* | Added bswap feature. | Joel Sherrill | 1998-08-13 | 2 | -4/+30 |
* | Updated version information. | Joel Sherrill | 1998-08-13 | 1 | -25/+25 |
* | Updated the disk space required. | Joel Sherrill | 1998-08-13 | 1 | -2/+2 |
| | | | | Fixed a typo in the hello world example. | ||||
* | Corrected name of build script and other minor things in the list of | Joel Sherrill | 1998-08-13 | 1 | -9/+13 |
| | | | | | | | | needed tools. Corrected path to patches. Added warning about putting the install point under the build tree. | ||||
* | Added a warning about positioning the INSTALL_POINT under the build | Joel Sherrill | 1998-08-13 | 1 | -0/+4 |
| | | | | tree. | ||||
* | Added RTEMS.src stanza dn commands to run it. | Joel Sherrill | 1998-08-13 | 2 | -2/+7 |
* | Changed settings for RPREFIX and DIRPREFIX. | Joel Sherrill | 1998-08-13 | 1 | -2/+2 |
* | Updated version number | Joel Sherrill | 1998-08-13 | 1 | -1/+1 |
* | Updated to include standard number. | Joel Sherrill | 1998-08-13 | 1 | -4/+7 |
* | Updated. | Joel Sherrill | 1998-08-13 | 1 | -3/+3 |
* | New dates and versions. | Joel Sherrill | 1998-08-13 | 1 | -5/+5 |
* | Changed phone number to reflect new area code. | Joel Sherrill | 1998-08-13 | 1 | -2/+2 |
* | base line -- copied from erc32 | Joel Sherrill | 1998-08-13 | 1 | -0/+193 |
* | Enable TX interrupts only when we need TDAs. | Joel Sherrill | 1998-08-13 | 1 | -1/+0 |
* | Cleaned up some debugging stuff. | Joel Sherrill | 1998-08-13 | 1 | -23/+15 |
| | | | | Redid interrupt handler to read imr/isr once and to write the imr once. | ||||
* | Don't disable the RX/TX on close in polled mode. | Joel Sherrill | 1998-08-13 | 2 | -4/+6 |
| | | | | Fixed a comment. | ||||
* | Per request from Chris Johns <ccj@acm.org>, I added code to detect | Joel Sherrill | 1998-08-13 | 3 | -30/+50 |
| | | | | | when the bare bsp was enabled without setting both --enable-cpu-model and --enable-cpu-cflags. | ||||
* | Patch from Chris Johns <ccj@acm.org> to change the way in which the initial | Joel Sherrill | 1998-08-13 | 1 | -2/+5 |
| | | | | stack pointers are saved. | ||||
* | Patch from Chris Johns <ccj@acm.org>. Comments follow: | Joel Sherrill | 1998-08-13 | 1 | -0/+19 |
| | | | | | | | | | | | Here is a small patch which allows the m68060 to be used. I have not tested the FP switching stuff which we know is broken. This is taken against the libchip snapshot but should merge without problems. If you have any problems please let me know. There are other smaller issues such as superscalar enable and cache control which I have not addressed yet. They are different to all other m68k processors. These can wait IMO. | ||||
* | fixed spacing | Joel Sherrill | 1998-08-13 | 1 | -16/+14 |
* | Removed spurious prints and cleaned up XXX. | Joel Sherrill | 1998-08-12 | 1 | -11/+10 |
* | Added more debug information. There are probably debug prints left in. | Joel Sherrill | 1998-08-12 | 1 | -24/+53 |
| | | | | | Fixed one important bug. After wrapping the RX Descriptors all had the EOL bit set which resulted in everything slowing down massively. | ||||
* | Updated the description section of the cfg_open and cfg_read routines | Wade A Smith | 1998-08-12 | 1 | -20/+155 |
* | Fixed bug where the last link of the RDA was not initialized properly. | Joel Sherrill | 1998-08-12 | 1 | -15/+30 |
* | Updated the description section of the admin_shutdown routine. | Wade A Smith | 1998-08-11 | 1 | -1/+14 |
* | Updated the description section for the dump_setpath routine. | Wade A Smith | 1998-08-11 | 1 | -2/+16 |
* | Updated the description section for the following routines: | Wade A Smith | 1998-08-11 | 1 | -7/+228 |
| | | | | | | log_close, log_seek, log_severity_before, log_facilityemptyset, log_facilityfillset, log_facilityaddset, log_facilitydelset, and log_facilityismember | ||||
* | Updated the Description section for the following routines: | Wade A Smith | 1998-08-11 | 1 | -2/+75 |
| | | | | log_notify, log_read, log_open, and log_write. | ||||
