* Removing Makefile.in and adding Makefile.am. These were missed in conversionJoel Sherrill1999-12-2181-7550/+1096
| | | | to automake by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Patch rtems-rc-19991203-10.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-2113-20/+24
| | | | | | | | | | which fixes a couple of bugs in RTEMS's old style Makefile.ins, which apparently were introduced by moving the start directories and not having adapted the Makefile.ins. To apply: patch -p1 < rtems-rc-19991203-10.diff
* Patch rtems-rc-19991203-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-2110-63/+4
| | | | | | | | | which ontains all what was left over from the other patches (Primarily minor configuration cleanups). To apply: patch -p1 < rtems-rc-19991203-9.diff ./bootstrap
* Patch rtems-rc-19991203-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-2156-392/+0
| | | | | | | | | which does minor cleanup for Makefile.ams below mptests, which only removes some bogus comments from the Makefile.ams. To apply: patch -p1 < rtems-rc-19991203-8.diff ./bootstrap
* Patch rtems-rc-19991203-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-2153-750/+6212
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which adds partial automake support to libcpu/<cpu>/*. Until now I have only implemented full automake support for the sh (my demonstration example :) and the i386 (inevitiable for structural reasons of this subdirectory). For all other cpus only their toplevel directories (exception: powerpc), include subdirectories and a few selected subdirectories have been converted to automake. I did this on purpose, because add automake support to each subdirectory requires individual adaptations which to be tested individually. Additionally the weirdnesses of the powerpc subdirectories hit again, esp. some powerpc cpu-models * install files to $(PROJECT_INCLUDE)/<cpu-model>/ while others install them to $(PROJECT_INCLUDE)/ * the scheme used to configure libcpu/powerpc/ is difficult to implement using automake, therefore this subdirectory still is configured by autoconf (The one out of an unlimited set selection scheme hits again :), though powerpc/*/* subdirectories already apply automake. The patch also reveils structural weaknesses in RTEMS: E.g. There seem to exist at least 5 different general schemes: * Not using libcpu at all (eg. i960) * Strictly tree-style a libcpu/<cpu-variant>/* (eg. m68k, sh) * Flat libcpu directory layout with cpu-variants merged into sources or not destinguishing cpu-variants (i386) * Not supporting variants with deep source tree (sparc, hppa, mips64orion) * Woven directory structure with shared directories (powerpc) I regret having to say this, but from my POV this means, that there doesn't exist a general implementation scheme for libcpu at all. To apply: rm -rf ./c/src/lib/libcpu/i386/wrapup rm -rf ./c/src/lib/libcpu/mips64orion/include rm -rf ./c/src/lib/libcpu/powerpc/ppc403/include patch -p1 < rtems-rc-19991203-7.diff ./bootstrap
* Made prototype of ChapReceiveSuccess and ChapReceiveFailure match.Joel Sherrill1999-12-212-4/+4
* Patch rtems-rc-19991203-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-213-123/+0
* Patch rtems-rc-19991203-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-215-40/+40
| | | | | | | | | | | which fixes a nasty dependency bug in optman/Makefile.am. Those directories have been build twice before, i.e. re-running make after having built rtems before, was rebuilding the files in optman/ directories. To apply: patch -p1 < rtems-rc-19991203-6.diff ./bootstrap
* Patch rtems-rc-19991203-5.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-218-174/+256
| | | | | which cleans up and merges some Hitachi SH-2 modifications from John Mills <jmills@tga.com>.
* Modifications to avoid having the size of the Buffer_addresses arrayJoel Sherrill1999-12-202-16/+32
| | | | too small when OPERATION_COUNT is less than 10.
