* Removed dependency on bsp.h.Joel Sherrill1999-02-241-1/+3
* Corrected name of file.Joel Sherrill1999-02-241-1/+1
* Changed to include FPSP in library.Joel Sherrill1999-02-241-0/+2
* Changed from $(INSTALL) to $(INSTALL_CHANGE).Joel Sherrill1999-02-242-3/+3
* Corrected Makefile.in to account for placement of include files.Joel Sherrill1999-02-244-4/+4
* Corrected name of constant so this would compile.Joel Sherrill1999-02-242-2/+2
* Accidentally moved.Joel Sherrill1999-02-194-2101/+0
* Moved back up in tree.Joel Sherrill1999-02-1912-0/+6303
* Accidentally moved erc32.hJoel Sherrill1999-02-191-521/+0
* Moved erc32.h back up in tree.Joel Sherrill1999-02-192-0/+1042
* Moved asm.h back up in tree.Joel Sherrill1999-02-1922-0/+2698
* Accidentally moved asm.hJoel Sherrill1999-02-198-1143/+0
* Moved to proper rtems/scoreJoel Sherrill1999-02-1950-6783/+712
* Added new PowerPC boards.Joel Sherrill1999-02-191-0/+6
* Enhanced to support -qrtems_debug.Joel Sherrill1999-02-191-3/+9
* BSP for Vista Score603e added.Joel Sherrill1999-02-1945-0/+6623
* Updated to reflect addition of new BSPs.Joel Sherrill1999-02-182-0/+9
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1999-02-181-6/+6
| | | | | | | | | Here is a patch which slightly improves the i386 interrupt handling macros. These macros were written to use both input and output parameters, which is not necessary. This patch changes them to use only an input or output parameter, as appropriate. It also changes the constraints to permit the interrupt level to be loaded directly in and out of memory, rather than always requiring a register.
* Renamed network to wd8003.Joel Sherrill1999-02-184-4/+4
* Patch from Emmanuel Raguet <raguet@crf.canon.fr>. Missed adding this fileJoel Sherrill1999-02-181-0/+540
| | | | earlier to CVS.
* Added INSTALL rule to Makefile.Joel Sherrill1999-02-189-3/+19
* Patch from Emmanuel RAGUET <raguet@crf.canon.fr> to add filesJoel Sherrill1999-02-185-8/+942
| | | | | | that were accidentally not committed earlier. The DECNet driver is being added as its own directory to avoid forcing the driver to have to pull in the complete set of network drivers.
* Added comments.Joel Sherrill1999-02-181-0/+20
* Added NE2000 Driver from Ian Lance Taylor <ian@airs.com>. Comments:Joel Sherrill1999-02-184-2/+998
| | | | | | | | | | | | | | | | | | | | | | Both the ne2000 and the wd80x3 are based on the National Semiconductor 8390 chip, so there is a fair amount of overlap between the two drivers. It would be possible in principle to combine some code into a separate set of subroutines called by both. In fact, the drivers in both OpenBSD and Linux work this way. I didn't bother, because for the relatively simple drivers used by RTEMS, the overlap is not especially large, and any reasonable use of subroutines would lead to slightly less efficient code. This ne2000 driver uses two transmit buffers. While one packet is being transmitted over the Ethernet, RTEMS will upload another. Since uploading a packet to the ne2000 is rather slow, I don't think there is any point to having more than two transmit buffers. However, the code does make it possible, by changing NE_TX_BUFS, although that would of course reduce the number of receive buffers. I suspect that the wd80x3 driver would benefit slightly from copying the multiple transmit buffer code. However, I have no way to test that.
