* | Patch from Emmanuel Raguet <raguet@crf.canon.fr> to add remote debug server | Joel Sherrill | 1998-12-03 | 102 | -148/+20545 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | and RPC support to RTEMS. Thanks. :) Email follows: Hello, For Xmas, here is the Remote Debugger on RTEMS ! Here are 2 patches for the Remote Debugger on RTEMS for pc386 from Linux host : - one for RTEMS it self, - one for GDB-4.17. 1/ RTEMS patch -------------- This patch adds 2 libraries : - a simplified SUN RPC library - the Remote Debugger library The configuration command is the following : ../rtems4/configure --target=i386-rtemself --enable-rtemsbsp=pc386 --enable-rdbg The SUN RPC library is built only if networking is set. The RDBG library is built if networking and enable-rdbg are set. The function used to initialize the debugger is : rtems_rdbg_initialize (); A special function has been created to force a task to be in a "debug" state : enterRdbg(). The use of this function is not mandatory. 2/ GDB-4.17 patch ----------------- This patch create a new RTEMS target for GDB-4.17. The configuration command is the following : ./configure --enable-shared --target=i386RTEMS To connect to a target, use : target rtems [your_site_address] Then, attach the target using : attach 1 And... Debug ;) You can obtain the original GDB-4.17 on ftp://ftp.debian.org/debian/dists/stable/main/source/devel/gdb_4.17.orig.tar.gz This has been tested from a Debian 2.0.1 linux host. | ||||
* | Removed spaces. | Joel Sherrill | 1998-12-03 | 6 | -28/+0 |
* | Changed to account for ownership only being tracked when a priority | Joel Sherrill | 1998-12-03 | 2 | -0/+16 |
| | | | | blocking protocol is used. | ||||
* | Removed all ^M from the file. | Jennifer Averett | 1998-12-03 | 2 | -312/+312 |
* | Added psx to the front of all test names. | Jennifer Averett | 1998-12-03 | 1 | -1/+1 |
* | Removed all ^M from the scn file. | Jennifer Averett | 1998-12-03 | 2 | -2506/+2506 |
* | Cleaned up test. | Jennifer Averett | 1998-12-03 | 14 | -640/+960 |
| | | | | Updated scn files to match present expected test output. | ||||
* | Added Comment that a result is valid at 4 or 5 seconds. | Jennifer Averett | 1998-12-03 | 2 | -26/+2 |
* | Updated scn files to match present expected test output. | Jennifer Averett | 1998-12-03 | 8 | -22/+534 |
* | Renamed all directories to start with psx. | Jennifer Averett | 1998-12-03 | 4 | -4/+4 |
* | Added a posix time test. | Jennifer Averett | 1998-12-03 | 1 | -2/+2 |
| | | | | Renamed all directories to start with psx. | ||||
* | Added imfs_fdatasync routine that gets called from both fdatasync and datasync. | Jennifer Averett | 1998-12-03 | 4 | -0/+104 |
* | Added a imfs fdatasync routine that gets called for fdatasync and datasync. | Jennifer Averett | 1998-12-03 | 5 | -5/+20 |
* | Added source for F_DUPFD. | Jennifer Averett | 1998-12-03 | 3 | -36/+54 |
* | Modifications for RTEMS_UNIX. | Jennifer Averett | 1998-12-03 | 17 | -4/+80 |
* | Added a imfs fdatasync routine that gets called for fdatasync and datasync. | Jennifer Averett | 1998-12-03 | 1 | -13/+24 |
| | | | | Modifications for RTEMS_UNIX. | ||||
* | Modified to support test names longer than two characters plus the | Joel Sherrill | 1998-12-03 | 1 | -1/+1 |
| | | | | | test suite designator. In English, we now support psxfile in addition to psx11. | ||||
* | Insure that the same output occurs when multiprocessing is disabled. | Joel Sherrill | 1998-12-03 | 10 | -2/+82 |
* | Moved cpuuse.h to rtems subdirectory. | Joel Sherrill | 1998-12-03 | 2 | -2/+2 |
* | Moved stackchk.h to rtems subdirectory. | Joel Sherrill | 1998-12-03 | 9 | -17/+27 |
* | Increased default amount of RAM. | Joel Sherrill | 1998-12-03 | 1 | -1/+1 |
* | Removed reference to stackchk.h. | Joel Sherrill | 1998-12-03 | 1 | -4/+0 |
* | Don't build libchip if we are targetting UNIX. | Joel Sherrill | 1998-12-03 | 1 | -1/+6 |