* Spelling error corrected.Joel Sherrill1999-12-161-1/+1
* More warnings removed after email with Emmanuel Raguet.Joel Sherrill1999-12-141-3/+2
* Patch from Eric Norum <eric@cls.usask.ca> to change to gen68360 clock handling.Joel Sherrill1999-12-131-30/+56
| | | | | | | | | I got tired of having strange clock rates (e.g. #define CONFIGURE_MICROSECONDS_PER_TICK 52489) and drifting times-of-day with the gen68360 BSP so I changed the way the programmable-interval clock interrupt works. The new version will have some jitter in the intervals between individual calls to the rtems_clock_tick routine, but the long-term average will match the CONFIGURE_MICROSECONDS_PER_TICK
* Removed warnings.Joel Sherrill1999-12-1313-13/+22
* Warning removal patch from Philip A. Prindeville <philipp@zembu.com>.Joel Sherrill1999-12-139-22/+26
* Patch rtems-19991203.sh2.diff from John M. Mills <jmills@tga.com> whichJoel Sherrill1999-12-132-2/+2
| | | | | | | | | | fixes some problems: I found the problem which prevented opening 'dev/sci1' (the default console) with the 'gensh2' (sh7045) BSP. Both SCI ports were being initialized against the same minor device number: '0'. When I tried to open minor-device '1', it naturally crashed. Fixing that one value in the 'sci_device[]' array solved the problem and allowed 'hello.exe' to run.
* *** empty log message ***Joel Sherrill1999-12-131-4/+4
* Patch from Silverio Diquigiovanni <silverio.di@qem.it> to correctJoel Sherrill1999-12-132-2/+2
| | | | | TPC values. Reviewed by Ralf Corsepius <corsepiu@faw.uni-ulm.de> who originally submitted the file.
* Patch from Eric Norum <eric@cls.usask.ca> to make the NTP handler a littleJoel Sherrill1999-12-133-3/+3
| | | | more flexible about the error status returned from a timeout.
* Patch rtems-rc-19991203-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-132-0/+40
| | | | which adds automake support to libbsp/bare.
* Patch from Jepsen Hans Peter <hans_peter_jepsen@Danfoss.com> toJoel Sherrill1999-12-132-2/+2
| | | | use correct ifdef conditional (__GNUC__ not __GCC__).
* Correction from Eric Norum for timeout in TFTP driver following bugJoel Sherrill1999-12-133-6/+9
| | | | | | | | | report by Nick.SIMON@syntegra.bt.co.uk: TFTP uses UDP and UDP packets are prime targets for getting dropped when the network gets busy. I want the number of retries quite large in my application. I see that PACKET_REPLY_MILLISECONDS is, in fact, not being used.
* Patch from Eric Norum <eric@cls.usask.ca> to provide more networkJoel Sherrill1999-12-131-4/+7
| | | | | | | | | | | | | | | | | | | | functionality. This puts RTEMS in near compliance with the network functionality defined in the first draft of the EL/IX API. Comments follow: With the attached changes to the libnetworking/libc/Makefile.in, RTEMS provides all the functions listed in section 4.14 of the EL/IX document except: socketpair if_nametoindex if_indextoname if_nameindex if_freenameindex Some of the routines which get information from files may be of limited use unless an application sets up the files somehow (TFTP/untar from host, etc.), but at least RTEMS is pretty much fully buzzword compliant with the networking section of the EL/IX API.
* Patch from Emmanuel Raguet <raguet@crf.canon.fr> to correct some problemsJoel Sherrill1999-12-131-9/+16
| | | | | | | | | | | | | in the dec21140 driver. Comments follow: I have tried to use bootp with the dec21140 driver and I had problems. I have found them - Ethernet address must be known in Attach step (read from the board) - Endian problem for Ethernet address storage. Now it is solved and I can use bootp to obtain the network configuration of the target.
* Patch rtems-rc-19991203-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>"""Joel Sherrill1999-12-132-41/+42
| | | | | which is an adaptation of a patch from Ian Lance Taylor plus a few other changes that should significantly speed up building librtemsall.a.
* Patch rtems-rc-19991203-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-134-82/+43
* Patch rtems-rc-19991203-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-132-4/+11
* Patch rtems-rc-19991203-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-133-64/+30
| | | | to correct the missing part of the mcp750 patch.
