* | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1999-10-21 | 19 | -135/+231 |
| | | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | ||||
* | Added Semaphore_Flush. | Joel Sherrill | 1999-10-21 | 4 | -0/+36 |
* | Shipping this all to Ralf. | Joel Sherrill | 1999-10-21 | 2 | -6/+7 |
* | Added prototype for rtems_task_is_suspended at request of | Joel Sherrill | 1999-10-20 | 2 | -2/+24 |
| | | | | Eric Norum. | ||||
* | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 1999-10-20 | 7 | -19/+42 |
| | | | | functioned. | ||||
* | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 1999-10-20 | 2 | -34/+37 |
| | | | | | | functioned. Merged Ralf's changes into gccnewlib.spec.in. | ||||
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+50 |
* | Miscellaneous improvements and cleanups committed so I can merge | Joel Sherrill | 1999-10-20 | 13 | -199/+35 |
| | | | | Ralf's end of day version. | ||||
* | Moved rtems specific files into here. | Joel Sherrill | 1999-10-20 | 1 | -0/+80 |
* | Moving things to an rtems subdirectory like the other tools. | Joel Sherrill | 1999-10-20 | 2 | -80/+0 |
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+177 |
* | Added RPM release numbers. | Joel Sherrill | 1999-10-20 | 2 | -10/+25 |
* | Generated files removed. | Joel Sherrill | 1999-10-20 | 11 | -307/+155 |
* | Obsoleted. | Joel Sherrill | 1999-10-20 | 1 | -34/+0 |
* | Obsoleted as they were distributed to subdirectories. | Joel Sherrill | 1999-10-20 | 4 | -473/+0 |
* | Made this more binutils like. :) | Joel Sherrill | 1999-10-20 | 1 | -5/+9 |
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+104 |
* | New files. | Joel Sherrill | 1999-10-20 | 2 | -0/+285 |
* | Adding the infrastructure for gdb. | Joel Sherrill | 1999-10-20 | 10 | -47/+155 |
* | Corrected typo. | Joel Sherrill | 1999-10-20 | 1 | -3/+3 |
* | Restored joel's changes after merging old version from Ralf. | Joel Sherrill | 1999-10-20 | 1 | -19/+90 |
* | New version from Ralf. | Joel Sherrill | 1999-10-20 | 28 | -213/+3357 |
* | Committing changes before Ralf's changed. | Joel Sherrill | 1999-10-20 | 4 | -24/+92 |
* | Left to build overnight. | Joel Sherrill | 1999-10-19 | 7 | -10/+123 |
* | Made it easier to change version numbers. | Joel Sherrill | 1999-10-19 | 2 | -15/+21 |
* | Now easier to modify version numbers in scripts. | Joel Sherrill | 1999-10-19 | 2 | -14/+20 |
* | Easier to insert tool version number. | Joel Sherrill | 1999-10-19 | 2 | -20/+31 |
* | Making sparc-rtems rpms available. | Joel Sherrill | 1999-10-18 | 3 | -2/+3 |
* | Working on being able to cut RPMs. It now appears that the process | Joel Sherrill | 1999-10-18 | 12 | -27/+788 |
| | | | | | | | | | | | | | is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets. | ||||
* | Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to | Joel Sherrill | 1999-10-15 | 7 | -0/+399 |
| | | | | help build RPMs. | ||||
* | Reorganized a lot per Jennifer's suggestions. | Joel Sherrill | 1999-10-13 | 4 | -120/+120 |
* | Updated copyright date. | Joel Sherrill | 1999-10-13 | 6 | -5/+7 |
* | More manuals and a little reorganization. | Joel Sherrill | 1999-10-13 | 1 | -5/+25 |
* | First commit of miscellaneous tools and documentation for a procedure | Joel Sherrill | 1999-10-13 | 8 | -0/+343 |
| | | | | that can be used to produce an online bookshelf of the GNU tools. | ||||
* | Made many changes to turn the outline into something more like a manual | Joel Sherrill | 1999-10-12 | 9 | -448/+1854 |
| | | | | and less like a collection of notes. | ||||
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -35/+0 |
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -324/+0 |
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -339/+0 |
* | New file. | Joel Sherrill | 1999-10-12 | 1 | -0/+34 |
* | Spacing. | Joel Sherrill | 1999-10-12 | 4 | -0/+4 |
* | Split null handlers table to own file and renamed. | Joel Sherrill | 1999-10-12 | 26 | -238/+60 |
| | | | | Renamed IMFS handler tables to include IMFS prefix. | ||||
* | Added rtems_filesystem_freenode() macro and added calls at appropriate | Joel Sherrill | 1999-10-12 | 52 | -280/+209 |
| | | | | | places to make sure memory allocated for filesystem specifif nodes gets freed. | ||||
* | Fixed spacing. | Joel Sherrill | 1999-10-12 | 4 | -4/+4 |
* | Corrected mistakes in the IMFS file handlers table and added the missing | Joel Sherrill | 1999-10-12 | 13 | -31/+428 |
| | | | | routine imfs_fcntl.c | ||||
* | Added call to freenod to let each filesystem free its own internal | Joel Sherrill | 1999-10-12 | 46 | -208/+697 |
| | | | | node used to manage file access. | ||||
* | Changed bcopy to strncpy to stick to ANSI/ISO routines. | Joel Sherrill | 1999-10-12 | 3 | -3/+3 |
* | Fixed random cut and paste problem. | Joel Sherrill | 1999-10-11 | 1 | -23/+23 |
* | Added files generated by index process to clean stanza. | Joel Sherrill | 1999-10-11 | 3 | -1/+5 |
* | Changed link for bad PDF files to BAD.html. | Joel Sherrill | 1999-10-11 | 1 | -2/+2 |
* | Changed version information. | Joel Sherrill | 1999-10-11 | 2 | -2/+2 |