* | Corrected spacing. | Joel Sherrill | 1998-12-03 | 2 | -2/+2 |
* | Corrected ifdef on RTEMS_MULTIPROCESSING so the queue is actually closed. | Joel Sherrill | 1998-12-03 | 2 | -4/+8 |
* | Removed reference to libpurify. | Joel Sherrill | 1998-12-01 | 2 | -4/+4 |
* | Include files now installed as <rtems/*.h>. | Joel Sherrill | 1998-12-01 | 14 | -18/+16 |
* | Removed unused file. | Joel Sherrill | 1998-12-01 | 5 | -195/+3 |
| | | | | Include files now installed as <rtems/*.h>. | ||||
* | changed version to 4.0.0-RADSTONE | Joel Sherrill | 1998-11-25 | 1 | -1/+1 |
* | First Cut at Hitachi SH. | Joel Sherrill | 1998-11-25 | 12 | -0/+1222 |
* | New files copied from template and personalized. | Joel Sherrill | 1998-11-23 | 12 | -0/+1314 |
* | New files added as part of file system infrastructure effort. | Joel Sherrill | 1998-11-23 | 4 | -0/+84 |
* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 330 | -2518/+31856 |
| | | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. | ||||
* | Added new tests in support of the file system infrastructure. | Joel Sherrill | 1998-11-23 | 7 | -0/+373 |
* | Added tests in support of the file system infrastructure. | Joel Sherrill | 1998-11-23 | 43 | -1/+9817 |
* | Removed. | Joel Sherrill | 1998-11-23 | 2 | -97/+1 |
* | Upped the memory to 8 Mbytes. | Joel Sherrill | 1998-11-23 | 1 | -1/+2 |
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 154 | -494/+1593 |
| | | | | it work. | ||||
* | Added networking. | Joel Sherrill | 1998-11-23 | 2 | -5/+10 |
* | Removed "HAS_NETWORKING=no". | Joel Sherrill | 1998-11-23 | 1 | -4/+0 |
* | New network driver from Erik Ivanenko <erik.ivanenko@utoronto.ca>. | Joel Sherrill | 1998-11-23 | 4 | -0/+3113 |
* | Bug report from Peter Mueller <pmueller@decrc.abb.de>: | Joel Sherrill | 1998-11-19 | 1 | -1/+1 |
| | | | | | | | | I use the m68k/efi332 BSP together with a home made board. After some time of debugging I found that the m68020 CPU is used to build rtems. This is not correct, because the 68332 does not have some of the 68020 features (no separate int stack ...). It is necessary to change this to mcpu32. After a clean/make everything works fine. | ||||
* | Renamed exception constants per requests from Erik Ivanenko | Joel Sherrill | 1998-11-19 | 1 | -19/+19 |
| | | | | <erik.ivanenko@utoronto.ca> and Eric Valette <valette@crf.canon.fr>. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1998-11-19 | 3 | -4/+4 |
| | | | | | | | Here is a cosmetic patch which corrects a few spelling problems in parts written by me. Apparently, I must have written these under the influence of ether (:-) | ||||
* | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1998-11-19 | 29 | -702/+925 |
| | | | | | | | | | | | | | | | 1) Socket timeout field changed from `short' to `long'. This makes longer timeouts possible. With a 1 kHz system clock the old system allowed timeouts only up to a little over 30 seconds! This change is a slightly cleaned-up version of the patch proposed by Ian Lance Taylor. 2) Major changes to BOOTP/DHCP reply handling. Now supports much of RFC2132. These changes were done at the request of, and with the assistance of, Erik Ivanenko. If you're making changes, you might want to change the network supplement Essentially just do a global search and replace of BOOTP with BOOTP/DHCP. | ||||
* | Changed BOOTP -> BOOTP/DHCP. | Joel Sherrill | 1998-11-19 | 2 | -11/+12 |
* | Changed version string. | Joel Sherrill | 1998-11-19 | 9 | -33/+447 |
| | | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk. | ||||
* | Stripped down to be just new chapters. | Joel Sherrill | 1998-11-19 | 2 | -102/+8 |
* | Renamed entire document so this is a transient working directory. | Joel Sherrill | 1998-11-19 | 1 | -43/+5 |
* | Merged these into POSIX manual. | Joel Sherrill | 1998-11-19 | 19 | -9745/+0 |