* First attempt at adding simple binary semaphore in addition to the currentJoel Sherrill1999-12-1325-36/+547
| | | | | "mutex" and counting semaphore. This is at the request of Eric Norum and his EPICS porting effort.
* Corrected order of output.Joel Sherrill1999-12-132-2/+2
* Added RTEMS_IO_ERROR.Joel Sherrill1999-12-133-0/+3
* Now builds and installs properly.Joel Sherrill1999-12-131-10/+5
* Patch rtems-rc-19991203-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-131-1/+5
| | | | | | | | | | | | | to generalize librdbg for all i386 BSPs. His comments: The patch below generalizes librdbg for all i386 bsps. It is not a complete rewrite, but a minimal invasive attempt to generalization. To apply: mv c/src/librdbg/src/i386/pc386 c/src/librdbg/src/i386/any patch -p1 < patches-rc-19991203-1.diff ./bootstrap
* Patch patches-rc-19991203-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-065-160/+3
| | | | | which makes i386 code available for all BSPs not just pc386. This is correct since the code is really general to all i386 BSPs now.
* changed version to 19991203Joel Sherrill1999-12-030-0/+0
* changed version to 19991203Joel Sherrill1999-12-031-1/+1
* New file.Joel Sherrill1999-12-031-0/+7
* Patch from Aleksey (Quality Quorum <qqi@world.std.com>) to change theJoel Sherrill1999-12-032-6/+46
| | | | | | | | | | | delay loop in this BSP. Here is his response to a question about the patch: Yes, or that other machine has a different chipset with different timing requirements on enabling Gate 20. I am strongly suspecting that it may some how related to the video card I am using (on my old P-75 target it was plain PCI VGA, on my new one it is Diamond Stealth 3D 2000).
* Modem example driver for ppp by Tomasz Domin <dot@comarch.pl> of ComArch SA.Joel Sherrill1999-12-036-0/+3697
| | | | This was used on a mpc823 based system.
* Made to compile on other CPU families.Joel Sherrill1999-12-031-0/+18
* Added dec21140 to Makefile.am.Joel Sherrill1999-12-031-1/+1
* Removed warnings.Joel Sherrill1999-12-031-24/+24
* New file.Joel Sherrill1999-12-032-0/+194
* Added more timing information.Joel Sherrill1999-12-034-0/+418
* New file based on information from <valette@crf.canon.fr>.Joel Sherrill1999-12-032-0/+370
* Modification from Emmanuel Raguet <raguet@crf.canon.fr> to merge theJoel Sherrill1999-12-0312-358/+435
| | | | | | dec21140 drivers from the i386/pc386 and powerpc/mcp750 (all Motorola PowerPC boards) and move the network driver to libchip. This driver should work on all PCI based uses of this chip.
* Patch rtems-rc-19991123-rc-3.diff from Ralf CorsepiusJoel Sherrill1999-12-032-0/+61
| | | | | | | | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de>: The patch below provides * automake support for score/cpu/powerpc * The hack to propagate values from *.cfg to automake configuration * A fix for librdbg/powerpc/mcp750/Makefile.am (Was completely corrupted before) * Fixes some files which apparently where missing in rtems-rc-19991123-rc-2.diff * some minor configuration related patches To apply: rm -rf ./c/src/exec/score/cpu/powerpc/wrap patch -p1 < rtems-rc-19991123-rc-3.diff Attention: c/src/exec/score/cpu/[configure.in|aclocal.m4|configure] should be removed after applying the patch. Modifications had been made to the score/cpu/powerpc directory after the snapshot this was based on. In particular, the mpc750 and other_cpu directories had been renamed to new_exception_processing and old_exception_processing. After this patch was applied, modifications were made to account for this.
* Patch rtems-rc-19991123-rc-3.diff from Ralf CorsepiusJoel Sherrill1999-12-0315-132/+63
* Patch from Rosimildo DaSilva <rdasilva@connecttel.com> for CygwinJoel Sherrill1999-12-031-2/+2
| | | | to consistently use $(EXEEXT).
