* aclocal/version.m4: Updated to rtems-20031217-test.
* release_support: Correct method used to find ChangeLog associated
with the version.m4 files. Keep going until I can get a tarball cut.
* VERSION: Updated to rtems-20031217-test.
* c/src/aclocal/version.m4: Updated to rtems-20031217-test.
* release_support: Use dirname not basedir. Keep going until I
* release_support: New file -- assistant to new cut_release script.
* release_support: Removed -- accidentally added to wrong directory.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am:
Eliminate VPATH.
* shared/Makefile.am: Fix typo in rule to build from cache/%.c.
* tmtests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* tmitrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* sptests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* sample.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* psxtests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* mptests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* libtests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* itrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* automake/compile.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* bsp.am: Use $(mkdir_p) instead of $(mkinstalldirs).
PR 542/filesystem
* include/rtems/libio_.h: Add rtems_libio_iop_to_descriptor macro to
convert iop to the corresponding integer file descriptor.
PR 544/tests
* include/buffer_test_io.h: Various modifications to make tests account
for resources and not print at inappropriate times.
PR 544/tests
* malloctest/system.h, rtmonuse/system.h: Various modifications to make
tests account for resources and not print at inappropriate times.
PR 544/tests
* sp07/Makefile.am, sp07/init.c, sp07/system.h, sp07/task4.c,
sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c,
sp09/system.h, sp19/system.h, sp20/system.h: Various modifications to
make tests account for resources and not print at inappropriate
times.
* sp07/buffered_io.c: New file.
PR 533/bsps
* startup/linkcmds: Update linkcmds for gcc 3.3.2.
PR 333/bsps
* startup/linkcmds: Remove SEARCH_DIR.
* setup.def: Update gcc/newlib for 4.7 series to 3.3.2 with 20031022
gcc patch (RPM revision 4.7-1).
* mpc6xx/wrapup/.cvsignore: Remove.
* mongoosev/duart/Makefile.am: Remove.
* mongoosev/vectorisrs/Makefile.am: Remove.
* mongoosev/Makefile.am: Merge-in vectorisrs/Makefile.am,
duart/Makefile.am.
* r46xx/vectorisrs/Makefile.am: Remove.
* r46xx/Makefile.am: Merge-in vectorisrs/Makefile.am.
* shared/cache/Makefile.am: Remove.
* shared/interrupts/Makefile.am: Remove.
* shared/Makefile.am: Merge-in cache/Makefile.am,
interrupts/Makefile.am.
* tx39/vectorisrs/Makefile.am: Remove.
* tx39/Makefile.am: Merge-in vectorisrs/Makefile.am.
* shared/misc/Makefile.am: Remove.
* shared/Makefile.am: Merge-in the Makefile.ams above.
Eliminate VPATH.
* cache/Makefile.am: Eliminate VPATH.
* Makefile.am: Eliminate VPATH.
* ppc403/clock/Makefile.am: Remove.
* ppc403/console/Makefile.am: Remove.
* ppc403/ictrl/Makefile.am: Remove.
* ppc403/timer/Makefile.am: Remove.
* ppc403/tty_drv/Makefile.am: Remove.
* ppc403/vectors/Makefile.am: Remove.
* ppc403/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Reflect changes to ppc403/Makefile.ams.
* mpc505/ictrl/Makefile.am: Remove.
* mpc505/timer/Makefile.am: Remove.
* mpc505/vectors/Makefile.am: Remove.
* mpc505/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Reflect changes to mpc8xx/Makefile.ams.
* mpc8xx/clock/Makefile.am: Remove.
* mpc8xx/console-generic/Makefile.am: Remove.
* mpc8xx/cpm/Makefile.am: Remove.
* mpc8xx/exceptions/Makefile.am: Remove.
* mpc8xx/mmu/Makefile.am: Remove.
* mpc8xx/timer/Makefile.am: Remove.
* mpc8xx/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Remove mpc6xx/*/Makefile, mpc8260/*/Makefile.
* mpc6xx/clock/Makefile.am: Remove.
* mpc6xx/exceptions/Makefile.am: Remove.
* mpc6xx/mmu/Makefile.am: Remove.
* mpc6xx/timer/Makefile.am: Remove.
* mpc6xx/wrapup/Makefile.am: Remove.
* mpc6xx/Makefile.am: Merge-in Makefile.ams above.
* mpc8260/clock/Makefile.am: Remove.
* mpc8260/console-generic/Makefile.am: Remove.
* mpc8260/cpm/Makefile.am: Remove.
* mpc8260/exceptions/Makefile.am: Remove.
* mpc8260/mmu/Makefile.am: Remove.
* mpc8260/timer/Makefile.am: Remove.
* mpc8260/Makefile.am: Merge-in Makefile.ams above.
* shared/include/Makefile.am: Remove.
* shared/src/Makefile.am: Remove.
* shared/Makefile.am: Merge-in Makefile.ams above.
* startup/linkcmds.dl: Remove SEARCH_DIR.
* aclocal/env-rtemsbsp.m4: Add PROJECT_LIB.
* automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