* Fixed top of file.Joel Sherrill1999-02-181-1/+3
* MVME167 BSP submitted by Charles Gauthier <Charles.Gauthier@iit.nrc.ca>.Joel Sherrill1999-02-1825-0/+4077
* Missed this file in the merge.Joel Sherrill1999-02-181-0/+412
* Regenerated.Joel Sherrill1999-02-181-106/+120
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-18662-368/+1680
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-18121-1/+30521
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | > 4) rtems-rc-19990202-0.diff /reorg-score-cpu.sh > > reorg-score-cpu.sh reorganizes the cpu/<cpu>/* subdirectories in a > similar manner than previous reorg scripts did. rtems-rc-19990202-0.diff > contains the diffs after reorg-score-cpu.sh has been run on a > rtems-19981215 snapshot + my patches up to rtems-rc-19990131-2.diff. > > This patch is rather nasty and may break something. However, I've tested > it for about 10 different target/bsp pairs and believe to have shaken > out most bugs. I wonder about the following .h files that were not moved: a29k/asm.h a29k/cpu_asm.h i386/asm.h i960/asm.h m68k/asm.h m68k/m68302.h m68k/m68360.h m68k/qsm.h m68k/sim.h mips64orion/asm.h mips64orion/cpu_asm.h mips64orion/mips64orion.h no_cpu/asm.h no_cpu/cpu_asm.h powerpc/asm.h powerpc/mpc860.h sh/asm.h sparc/asm.h sparc/erc32.h
* Another part of automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-02-181-0/+72
* Yet another part of automake VI from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-1861-18081/+24
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-1813-82/+24
| | | | | | | | | | | | | | | | | | > 3) rtems-rc-19990131-2.diff > > This patch removes generating bsp_specs from leaf.cfg and generates > bsp_specs from inside of c/Makefile instead. > > The motivation behind this patch is to avoid "polluting" Makefiles by > unneccessary rules from included Makefile-fragments (*.cfg-files) and > try to handle files by explicit rules in Makefiles instead (FYI: > automake-1.4 physically includes Makefile fragments at the time > automake is run, not at the time make is run as RTEMS Makefile.ins do > now) > > Nevertheless, this patch is rather uncritical, almost cosmetical - If > you don't like it, then dump it ;-, however I doubt that subsequent > patches will apply then ;-.
* Added rejected patch from automake VI from Ralf Corsepius.Joel Sherrill1999-02-182-12/+18
* Part of automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-186-105/+59
| | | | | | | | | | | | | | > 2) rtems-rc-19990131-1.diff > > Rework of compilers/*.cfg files (esp. gcc-target-default.cfg) to adapt > the flags/makefile variables to automake and make standards (cf. > make.info - implicit rules/variables). > > This patch is rather risky and may probably break things, but is an > essential step towards automake. > > FWIW: It also reverts the i386-ASMFLAGS/ASFLAGS-patch, which was wrong, > as I had to experience ;-.
* Part of automake VI Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1999-02-1815-20/+43
| | | | | | | > Adds variables to the custom/*cfg files to specify the location of > tools. The purpose is to remove hard-coded paths from the Makefiles. > > In later steps this eases moving the tools to other locations.
* Part of the targopts.h change in generation patch from Ralf CorsepiusJoel Sherrill1999-02-182-53/+6
* Corrected.Joel Sherrill1999-02-181-36/+0
* Readded.Joel Sherrill1999-02-181-0/+14
* Should have been removed earlier.Joel Sherrill1999-02-1843-5878/+0
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-1812-69/+60
| | | | | | | | | | | | | This patch removes generation of targopts.h from leaf.cfg and generates it in location at score/include/rtems/score instead. To achieve this: * all rules in other Makefile.ins which have accessed targopts.h have been removed. * c/Makefile.in has been modified to generate the directories before doing anything else. I.e. to ensure the directories exist before any preinstall rule fires (This part is a bit kludgy, but it seems to work. Please check if the interaction with libhwapi still works).
