* README.configure: Reflect requireing autoconf-2.59 and
automake-1.8.
* wrapup/Makefile.am: Reflect changes to shmdr.
* shmdr/addlq.c, shmdr/cnvpkt.c, shmdr/dump.c, shmdr/fatal.c,
shmdr/getlq.c, shmdr/getpkt.c, shmdr/init.c, shmdr/initlq.c,
shmdr/intr.c, shmdr/mpci.h, shmdr/mpisr.c, shmdr/poll.c,
shmdr/README, shmdr/receive.c, shmdr/retpkt.c, shmdr/send.c,
shmdr/setckvec.c, shmdr/shm_driver.h: Remove (Moved to
c/src/libchip/shmdr).
* start/Makefile.am: Eliminate VPATH.
2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bspstart.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Remove shmdr.
2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Use $(mkdir_p) instead of $(mkinstalldirs).
2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use mkdir_p.
Remove dirs from PRE/TMPINSTALL_FILES.
* bsp.am: Replace bsplibdir by project_libdir.
Use mkdir_p instead of mkinstalldirs.
2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Remove project_libdir.
* Makefile.am: Misc. fixes.
* bsp.am: Add project_libdir.
2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bspstart.am: New.
2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Merge-in shared/Makefile.am, shmdr/Makefile.am.
* shared/Makefile.am: Remove.
* shmdir/Makefile.am: Remove.
* bsp.am: Add preinstallation dirstamp support.
2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Remove all-local: $(ARCH).
2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Reworked.
2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Reflect having moved automake/.
* shmdr/Makefile.am: Reflect having moved automake/.
2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
* configure.ac: Remove (Merged into ../../configure.ac).
* Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
2003-03-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Remove AC_CONFIG_AUX_DIR.
2003-02-14 Joel Sherrill <joel@OARcorp.com>
AMD a29k port declared obsolete.
* a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/acinclude.m4,
a29k/configure.ac, a29k/portsw/.cvsignore, a29k/portsw/ChangeLog,
a29k/portsw/Makefile.am, a29k/portsw/README, a29k/portsw/bsp_specs,
a29k/portsw/configure.ac, a29k/portsw/times,
a29k/portsw/console/.cvsignore, a29k/portsw/console/Makefile.am,
a29k/portsw/console/concntl.h, a29k/portsw/console/console.c,
a29k/portsw/console/serial.c, a29k/portsw/console/serial.h,
a29k/portsw/include/.cvsignore, a29k/portsw/include/Makefile.am,
a29k/portsw/include/bsp.h, a29k/portsw/start/.cvsignore,
a29k/portsw/start/Makefile.am, a29k/portsw/start/amd.ah,
a29k/portsw/start/pswmacro.ah, a29k/portsw/start/register.S,
a29k/portsw/start/register.ah, a29k/portsw/start/start.S,
a29k/portsw/startup/.cvsignore, a29k/portsw/startup/Makefile.am,
a29k/portsw/startup/bspclean.c, a29k/portsw/startup/bspstart.c,
a29k/portsw/startup/linkcmds, a29k/portsw/startup/main.c,
a29k/portsw/startup/ramlink, a29k/portsw/startup/romlink,
a29k/portsw/startup/setvec.c, a29k/portsw/wrapup/.cvsignore,
a29k/portsw/wrapup/Makefile.am: Removed.
2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2003-02-03 Joel Sherrill <joel@OARcorp.com>
* shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not
TMPINSTALL_FILES.
2003-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: install mpci.h and shm_driver.h.
Eliminate OBJS.
2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Don't include @RTEMS_BSP@.cfg.
2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Use .$(OBJEXT) instead of .o.
2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/.cvsignore: Remove.
* include/rtems/.cvsignore: Remove.
* include/rtems/score/Makefile.am: Remove.
* include/rtems/score/.cvsignore: Remove.
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
Replace $bspdir with $RTEMS_BSP_FAMILY.
* configure.ac: Remove include/Makefile, include/rtems/Makefile,
include/rtems/score/Makefile (Eliminate targopts.h).
* Makefile.am: Remove include from SUBDIRS (Eliminate targopts.h)
2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Add bsplib_DATA = bsp_specs.
2002-06-25 Joel Sherrill <joel@OARcorp.com>
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue thus adding a directory at the
top shared level.
* shared/gdbstub: New directory.
* configure.ac: Modified to reflect above.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rtems/score/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rtems/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shmdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Add line break, remove comment.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use @subdirs@ instead of RTEMS_LIBBSP_CPU_SUBDIR.
* configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS, remove
2001-09-28 Joel Sherrill <joel@OARcorp.com>
* shared/bootcard.c, shared/main.c: Now call int c_rtems_main()
not main().
