* | build: Remove local.am | Sebastian Huber | 2018-10-10 | 244 | -253/+0 |
* | build: Directly reference libraries in tests | Sebastian Huber | 2018-10-10 | 5 | -64/+27 |
| | | | | Remove use of TMPINSTALL_FILES. | ||||
* | build: Merge score/cpu/*/Makefile.am | Sebastian Huber | 2018-10-10 | 23 | -1751/+1706 |
* | build: Merge libmisc/Makefile.am | Sebastian Huber | 2018-10-10 | 4 | -236/+214 |
* | build: Merge libnetworking/Makefile.am | Sebastian Huber | 2018-10-10 | 3 | -142/+132 |
* | build: Merge zlib/Makefile.am | Sebastian Huber | 2018-10-10 | 3 | -30/+23 |
* | build: Merge telnetd/Makefile.am | Sebastian Huber | 2018-10-10 | 3 | -15/+13 |
* | build: Merge score/Makefile.am | Sebastian Huber | 2018-10-10 | 3 | -230/+217 |
* | build: Merge rtems/Makefile.am | Sebastian Huber | 2018-10-10 | 4 | -205/+158 |
* | build: Merge pppd/Makefile.am | Sebastian Huber | 2018-10-10 | 3 | -19/+24 |
* | build: Merge posix/Makefile.am | Sebastian Huber | 2018-10-10 | 4 | -203/+222 |
* | build: Merge mghttpd/Makefile.am | Sebastian Huber | 2018-10-10 | 3 | -17/+13 |
* | build: Merge libstdthreads/Makefile.am | Sebastian Huber | 2018-10-10 | 6 | -23/+13 |
* | build: Merge librpc/Makefile.am | Sebastian Huber | 2018-10-10 | 4 | -54/+51 |
* | build: Merge libpci/Makefile.am | Sebastian Huber | 2018-10-10 | 4 | -41/+26 |
* | build: Merge libmd/Makefile.am | Sebastian Huber | 2018-10-10 | 4 | -20/+9 |
* | build: Merge libi2c/Makefile.am | Sebastian Huber | 2018-10-10 | 4 | -10/+1 |
* | build: Merge libgnat/Makefile.am | Sebastian Huber | 2018-10-10 | 4 | -16/+7 |
* | build: Merge libfs/Makefile.am | Sebastian Huber | 2018-10-10 | 5 | -186/+177 |
* | build: Merge libdrvmgr/Makefile.am | Sebastian Huber | 2018-10-09 | 4 | -38/+23 |
* | build: Merge libdl/Makefile.am | Sebastian Huber | 2018-10-09 | 4 | -41/+29 |
* | build: Merge libdebugger/Makefile.am | Sebastian Huber | 2018-10-09 | 3 | -24/+20 |
* | build: Merge libcsupport/Makefile.am | Sebastian Huber | 2018-10-09 | 4 | -138/+195 |
* | build: Merge libcrypt/Makefile.am | Sebastian Huber | 2018-10-09 | 4 | -15/+5 |
* | build: Merge libblock/Makefile.am | Sebastian Huber | 2018-10-09 | 4 | -43/+31 |
* | build: Merge libfdt/Makefile.am | Sebastian Huber | 2018-10-09 | 4 | -18/+8 |
* | build: Merge ftpd/Makefile.am | Sebastian Huber | 2018-10-09 | 3 | -13/+13 |
* | build: Merge dev/Makefile.am | Sebastian Huber | 2018-10-09 | 4 | -26/+14 |
* | build: Move sapi/Makefile.am | Sebastian Huber | 2018-10-09 | 6 | -66/+76 |
* | build: Remove specialized CPPFLAGS | Sebastian Huber | 2018-10-09 | 30 | -37/+0 |
* | shell: Use #include "..." for local header files | Sebastian Huber | 2018-10-09 | 30 | -37/+36 |
| | | | | Update #3375. | ||||
* | telnetd: Ignore setsockopt() return status | Sebastian Huber | 2018-10-09 | 2 | -2/+2 |
| | | | | Update #3529. | ||||
* | ftpd: Restructure chroot() handling. | Sebastian Huber | 2018-10-09 | 1 | -7/+3 |
| | | | | | | Remove superfluous setting of errno = 0. Update #3530. | ||||
* | leon: do not use -mfix-{device} with Clang | Daniel Hellstrom | 2018-10-09 | 2 | -2/+28 |
