflush.c,
tools/schedsim/shell/shared/main_semobtain.c,
tools/schedsim/shell/shared/main_semrelease.c,
tools/schedsim/shell/shared/main_taskcreate.c,
tools/schedsim/shell/shared/main_taskdelete.c,
tools/schedsim/shell/shared/main_taskmode.c,
tools/schedsim/shell/shared/main_taskpriority.c,
tools/schedsim/shell/shared/main_taskresume.c,
tools/schedsim/shell/shared/main_tasksuspend.c,
tools/schedsim/shell/shared/main_taskwakeafter.c,
tools/schedsim/shell/shared/schedsim_shell.h,
tools/schedsim/shell/shared/shell_cmdset.c,
tools/schedsim/shell/shared/shell_makeargs.c,
tools/schedsim/shell/shared/include/shell.h,
tools/schedsim/shell/shared/include/newlib/_ansi.h,
tools/schedsim/shell/shared/include/newlib/getopt.h: Removed.
* configure.ac: RTEMS Scheduler Simulator is now in its own CVS module
named rtems-schedsim.
* score/Makefile.am, score/preinstall.am: bspsmp.h is now supposed to
be installed all the time. Revert part of previous commit.
* score/inline/rtems/score/schedulersimple.inl,
score/src/schedulersimpleyield.c: Fix violations of naming
convention.
PR 1789/cpukit
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Simple SMP Priority Scheduler.
* score/include/rtems/score/schedulersimplesmp.h,
score/src/schedulersimplesmpblock.c,
score/src/schedulersimplesmpschedule.c,
score/src/schedulersimplesmpunblock.c: New files.
* libnetworking/Makefile.am: Reformat.
* librpc/Makefile.am: Reformat.
* include/bsp.h: define CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
* libnetworking/rtems/rtems_bsdnet_internal.h: Move
#include <rtems.h> out of C++-guard.
* libcsupport/Makefile.am: Reformat.
* rtems/Makefile.am: Reformat.
* posix/Makefile.am: Reformat.
* posix/Makefile.am: Add posixtime.h.
* posix/src/clockgetres.c, posix/src/clockgettime.c,
posix/src/clocksettime.c:
Use CLOCK_PROCESS_CPUTIME_ID, CLOCK_THREAD_CPUTIME_ID.
Include posix/src/posixtime.h.
* posix/src/posixtime.h: New.
* libnetworking/rtems/mkrootfs.h: Make self-contained.
* rtems/interr.c: Minimize diffs to cpukit/score/src/interr.c.
* rtems/sched_cpu/rtems/score/cpu.h:
Incorporate parts of former posix BSP.
* libfs/Makefile.am: Unconditionally descend into src/nfsclient.
Include subdirs.am.
* sp21/init.c, sp21/sp21.doc sp21/sp21.scn: New test cases.
* sapi/include/confdefs.h: Added "/dev/zero" driver.
* libmisc/devnull/devzero.c, libmisc/devnull/devzero.h: New files.
* libmisc/Makefile.am, Makefile.am, preinstall.am: Reflect changes
above.
* index.html.in, common/opengroup_manpage_acknowledgement.texi,
common/opengroup_preface_acknowledgement.texi: New dates.
* score/include/rtems/score/schedulersimple.h,
score/src/schedulersimpleenqueue.c,
score/src/schedulersimpleenqueuefirst.c,
score/src/schedulersimplereadyqueueenqueue.c,
score/src/schedulersimplereadyqueueenqueuefirst.c,
score/src/schedulersimpleunblock.c: Correct names as pointed out by
Gedare.
PR 1788/cpukit
* score/include/rtems/score/percpu.h,
score/include/rtems/score/thread.h: Make time of last context switch
part of per cpu information since each core has a different context
switch to track.
* libnetworking/sys/ucred.h: Make self-contained.
* libnetworking/nfsclient/nfsdiskless.h: Make self-contained.
* libnetworking/nfs/nfsproto.h: Make self-contained.
* libnetworking/resolv.h: Make self-contained.
