* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 47 | -55/+55 |
* | 2007-01-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-18 | 2 | -4/+8 |
| | | | | | * custom/csb336.cfg, custom/edb7312.cfg, custom/gba.cfg: CFLAGS_OPTIMIZE_V = -O2. | ||||
* | CFLAGS_OPTIMIZE_V = -O2. | Ralf Corsepius | 2007-01-18 | 3 | -7/+3 |
* | 2007-01-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-18 | 1 | -0/+7 |
| | | | | | | | * custom/eZKit533.cfg: CFLAGS_OPTIMIZE = -O0. * custom/gensh1.cfg, custom/ep1a.cfg, custom/erc32.cfg, custom/erc32nfp.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg, custom/armulator.cfg, custom/gp32.cfg: CFLAGS_OPTIMIZE_V = -O2. | ||||
* | CFLAGS_OPTIMIZE_V = -O2 | Ralf Corsepius | 2007-01-17 | 3 | -3/+3 |
* | CFLAGS_OPTIMIZE_V = -O0 | Ralf Corsepius | 2007-01-17 | 2 | -9/+3 |
* | CFLAGS_OPTIMIZE_V = -O2 | Ralf Corsepius | 2007-01-17 | 4 | -7/+7 |
* | 2007-01-16 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2007-01-17 | 6 | -16/+245 |
| | | | | | | | * vmeUniverse/vmeTsi148.c, vmeUniverse/vmeTsi148.h, * vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h, * vmeUniverse/vme_am_defs.h: Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer. | ||||
* | 2007-01-16 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2007-01-17 | 3 | -1/+91 |
| | | | | | * libi2c/libi2c.c, libi2c/libi2c.h: Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer. | ||||
* | 2007-01-16 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2007-01-17 | 4 | -4/+138 |
| | | | | | | | * libnetworking/rtems/rtems_mii_ioctl.c, * libnetworking/rtems/rtems_mii_ioctl.h, * libnetworking/rtems/rtems_mii_ioctl_kern.c: Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer. | ||||
* | 2007-01-16 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2007-01-17 | 5 | -4/+182 |
| | | | | | | * libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-2b-eeprom.h, * libchip/i2c/i2c-ds1621.c, libchip/i2c/i2c-ds1621.h: Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer. | ||||
* | 2007-01-16 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2007-01-17 | 3 | -3/+95 |
| | | | | | * mpc6xx/mmu/pte121.h, mpc6xx/mmu/pte121.c: Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer. | ||||
* | 2007-01-16 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2007-01-17 | 18 | -30/+769 |
| | | | | | | | | | | | * ep1a/vme/vmeconfig.c, mvme5500/pci/pcifinddevice.c, * mvme5500/startup/pgtbl_activate.c, mvme5500/vectors/bspException.h, * mvme5500/vectors/exceptionhandler.c, mvme5500/vme/VME.h, * mvme5500/vme/vmeconfig.c, score603e/vme/vmeconfig.c, shared/pci/pcifinddevice.c, * shared/startup/pgtbl_activate.c, shared/startup/pgtbl_setup.c, * shared/startup/probeMemEnd.c, shared/startup/sbrk.c, shared/vme/VME.h, * shared/vme/VMEConfig.h, shared/vme/vme_universe.c, shared/vme/vmeconfig.c: Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer. | ||||
* | 2007-01-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-16 | 1 | -0/+4 |
| | | | | * setup.def: newlib-1.15.0. | ||||
* | newlib-1.15.0 | Ralf Corsepius | 2007-01-16 | 1 | -1/+1 |
* | Replace nosrc.rpm with src.rpm | Ralf Corsepius | 2007-01-15 | 1 | -6/+6 |
* | 2007-01-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-15 | 2 | -2/+3 |