* | Added SONIC_DEBUG_DESCRIPTORS and changed debug level. | Joel Sherrill | 1998-08-11 | 1 | -3/+11 |
* | Survives 16-20 packets. Appears to be ok on TX buffer management. | Joel Sherrill | 1998-08-10 | 1 | -11/+16 |
| | | | | Problem appears to be on the RX buffer initialization side. | ||||
* | Update the description section for the log_write function. | Wade A Smith | 1998-08-10 | 1 | -3/+38 |
* | Added prints | Joel Sherrill | 1998-08-10 | 1 | -1/+2 |
* | Updated the Description section for the Configuration Space Management | Wade A Smith | 1998-08-10 | 1 | -93/+224 |
| | | | | routines. | ||||
* | Can now reply to multiple successive pings successfully without being in | Joel Sherrill | 1998-08-10 | 2 | -29/+22 |
| | | | | | | promiscuous mode. It still dies somewhere between 16 and 20 pings. | ||||
* | replies to ping -- forced into prosmiscuous mode | Joel Sherrill | 1998-08-10 | 1 | -13/+21 |
* | Added to the description section of the Configuration Space Operations. | Wade A Smith | 1998-08-10 | 1 | -9/+77 |
* | Documented the admin_shutdown function | Wade A Smith | 1998-08-10 | 1 | -4/+13 |
* | Documented the following Event Logging routines: | Wade A Smith | 1998-08-10 | 1 | -48/+172 |
| | | | | | | log_write, log_open, log_read, log_notify, log_close, log_seek, log_severity_before, log_facilityemptyset, log_facilityfillset, log_facilityaddset, log_facilitydelset, and log_facilityismember | ||||
* | Documented the dump_setpath function. | Wade A Smith | 1998-08-10 | 1 | -4/+22 |
* | Added documentation for the following Configuration Space Operations: | Wade A Smith | 1998-08-10 | 1 | -46/+342 |
| | | | | | cfg_mount, cfg_unmount, cfg_mknod, cfg_set, cfg_get, cfg_link, cfg_unlink, cfg_open, cfg_read, cfg_children, cfg_mark, and cfg_close | ||||
* | Reordered some stuff. | Joel Sherrill | 1998-08-08 | 1 | -7/+10 |
* | changed version to 980808 | Joel Sherrill | 1998-08-08 | 2 | -2/+2 |
* | Corrected spacing. | Joel Sherrill | 1998-08-08 | 1 | -1/+1 |
* | Changed debug level. | Joel Sherrill | 1998-08-08 | 2 | -36/+96 |
| | | | | | | | | | | | | | | | | Moved CAM Descriptor types to sonic.h. CAM memory is now malloced to insure it shares the same upper address bits. Removed increment of RX interrupt count on TX interrupt path. Added SONIC_DEBUG_FRAGMENTS and SONIC_DEBUG_CAM conditionals. Fixed bugs in fragment manipulation. First bug was that the pad overwrote the last fragment. The second bug was that the link information overwrote the size of the last fragment. Rewrote initialization of TDA to simplify it. | ||||
* | changed version to 9800808 | Joel Sherrill | 1998-08-08 | 2 | -2/+2 |
* | Removed SonicRegisters structure since we now use register indices | Joel Sherrill | 1998-08-06 | 1 | -83/+15 |
| | | | | | | | | and access routines. Added revision constants. Added in_use and EOL field values. | ||||
* | Enabled specific types of debug info. | Joel Sherrill | 1998-08-06 | 1 | -31/+55 |
| | | | | | | | | | | | | Added pointer to RDA to sonic structure. Added macro names for values used in the in_use field of RDA entries. Rewrote the RX Descriptor Area initialization loop. Added a check to barf if this is a Rev B sonic chip. Enabled check that the CAM was properly loaded. | ||||
* | Changed debug enable macros to support individually enabling different | Joel Sherrill | 1998-08-06 | 1 | -15/+30 |
| | | | | | | | types of debug information. Removed call to rtems_panic which was based on checking a variable which was no longer being set. | ||||
* | Card Resource Register was a 16-bit register not a 32-bit one. | Joel Sherrill | 1998-08-06 | 5 | -28/+36 |
| | | | | Used existing constants for bits on the register. | ||||
* | Added support for the Card Resource Register. The new probe routines | Joel Sherrill | 1998-08-06 | 5 | -8/+107 |
| | | | | | check for the presence of the DUART, SCC, and RTC. The SONIC check needs to be added in the future as the network driver is libchip'ed. |
