PR 1759/cpukit
* Makefile.am, configure.ac: Add test to use some pthread calls with
Classic Tasks.
* psxclassic01/.cvsignore, psxclassic01/Makefile.am,
psxclassic01/init.c, psxclassic01/psxclassic01.doc,
psxclassic01/psxclassic01.scn: New files.
* score/include/rtems/score/schedulerpriority.h: Enqueue first entry
said enqueue. Caught while running coverage.
* libmisc/cpuuse/cpuusagereport.c: Fix calculation in case a thread
dispatch happends in the meantime. The percent values will not sum up
to one hundred percent.
* include/rtems/irq-extension.h: Documentation.
* libmisc/monitor/mon-prmisc.c: Fix for multiprocessing configuration.
* Makefile.am, configure.ac: Move file generation into Makefile.
* Makefile.inc.in: Set PROJECT_ROOT = @pkgdatadir@.
* Makefile.am: Install *.cfgs into $(pkgdatadir)/make.
* aclocal/rtems-top.m4: Add pkgdatadir.
* configure.ac: Remove dead code.
PR 1753/misc:
* host.cfg.in: Remove RTEMS_HOST.
Override pkgdatadir to $(datadir)/rtems$_RTEMS_API.
* Makefile.am: Install make/Templates to pkgdatadir.
PR 1754/misc:
* host.cfg.in: Remove GCCSED.
* timer/timer.c: Retry up to 5 times when the calibration loop fails.
PR 1752/doc
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/cpu_supplement.texi: Remove TI C4x CPU Supplement
chapter.
* cpu_supplement/tic4x.t: Removed.
* ada_user/Makefile.am: Add ObjectId pdf files.
* Makefile.am: Merge-in make/Makefile.am.
* configure.ac: Reflect change above.
* Makefile.am: Remove (merged into ../Makefile.am).
* compilers/gcc-target-default.cfg: Remove (Unused).
* Makefile.am: Reflect change above.
* compilers/gcc-no_bsp.cfg: Remove (Unused).
* Makefile.maint, aclocal/rpm.m4, aclocal/rtems-top.m4,
aclocal/version.m4: Rename RTEMS_API into _RTEMS_API.
* configure.ac: Rename RTEMS_API into _RTEMS_API.
* aclocal/rtems-top.m4, aclocal/version.m4:
* aclocal/env-rtemsbsp.m4, aclocal/rtems-top.m4, aclocal/version.m4:
PR 1738/bsps
* clock/clock.c, include/bsp.h, network/network.c: system clock driver
programs the PIT w/o assuming the CPU clock frequency being a power
of two.
PR 1744/doc
* user/clock.t: rtems_clock_time_value type uses changed to struct
timeval.
PR 1751/bsps
* start/start.S: Fix typo which was not caught by binutils prior to a
recent bug fix.
PR 1748/bsps
* clock/ckinit.c, include/leon.h: When the clock tick generates an
interrupt WHILE we have interrupts disabled doing a get TOD or
uptime, the get nanoseconds handler was returning a bogusly large
number.
PR 1748/bsps
* clock/ckinit.c: When the clock tick generates an interrupt WHILE we
have interrupts disabled doing a get TOD or uptime, the get
nanoseconds handler was returning a bogusly large number.
* bootstrap: Add -g option.
Switch default to autoreconf.
* sapi/include/confdefs.h: Typos.
PR 1750/bsps
* console/erc32_console.c, make/custom/erc32.cfg: The new console
driver did not support polled mode. It also had a bug in which it
could lose a transmitter interrupt.
* libcsupport/src/mknod.c, libfs/src/rfs/rtems-rfs-inode.c: PR
1749. Fix the incorrect handling of the file type in the mode
value to reject invalid types as per the standard.
* libnetworking/netinet/if_ether.c,
libnetworking/netinet/in.c,
libnetworking/netinet/in_pcb.c,
libnetworking/netinet/in_pcb.h,
libnetworking/netinet/in_proto.c,
libnetworking/netinet/in_rmx.c,
libnetworking/netinet/in_var.h,
libnetworking/netinet/ip_divert.c,
libnetworking/netinet/ip_fw.c,
libnetworking/netinet/ip_mroute.c,
libnetworking/netinet/ip_output.c,
libnetworking/netinet/raw_ip.c,
libnetworking/netinet/tcp_input.c,
libnetworking/netinet/tcp_output.c,
libnetworking/netinet/tcp_subr.c,
libnetworking/netinet/tcp_timer.c,
libnetworking/netinet/tcp_usrreq.c,
libnetworking/netinet/udp_usrreq.c:
Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h.
* libnetworking/rtems/rtems_showicmpstat.c,
libnetworking/rtems/rtems_showifstat.c,
libnetworking/rtems/rtems_showipstat.c,
libnetworking/rtems/rtems_showmbuf.c,
libnetworking/rtems/rtems_showroute.c,
libnetworking/rtems/rtems_showtcpstat.c,
libnetworking/rtems/rtems_showudpstat.c:
* libnetworking/kern/kern_subr.c, libnetworking/kern/kern_sysctl.c,
libnetworking/kern/uipc_socket.c, libnetworking/kern/uipc_socket2.c:
* libnetworking/net/if.c, libnetworking/net/if.h,
libnetworking/net/if_media.h, libnetworking/net/if_var.h,
libnetworking/net/raw_cb.c, libnetworking/net/raw_cb.h,
libnetworking/net/raw_usrreq.c, libnetworking/net/route.c,
libnetworking/net/rtsock.c:
* libnetworking/sys/mount.h, libnetworking/sys/socketvar.h,
libnetworking/sys/sysctl.h:
* configure.ac: Rework checks for mandated headers tar.h,
errno.h, sched.h, sys/cdefs.h, sys/queue.h.
* configure.ac: Remove unused AM_CONDITIONAL([NEED_SYS_CDEFS_H]).
Remove unused AM_CONDITIONAL([NEED_SYS_QUEUE_H]).
* acinclude.m4: Regenerate (Reflect the i386ex and tx_386ex BSP have
been removed.).
* score/src/heapfree.c, score/src/heapresizeblock.c: PR 1746. Move
protection block checks to after the block address has been
checked as a valid heap address. Add a special case in the heap
free for a NULL address.
* sched_cpu/rtems/score/cpuopts.h: Bump to 4.10.99.0
* setup.def, shell/preface.texi: Bump to 4.10.99.0
