* | Now generates complete template for chapters. | Joel Sherrill | 1998-08-01 | 1 | -53/+85 |
* | New files -- automatically gnerated templates. | Joel Sherrill | 1998-08-01 | 2 | -0/+722 |
* | New file | Joel Sherrill | 1998-08-01 | 1 | -0/+65 |
* | Removed items which are now automatically generated. | Joel Sherrill | 1998-08-01 | 1 | -41/+1 |
* | New file. | Joel Sherrill | 1998-08-01 | 1 | -0/+98 |
* | Removed all node and menu information since this information is now | Joel Sherrill | 1998-08-01 | 9 | -563/+12 |
| | | | | | | | automatically generated. Removed any attempts to link across chapter boundaries since the manual is incomplete. | ||||
* | Modified so chapters are automatically generated. | Joel Sherrill | 1998-08-01 | 1 | -8/+4 |
* | New file | Joel Sherrill | 1998-08-01 | 1 | -0/+7 |
* | Don't automatically generate this one. | Joel Sherrill | 1998-08-01 | 1 | -0/+0 |
* | Moved to thread.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -1025/+0 |
* | Moved to signal.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -691/+0 |
* | Moved to sched.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -228/+0 |
* | Moved to preface.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -21/+0 |
* | Moved to mutex.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -642/+0 |
* | Moved to key.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -179/+0 |
* | Moved to cond.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -386/+0 |
* | Moved to clock.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -264/+0 |
* | Added automatic generation of files. | Joel Sherrill | 1998-08-01 | 9 | -1/+3478 |
* | Moved to network demos | Joel Sherrill | 1998-08-01 | 1 | -8/+1 |
* | Patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to make ASFLAGS include the | Joel Sherrill | 1998-08-01 | 2 | -2/+2 |
| | | | | CPU_ASFLAGS. | ||||
* | Patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to not use this file for | Joel Sherrill | 1998-08-01 | 1 | -0/+3 |
| | | | | ColdFires. It is just too wrong to fix. | ||||
* | Merged patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to add ColdFire | Joel Sherrill | 1998-08-01 | 4 | -3/+33 |
| | | | | specific register macros and correct code in rtems.s. | ||||
* | Added Rod Barman (rodb@cs.ubc.ca) in credits for ColdFire. | Joel Sherrill | 1998-08-01 | 1 | -1/+2 |
* | Changed name of network driver. | Joel Sherrill | 1998-07-30 | 1 | -1/+1 |
* | Added temporary include of dmv170.h | Joel Sherrill | 1998-07-30 | 1 | -0/+6 |
* | Added SONIC configuration information. | Joel Sherrill | 1998-07-30 | 1 | -0/+9 |
* | Added a hint to continue writing this. | Joel Sherrill | 1998-07-30 | 1 | -0/+2 |
* | Updated. | Joel Sherrill | 1998-07-30 | 2 | -2/+2 |
* | Added getRealTime() and setRealTime(). | Joel Sherrill | 1998-07-30 | 2 | -18/+99 |
| | | | | Reimplemented checkRealTime() to use RTEMS internal routine. | ||||
* | Changed clock rate from 32 Khz to 1 Mhz. | Joel Sherrill | 1998-07-30 | 2 | -6/+6 |
| | | | | Registers are at 8 byte boundaries NOT 4 as initially configured. | ||||
* | Changed comment to be more polite. | Joel Sherrill | 1998-07-30 | 1 | -1/+1 |
* | Updating to make more readable. | Joel Sherrill | 1998-07-30 | 1 | -28/+8 |
* | New files. | Joel Sherrill | 1998-07-30 | 8 | -0/+46 |
* | Spacing corrected. | Joel Sherrill | 1998-07-30 | 1 | -1/+0 |
* | New file based on email from DY-4 technical support. | Joel Sherrill | 1998-07-30 | 1 | -0/+62 |
* | Fixed spacing. | Joel Sherrill | 1998-07-30 | 1 | -1/+0 |
* | Updated to accurately reflect the dmv177. | Joel Sherrill | 1998-07-30 | 1 | -22/+21 |
* | Patch from Eric Valette <valette@crf.canon.fr>: | Joel Sherrill | 1998-07-30 | 1 | -1/+1 |
| | | | | | | Now that Joel told me how to compile outside the tree, I have found a few more bugs. Here is a small patch to fix them. | ||||
* | Made chain.h shared | Joel Sherrill | 1998-07-30 | 2 | -355/+1 |
* | Made tod.h shared | Joel Sherrill | 1998-07-30 | 2 | -1/+2 |
* | Added HAS_RTC and enabled KA9Q. | Joel Sherrill | 1998-07-30 | 1 | -4/+2 |
* | New file. Based on merged of shared libchip style console.c and the | Joel Sherrill | 1998-07-29 | 1 | -0/+187 |
| | | | | existing TOD interface. | ||||
* | Cleaned up comment. | Joel Sherrill | 1998-07-29 | 1 | -4/+5 |
| | | | | Modified open so it uses a local variable rather than modifying a parameter. | ||||
* | Added reference to shared TOD driver. | Joel Sherrill | 1998-07-29 | 1 | -1/+1 |
* | Added prototype for default register access routines to header files. | Joel Sherrill | 1998-07-29 | 8 | -8/+200 |
| | | | | | Corrected prototypes to reflect unsigned32 values being passed around instead of unsigned8's. | ||||
* | Corrected to reflect the ICM7170 which is really on this board. | Joel Sherrill | 1998-07-29 | 2 | -16/+12 |
* | Added config.c and deleted tod.c. | Joel Sherrill | 1998-07-29 | 1 | -1/+1 |
* | Simplified RTC base address. | Joel Sherrill | 1998-07-29 | 1 | -2/+1 |
* | Changed cast on RTC address and added base address of RTC fields as opposed | Joel Sherrill | 1998-07-29 | 1 | -1/+2 |
| | | | | to entire RTC with NVRAM included. | ||||
* | Deleted probe routine as device specific. | Joel Sherrill | 1998-07-29 | 2 | -12/+6 |
| | | | | Renamed port table. |