2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* shmdr/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make
automake-1.5 happy.
* include/rtems/score/Makefile.am: Use CLEANFILES = to make
automake-1.5 happy.
* bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Fix automake version number in comment.
2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-09-25 Joel Sherrill <joel@OARcorp.com>
* shmdr/shm_driver.h: Added _AM29K entry. May not be correct.
2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Include compile.am
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
* wrapup/Makefile.am: Remove GENERIC_FILES.
* Makefile.am: Add shmdr. Use noinst_DATA instead of TMP_LIBS.
shmdr/setckvec.c, shmdr/shm_driver.h: Copied from libbsp/shmdr.
* mptests.am: Fix typos in previous patch.
* tmtests.am: Add dirstamp support.
* tmitrontests.am: Add dirstamp support.
* mptests.am: Add dirstamp support.
* mptests/mp01/node1/Makefile.am: Eliminate VPATH.
* mptests/mp01/node2/Makefile.am: Eliminate VPATH.
* mptests/mp02/node1/Makefile.am: Eliminate VPATH.
* mptests/mp02/node2/Makefile.am: Eliminate VPATH.
* mptests/mp03/node1/Makefile.am: Eliminate VPATH.
* mptests/mp03/node2/Makefile.am: Eliminate VPATH.
* mptests/mp04/node1/Makefile.am: Eliminate VPATH.
* mptests/mp04/node2/Makefile.am: Eliminate VPATH.
* mptests/mp05/node1/Makefile.am: Eliminate VPATH.
* mptests/mp05/node2/Makefile.am: Eliminate VPATH.
* mptests/mp06/node1/Makefile.am: Eliminate VPATH.
* mptests/mp06/node2/Makefile.am: Eliminate VPATH.
* mptests/mp07/node1/Makefile.am: Eliminate VPATH.
* mptests/mp07/node2/Makefile.am: Eliminate VPATH.
* mptests/mp08/node1/Makefile.am: Eliminate VPATH.
* mptests/mp08/node2/Makefile.am: Eliminate VPATH.
* mptests/mp09/node1/Makefile.am: Eliminate VPATH.
* mptests/mp09/node2/Makefile.am: Eliminate VPATH.
* mptests/mp10/node1/Makefile.am: Eliminate VPATH.
* mptests/mp10/node2/Makefile.am: Eliminate VPATH.
* mptests/mp11/node1/Makefile.am: Eliminate VPATH.
* mptests/mp11/node2/Makefile.am: Eliminate VPATH.
* mptests/mp12/node1/Makefile.am: Eliminate VPATH.
* mptests/mp12/node2/Makefile.am: Eliminate VPATH.
* mptests/mp13/node1/Makefile.am: Eliminate VPATH.
* mptests/mp13/node2/Makefile.am: Eliminate VPATH.
* mptests/mp14/node1/Makefile.am: Eliminate VPATH.
* mptests/mp14/node2/Makefile.am: Eliminate VPATH.
* itrontests.am: Add dirstamp support.
* sptests.am: Add dirstamp support.
* samples.am: Add dirstamp support.
* psxtests.am: Add dirstamp support.
* libtests.am: Add dirstamp support.
* VERSION: Updated to rtems-20031217-test.
* aclocal/version.m4: Updated to rtems-20031217-test.
* release_support: Correct method used to find ChangeLog associated
with the version.m4 files. Keep going until I can get a tarball cut.
* c/src/aclocal/version.m4: Updated to rtems-20031217-test.
* release_support: Use dirname not basedir. Keep going until I
* release_support: New file -- assistant to new cut_release script.
* release_support: Removed -- accidentally added to wrong directory.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am:
Eliminate VPATH.
* shared/Makefile.am: Fix typo in rule to build from cache/%.c.
* tmtests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* tmitrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* sptests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* sample.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* psxtests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* mptests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* libtests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* itrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* automake/compile.am: Use $(mkdir_p) instead of $(mkinstalldirs).
PR 542/filesystem
* include/rtems/libio_.h: Add rtems_libio_iop_to_descriptor macro to
convert iop to the corresponding integer file descriptor.
PR 544/tests
* include/buffer_test_io.h: Various modifications to make tests account
for resources and not print at inappropriate times.
PR 544/tests
* malloctest/system.h, rtmonuse/system.h: Various modifications to make
tests account for resources and not print at inappropriate times.
PR 544/tests
* sp07/Makefile.am, sp07/init.c, sp07/system.h, sp07/task4.c,
sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c,
sp09/system.h, sp19/system.h, sp20/system.h: Various modifications to
make tests account for resources and not print at inappropriate
times.
* sp07/buffered_io.c: New file.
