* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to move librdbg | Joel Sherrill | 1999-10-11 | 14 | -137/+1083 |
| | | | | to its own top level package. | ||||
* | Switched to the C++ front end to gcc to link. This still did not | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
| | | | | work. | ||||
* | Now compiles for coff and elf. | Joel Sherrill | 1999-10-11 | 1 | -65/+185 |
* | Added file system guide. | Joel Sherrill | 1999-10-11 | 1 | -45/+163 |
| | | | | Corrected link to supplements. | ||||
* | Cleanup. | Joel Sherrill | 1999-10-11 | 4 | -109/+140 |
* | First cut at complete document under CVS and texinfo. | Joel Sherrill | 1999-10-11 | 2 | -1/+9 |
* | New files. | Joel Sherrill | 1999-10-11 | 2 | -0/+2968 |
* | Added filesystem implementation notes chapter. | Joel Sherrill | 1999-10-08 | 2 | -1/+8 |
* | Added lifecycle chapter. | Joel Sherrill | 1999-10-08 | 3 | -3/+45 |
* | First cut at merging. | Joel Sherrill | 1999-10-08 | 1 | -26/+42 |
* | Another couple of chapters formatting under texinfo. | Joel Sherrill | 1999-10-08 | 2 | -31/+65 |
* | Added initial version of 3 other chapters. | Joel Sherrill | 1999-10-08 | 4 | -32/+49 |
* | Renamed path_eval to patheval | Joel Sherrill | 1999-10-08 | 1 | -2/+11 |
* | Base versions cut from old document. | Joel Sherrill | 1999-10-08 | 3 | -0/+108 |
* | Finished initial conversion to texinfo. | Joel Sherrill | 1999-10-08 | 1 | -171/+214 |
* | Added applayering but did not finish it. | Joel Sherrill | 1999-10-07 | 3 | -1/+288 |
* | Filled in descriptions for required fields in CPU Configuration Table. | Joel Sherrill | 1999-10-07 | 1 | -1/+58 |
* | Added Base File System chapter. Builds completely. | Joel Sherrill | 1999-10-07 | 4 | -39/+325 |
* | Built with preface for info. | Joel Sherrill | 1999-10-07 | 3 | -0/+279 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+2 |
| | | | | | | pdf version of figures. Added convert stanza to generate pdf's from eps of figures. | ||||
* | Enhanced to support @email{} as supported in texi2html in texinfo 4.0. | Joel Sherrill | 1999-10-07 | 1 | -0/+5 |
| | | | | | This way we maintain compatibility but continue to use the better, more flexible tool. | ||||
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 17 | -17/+17 |
| | | | | pdf version of figures. | ||||
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 2 | -6/+6 |
| | | | | | | | | | | | | pdf version of figures. Disabled building of pdf for both the C and Ada Getting Started manuals because texi2pdf can not handle the construct: @set URL http://www.rtems.com @uref{@value{URL},@value{URL}} It will be reenabled as soon as this problem is fixed. | ||||
* | Switched back to jpg for networkflow because netscape 4.71 for linux | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | did not display the png properly. | ||||
* | Regenerated. | Joel Sherrill | 1999-10-07 | 3 | -0/+0 |
* | Enabled table of contents generation so the left hand side of the PDF | Joel Sherrill | 1999-10-07 | 10 | -10/+10 |
| | | | | viewer can have section headings. | ||||
* | Now includes figures. | Joel Sherrill | 1999-10-07 | 1 | -12/+5 |
* | Updated. | Joel Sherrill | 1999-10-07 | 1 | -0/+0 |
* | COpy the images to the html install point. | Joel Sherrill | 1999-10-07 | 1 | -2/+6 |
| | | | | Added stanza to generate pdf files from eps ones. | ||||
* | Copy figures from user guide directory so they can be included in the | Joel Sherrill | 1999-10-07 | 1 | -7/+15 |
| | | | | | | generated document. User $(PROJECT) instead of ada_user | ||||
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 3 | -3/+3 |
* | Added Porting Guide to documentation set. | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
* | Enabled building pdf. | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
* | Changed install point to /usr1/rtems/tmp. | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
* | Renamed and generated pdf. | Joel Sherrill | 1999-10-07 | 3 | -1/+1 |
* | New file -- converted from networkflow.eps | Joel Sherrill | 1999-10-07 | 1 | -0/+0 |
* | New files. | Joel Sherrill | 1999-10-07 | 2 | -0/+0 |
* | New directive added -- rtems_task_is_suspended. | Joel Sherrill | 1999-10-07 | 3 | -1/+153 |
* | Added rtems_task_is_suspended. | Joel Sherrill | 1999-10-07 | 1 | -0/+42 |
* | Cleaned up use of $(PROJECT) instead of hard-coding c_user. | Joel Sherrill | 1999-10-07 | 1 | -3/+5 |
| | | | | Added rule to convert rtemspie.eps to .pdf. | ||||
* | Added Is_Suspended method. | Joel Sherrill | 1999-10-07 | 4 | -0/+40 |
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-06 | 26 | -5265/+0 |
| | | | | | | | | | | | | | | and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP. | ||||
* | New file. | Joel Sherrill | 1999-10-06 | 6 | -0/+84 |
* | Removed aclocal.m4 generated from aclocal macros | Joel Sherrill | 1999-10-06 | 45 | -29493/+0 |
* | Removed configure generated from configure.in | Joel Sherrill | 1999-10-06 | 45 | -93893/+0 |
* | Modified to avoid conflicts on definitions of malloc. newlib 1.8.2 | Joel Sherrill | 1999-10-06 | 10 | -10/+10 |
| | | | | | | | | now prototypes the malloc family in stdlib.h. This causes conflicts with the way the network stack overrides the definitions of malloc. As best I (being Joel) can tell, commenting stdlib.h out keeps the files compiling and referencing the desired malloc/free but results in more warnings. | ||||
* | Modified to explicitly list all files as part of C_PIECES. | Joel Sherrill | 1999-10-06 | 1 | -1/+2 |
* | Added Porting Guide. | Joel Sherrill | 1999-10-06 | 1 | -0/+2 |
* | Added portability write up from paper from France in 1997 as starting | Joel Sherrill | 1999-10-06 | 2 | -5/+133 |
| | | | | point for portability discussion. | ||||
* | Added copyrights and CVS Ids. | Joel Sherrill | 1999-10-06 | 10 | -0/+80 |