| | | | | | * common/rtems.texi.in: Use bugzilla for RTEMSBUGS. Remove RTEMSGNATS. | ||||
* | More tweaks. | Ralf Corsepius | 2007-01-15 | 1 | -12/+12 |
* | More tweaks. | Ralf Corsepius | 2007-01-15 | 2 | -40/+40 |
* | 2007-01-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-15 | 4 | -42/+45 |
| | | | | | * started/binaries.t, started/buildc.t, started/tversions.texi.in: Various update to reflect current toolchains. | ||||
* | 2007-01-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-15 | 1 | -2/+2 |
| | | | | | * configure.ac: Reflect having moved setup.def. Eliminate gcc3*. | ||||
* | 2007-01-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-15 | 1 | -0/+2 |
* | Reflect having moved setup.def. | Ralf Corsepius | 2007-01-15 | 1 | -9/+9 |
* | 2007-01-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-15 | 1 | -0/+4 |
| | | | | * setup.def: New (Formerly in ../scripts). | ||||
* | New (Formerly in ../scripts). | Ralf Corsepius | 2007-01-15 | 1 | -0/+22 |
* | Disable binutils infos. | Ralf Corsepius | 2007-01-12 | 1 | -1/+1 |
* | Add BINUTILS_OPTS += | Ralf Corsepius | 2007-01-12 | 6 | -0/+6 |
* | Bump GCC_RPMREL | Ralf Corsepius | 2007-01-12 | 11 | -12/+12 |
* | Update to gcc-core-4.2.0-rtems4.8-20070112.diff | Ralf Corsepius | 2007-01-12 | 1 | -1/+1 |
* | Remove (Obsolete). | Ralf Corsepius | 2007-01-12 | 2 | -18647/+0 |
* | Update (bfin merged into upstream) | Ralf Corsepius | 2007-01-12 | 1 | -0/+31 |
* | Use gcc-core-4.1.1-rtems4.8-20070102.diff | Ralf Corsepius | 2007-01-12 | 3 | -3/+3 |
* | Upgrade to newlib-1.15.0-rtems4.8-20070110. | Ralf Corsepius | 2007-01-12 | 11 | -11/+11 |
* | Add BINUTILS_OPTS. | Ralf Corsepius | 2007-01-12 | 11 | -0/+11 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2007-01-12 | 11 | -11/+11 |
* | Bump releases. | Ralf Corsepius | 2007-01-10 | 1 | -2/+2 |
* | Rename automake-rtems into automake. | Ralf Corsepius | 2007-01-10 | 2 | -8/+13 |
| | | | | Rename autoconf-rtems into autoconf. | ||||
* | Rename autoconf-rtems into autoconf. | Ralf Corsepius | 2007-01-10 | 2 | -7/+12 |
* | Update bugfix address | Ralf Corsepius | 2007-01-10 | 1 | -2/+1 |
* | Add ECANCELED. | Ralf Corsepius | 2007-01-10 | 1 | -0/+849 |
* | 2007-01-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-01-09 | 2 | -3/+5 |
| | | | | | * libcsupport/src/error.c: rtems_progname is no longer defined in the BSP startup since it never held a meaningful value. | ||||
* | 2007-01-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-08 | 1 | -0/+4 |
| | | | | * acinclude.m4: AC_PREREQ(2.60). | ||||
* | AC_PREREQ(2.60) | Ralf Corsepius | 2007-01-08 | 1 | -1/+1 |
* | 2007-01-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-08 | 2 | -51/+5 |
| | | | | * Makefile.am: Use preinstall.am. | ||||
* | New. | Ralf Corsepius | 2007-01-08 | 1 | -0/+62 |
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 100 | -237/+237 |
* | 2007-01-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-08 | 2 | -1/+5 |
| | | | | * ampolish3: Use MKDIR_P instead of mkdir_p. | ||||
* | Fix CVS-Id | Ralf Corsepius | 2007-01-08 | 0 | -0/+0 |
* | 2007-01-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-08 | 2 | -3/+5 |
| | | | | * Makefile.am: Remove scripts/. | ||||
* | Remove (Obsolete). | Ralf Corsepius | 2007-01-08 | 72 | -5645/+0 |
