* | Renamed hppa1_1 to hppa1.1 | Joel Sherrill | 1998-03-23 | 4 | -85/+73 |
* | renamed ppc to powerpc | Joel Sherrill | 1998-03-23 | 5 | -80/+72 |
* | Updated now that the phony crt0.c in newlib defines all odd symbols | Joel Sherrill | 1998-03-23 | 3 | -72/+4 |
| | | | | that gcc automatically generates references to. | ||||
* | *** empty log message *** | Joel Sherrill | 1998-03-23 | 1 | -101/+67 |
* | Converted to conditionally uses strerr code to better work with glibc2. | Joel Sherrill | 1998-03-23 | 2 | -8/+21 |
* | Patches from Eric Norum: | Joel Sherrill | 1998-03-23 | 9 | -174/+85 |
| | | | | | | | Here are some patches to the gen68360 BSP. The improvements include: Boot prom run-time selection of DRAM size (1/4/16 Mbytes) Full 32-bit ethernet address obtained from boot prom. Updated README. | ||||
* | Update from Eric Norum: | Joel Sherrill | 1998-03-23 | 1 | -12/+3 |
* | Added BSP specific start since it had become VERY complex to attempt | Joel Sherrill | 1998-03-21 | 3 | -1/+325 |
| | | | | to share the start code across i386 BSPs. | ||||
* | Corrected typo in copyright notice. | Joel Sherrill | 1998-03-21 | 2 | -2/+2 |
* | Switch to using a shared main() for all of the embedded BSPs | Joel Sherrill | 1998-03-21 | 70 | -463/+190 |
| | | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path. | ||||
* | Fixed spacing to be consistent with other CPUs. | Joel Sherrill | 1998-03-21 | 1 | -1/+1 |
* | Fixed RTEMS_PROG_CC_WORKS and RTEMS_PROG_CXX_WORKS so they could | Joel Sherrill | 1998-03-21 | 2 | -71/+133 |
| | | | | successfully work on powerpc-rtems and hppa1.1-rtems. | ||||
* | Added enough symbols to the conftest.c program to make sure it would | Joel Sherrill | 1998-03-21 | 2 | -3/+34 |
| | | | | successfully link on both the powerpc and hppa1.1. | ||||
* | POSIX not properly conditionalized | Joel Sherrill | 1998-03-21 | 2 | -2/+2 |
* | Fixed typo. | Joel Sherrill | 1998-03-20 | 2 | -2/+2 |
* | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1998-03-20 | 1 | -11/+2 |
| | | | | | | | | | | I've included a version of make/custom/gen68360.cfg that works with this. Note that I've removed the option of using `-m68020 -msoft-float -mno-bitfield' as an alternative to using `-mcpu32'. The alternative won't work with the new system (since it predefines __mc68020__ and not __mcpu32__), and didn't really work before anyway (since the newlib that gets linked was built with `-m68020 -msoft-float' and so could contain bitfield operators). | ||||
* | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1998-03-20 | 1 | -81/+75 |
| | | | | | | Here is my attempt at bringing m68k.h into line with the predefined symbols provided by egcs-1.0.2-prerelease (with R. Kirkham's patch so that -mcpu32, etc. implies -msoft-float). | ||||
* | Added Hitachi SH port info. | Joel Sherrill | 1998-03-20 | 1 | -1/+2 |
* | New port from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1998-03-20 | 25 | -0/+1919 |
* | SH port submitted from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1998-03-20 | 32 | -0/+5497 |
* | Patch from Ralf Corsepius to properly detect that Cygwin32 does not | Joel Sherrill | 1998-03-20 | 3 | -84/+111 |
| | | | | support the -pipe option on the compiler. | ||||
* | Fixed MANAGERS_NOT_WANTED. | Joel Sherrill | 1998-03-20 | 1 | -2/+2 |
* | Removed blank line. | Joel Sherrill | 1998-03-20 | 1 | -1/+1 |
* | Added Constants, Feature Flags, and Macros (included in Functions). | Joel Sherrill | 1998-03-18 | 17 | -126/+554 |
| | | | | No status information was included. | ||||
* | First attempt at adding constants and feature flags | Joel Sherrill | 1998-03-17 | 5 | -10/+324 |
* | Completed status pass on functions and data types. | Joel Sherrill | 1998-03-17 | 12 | -33/+48 |
* | Completed first pass at function status. | Joel Sherrill | 1998-03-17 | 9 | -96/+117 |
| | | | | Added most data types without status information. | ||||
* | Added types, status of functions, cleaned up output of summarize. | Joel Sherrill | 1998-03-16 | 9 | -229/+316 |
* | Added function status and data types | Joel Sherrill | 1998-03-16 | 3 | -21/+54 |
* | Cleaned up format and added data types. | Joel Sherrill | 1998-03-16 | 1 | -8/+38 |
* | Added Function field. | Joel Sherrill | 1998-03-16 | 15 | -344/+344 |
* | summarize now generates a nicely formatted function status summary. | Joel Sherrill | 1998-03-16 | 2 | -3/+13 |
* | Function implmentation status information correct. | Joel Sherrill | 1998-03-16 | 1 | -10/+10 |
* | First time summary chapter is included in the document. | Joel Sherrill | 1998-03-16 | 3 | -3/+6 |
* | Fix from Chris Johns for inconsistent invocation of make. | Joel Sherrill | 1998-03-16 | 2 | -2/+2 |
* | Added blank lines. | Joel Sherrill | 1998-03-14 | 2 | -0/+12 |
* | Added summary chapter. | Joel Sherrill | 1998-03-14 | 1 | -2/+11 |
* | New file. | Joel Sherrill | 1998-03-14 | 1 | -0/+33 |
* | Added functions from POSIX standard. | Joel Sherrill | 1998-03-14 | 7 | -0/+295 |
* | Added functions from POSIX standard. | Joel Sherrill | 1998-03-14 | 3 | -2/+116 |
* | Added copyright header | Joel Sherrill | 1998-03-14 | 1 | -0/+8 |
* | Added functions from POSIX standard. | Joel Sherrill | 1998-03-14 | 7 | -7/+686 |
* | Outline complete and apparently correct. | Joel Sherrill | 1998-03-11 | 16 | -152/+156 |
* | Baseline | Joel Sherrill | 1998-03-11 | 21 | -0/+754 |
* | Corrected to indicate test cases which were skipped. | Joel Sherrill | 1998-03-03 | 2 | -4/+4 |
* | Changed to remove warning. | Joel Sherrill | 1998-03-03 | 1 | -5/+3 |
* | Switched from "extern int errno" to "#include <errno.h>". | Joel Sherrill | 1998-03-03 | 12 | -12/+12 |
* | Removed use of dc. David Fiddes reported that this is part of the | Joel Sherrill | 1998-02-27 | 2 | -2/+34 |
| | | | | | GNU tool bc which is not always installed under Linux and seldom present under non-UNIX environments like Win32. | ||||
* | Patch from Eric Norum: | Joel Sherrill | 1998-02-23 | 1 | -1/+1 |
| | | | | | | | | | Here's another small patch. The changes to socket.h are to provide some definitions that UNIX BSD socket programmers expect. The memcpy.c contains a memcpy routine optimized for the CPU32+. When I run the ttcp benchmark with this routine I get host->68360 transfers around 165 kbytes/sec (about a 25% improvement) and 68360->host transfers of around 290 kbytes/sec (about a 50% improvement). | ||||
* | Modified to make it possible for an ISR to return a mutex which did | Joel Sherrill | 1998-02-20 | 2 | -4/+40 |
| | | | | not use priority ceiling or priority inheritance protocols. |