| | | | | | | | | | Clang do not support -mfix-gr712rc, -mfix-ut700 and -mfix-ut699. Therefore we adjust the CPU_CFLAGS to remove these when compiling with Clang. Instead use GR712RC: -mcpu=gr712rc GR740: -mcpu=gr740 UT699/UT700: Not currently supported by clang, use LEON3 BSP. | ||||
* | leon, spwtdp: Initial driver commit | Javier Jalle | 2018-10-09 | 7 | -0/+1357 |
* | bsps/arm: Fix ctor/dtor invocation order | Sebastian Huber | 2018-10-09 | 1 | -31/+4 |
| | | | | Remove obsolete .ctor and .dtor output sections. | ||||
* | posix: Remove static assertion | Sebastian Huber | 2018-10-09 | 2 | -2/+1 |
| | | | | | | | | Standard C does not allow pointer operands in an integer constant expressions. GCC issues only a -Wpedantic warning in the removed static assertion. However, clang is pedantic by default and issues an error. Rely on the test case instead. | ||||
* | ftpd: Remove superfluous temporary buffer | Sebastian Huber | 2018-10-08 | 1 | -31/+15 |
* | ftpd: Check return status of getsockname() | Sebastian Huber | 2018-10-08 | 1 | -18/+22 |
* | ftpd: Fix insecure chroot() handling | Sebastian Huber | 2018-10-05 | 1 | -8/+9 |
| | | | | | | | Ensure that the rtems_libio_set_private_env() was successful before the chroot(). Update #3530. | ||||
* | ftpd: Avoid resource leak | Sebastian Huber | 2018-10-05 | 1 | -0/+2 |
* | ftpd: Avoid use of uninitialized memory | Sebastian Huber | 2018-10-05 | 1 | -8/+7 |
* | ftpd: Avoid malloc() and sscanf() | Sebastian Huber | 2018-10-05 | 1 | -4/+3 |
| | | | | | | Move the user name to the session information. Update #3530. | ||||
* | ftpd: Remove FTPD_SessionInfo_t::pass member | Sebastian Huber | 2018-10-05 | 3 | -16/+51 |
| | | | | | | There is no need to keep the password throughout the session. Update #3530. | ||||
* | ftpd: Avoid NULL pointer checks before free() | Sebastian Huber | 2018-10-05 | 1 | -10/+5 |
| | | | | | | They are superfluous and just bloat the code. Update #3530. | ||||
* | jffs2: Avoid use of constant register variable | Sebastian Huber | 2018-10-05 | 1 | -0/+12 |
| | | | | | Avoid the use of a constant register variable which is used in some conditions. This gets rid of a clang -Wsometimes-uninitialized warning. | ||||
* | Fix rbtree_postorder_for_each_entry_safe() | Sebastian Huber | 2018-10-05 | 1 | -2/+2 |
| | | | | | | | | Use the non-standard typeof operator to avoid code generation errors with clang and use of uninitialized variable warnings with GCC and Coverity Scan. Update #3465. | ||||
* | score: Fix legacy RTEMS_STATIC_ASSERT() | Sebastian Huber | 2018-10-05 | 7 | -11/+25 |
| | | | | | | | | | In standard C pointer operands are not allowed in integer constant expressions. Avoid a static assertion based on an array typedef since this could lead to warnings ("variably modified 'x' at file scope" and "typedef 'x' locally defined but not used"); This implementation requires unique messages. | ||||
* | tests: Use rtems_task_exit() | Sebastian Huber | 2018-10-05 | 164 | -365/+223 |
| | | | | Update #3533. | ||||
* | score: Remove CPU_PROVIDES_IDLE_THREAD_BODY | Sebastian Huber | 2018-10-05 | 37 | -516/+53 |
| | | | | | | | Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary conditional compilation. Close #3539. |