* ./clock/Makefile.in,vJoel Sherrill1999-02-1869-0/+13360
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | ./clock/clock.c,v ./console/Makefile.in,v ./console/config.c,v ./console/console.c,v ./console/console.h,v ./console/debugio.c,v ./console/i8042.c,v ./console/i8042_p.h,v ./console/i8042vga.c,v ./console/i8042vga.h,v ./console/ns16550.c,v ./console/ns16550.h,v ./console/ns16550_p.h,v ./console/ns16550cfg.c,v ./console/ns16550cfg.h,v ./console/vga.c,v ./console/vga_p.h,v ./console/z85c30.c,v ./console/z85c30.h,v ./console/z85c30_p.h,v ./console/z85c30cfg.c,v ./console/z85c30cfg.h,v ./include/Makefile.in,v ./include/bsp.h,v ./include/chain.h,v ./include/coverhd.h,v ./include/extisrdrv.h,v ./include/nvram.h,v ./include/pci.h,v ./include/tod.h,v ./network/Makefile.in,v ./network/amd79c970.c,v ./network/amd79c970.h,v ./nvram/Makefile.in,v ./nvram/ds1385.h,v ./nvram/mk48t18.h,v ./nvram/nvram.c,v ./nvram/prepnvr.h,v ./nvram/stk11c68.h,v ./pci/Makefile.in,v ./pci/pci.c,v ./start/Makefile.in,v ./start/start.s,v ./startup/Makefile.in,v ./startup/bspclean.c,v ./startup/bspstart.c,v ./startup/bsptrap.s,v ./startup/device-tree,v ./startup/genpvec.c,v ./startup/linkcmds,v ./startup/rtems-ctor.cc,v ./startup/sbrk.c,v ./startup/setvec.c,v ./startup/spurious.c,v ./startup/swap.c,v ./timer/Makefile.in,v ./timer/timer.c,v ./tod/Makefile.in,v ./tod/cmos.h,v ./tod/tod.c,v ./universe/Makefile.in,v ./universe/universe.c,v ./vectors/Makefile.in,v ./vectors/README,v ./vectors/align_h.s,v ./vectors/vectors.s,v ./wrapup/Makefile.in,v ./Makefile.in,v ./README,v ./STATUS,v ./bsp_specs,v
* ./clock/Makefile.in,vJoel Sherrill1999-02-181-0/+114
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | ./clock/clock.c,v ./console/Makefile.in,v ./console/config.c,v ./console/console.c,v ./console/console.h,v ./console/debugio.c,v ./console/i8042.c,v ./console/i8042_p.h,v ./console/i8042vga.c,v./console/i8042vga.h,v ./console/ns16550.c,v ./console/ns16550.h,v ./console/ns16550_p.h,v ./console/ns16550cfg.c,v ./console/ns16550cfg.h,v ./console/vga.c,v ./console/vga_p.h,v ./console/z85c30.c,v ./console/z85c30.h,v ./console/z85c30_p.h,v ./console/z85c30cfg.c,v ./console/z85c30cfg.h,v ./include/Makefile.in,v ./include/bsp.h,v ./include/chain.h,v ./include/coverhd.h,v ./include/extisrdrv.h,v ./include/nvram.h,v ./include/pci.h,v ./include/tod.h,v ./network/Makefile.in,v ./network/amd79c970.c,v ./network/amd79c970.h,v ./nvram/Makefile.in,v ./nvram/ds1385.h,v ./nvram/mk48t18.h,v ./nvram/nvram.c,v ./nvram/prepnvr.h,v ./nvram/stk11c68.h,v ./pci/Makefile.in,v ./pci/pci.c,v ./start/Makefile.in,v ./start/start.s,v ./startup/Makefile.in,v ./startup/bspclean.c,v ./startup/bspstart.c,v ./startup/bsptrap.s,v ./startup/device-tree,v ./startup/genpvec.c,v ./startup/linkcmds,v ./startup/rtems-ctor.cc,v ./startup/sbrk.c,v ./startup/setvec.c,v ./startup/spurious.c,v ./startup/swap.c,v ./timer/Makefile.in,v ./timer/timer.c,v ./tod/Makefile.in,v ./tod/cmos.h,v ./tod/tod.c,v ./universe/Makefile.in,v ./universe/universe.c,v ./vectors/Makefile.in,v ./vectors/README,v ./vectors/align_h.s,v ./vectors/vectors.s,v ./wrapup/Makefile.in,v ./Makefile.in,v ./README,v ./STATUS,v ./bsp_specs,v
* Should have been removed from cvs early.Joel Sherrill1999-02-1831-5253/+0
* Patch from Emmanuel Raguet <raguet@crf.canon.fr>:Joel Sherrill1999-02-187-4/+201
| | | | | | | You will find enclosed a patch which contains, for Intel PC386 target : - an Ethernet driver for DEC21140 device based boards. - a simple cache management with paging mechanism.
* GLobal reentrancy structure is now dynamically initialized.Joel Sherrill1999-02-183-3/+6
* Added CVS Id string.Joel Sherrill1999-02-181-0/+4
* Added or corrected CVS Id strings.Joel Sherrill1999-02-187-5/+11
* MPC860 support submitted by Jay Monkman <jmonkman@frasca.com>.Joel Sherrill1999-02-184-2/+256
* Jay Monkman <jmonkman@frasca.com> submitted the eth_comm BSP for a PPC860Joel Sherrill1999-02-1741-0/+8989
| | | | based board.
