* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-27104-52/+312
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-2733-26/+114
| | | | | * configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization.
* 2000-10-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-271-1/+1
| | | | * ChangeLog: Corrected previous entry to include configure.in.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-279-5/+27
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-273-1/+39
| | | | | | * automake/multilib.am: New file. * Makefile.am: Update AUTOMAKE_FILES to reflect the contents of the automake/ directory.
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-272-1/+5
| | | | * configure.in: add tests to the GNU canonicalized subdirectories,
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-2712-6/+36
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-276-4/+16
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * itrontests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * libtests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * mptests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * psxtests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sample.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sptests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * tmitrontests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * tmtests.am: Remove DEFS.
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-275-3/+19
| | | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * configure.in: Replace AC_CONFIG_SUBDIRS with RTEMS_CONFIG_BUILD_SUBDIRS.
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-272-1/+6
| | | | | * Makefile.am: Make sure $SHELL inside of Makefiles does not get propagated to the BSP-subdirectories if a user specified CONFIG_SHELL.
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-262-2/+6
| | | | * configure.in: add lib/libcpu to the GNU canonicalized subdirectories,
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-2626-13/+78
| | | | * configure.in: Remove trailing '/'s from setting up RPM_SPECdir.
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-265-5/+9
| | | | | | * configure.in: Remove bogus cfg_subdirs. * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization.
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-262-2/+8
| | | | | * configure.in: add lib to the GNU canonicalized subdirectories, make the lib directory before configuring lib/.
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-2580-40/+240
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-253-3/+12
| | | | | * configure.in, Makefile.am: add exec to the GNU canonicalized subdirectories.
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-2516-8/+48
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-251-1/+1
| | | | | | * configure.in: add librtems++, libnetworking, librpc, librdb, libmisc, and libchip to the GNU canonicalized subdirectories. NOTE: Missed committing as each subdirectory was added (joel).
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-4/+5
| | | | * configure.in: add librtems++ to the GNU canonicalized subdirectories.
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-2/+7
| | | | | * configure.in: add libnetworking, librpc and librdb to the GNU canonicalized subdirectories.
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-256-3/+18
| | | | | * configure.in: add libmisc and libchip to the GNU canonicalized subdirectories.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-251-15/+0
| | | | | | * macros/enable-hwapi.m4: Removed. * aclocal/rtems-top.m4, automake/compile.am, automake/lib.am: A small cleanup step towards gnu-canonicalization.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-2517-211/+29
| | | | | | | | | | | | * libc/ioman.c: Moved to libfs. * libc/Makefile.am: Removed ioman.c as part of moving it to libfs. * libc/base_fs.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific. * libc/libio.h: Removed prototype of IMFS_ops since it should not be in this file. * libc/mount.c: Removed IMFS specific configuration information. * libc/unmount.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-253-2/+11
| | | | | | | * custom/p4600.cfg, custom/p4650.cfg: Commented out RTEMS_CPU definition since this information can be picked up from autoconf generated files. These BSPs are shared by the mips and mips64orion "ports."
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-256-0/+14
| | | | | * psxmount/test.c, psxstat/test.c: Include <imfs.h> to get IMFS_ops. It was formerly incorrectly prototyped in <libio.h>.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-259-24/+144
| | | | | | | * src/imfs/imfs_config.c: New file containing IMFS configuration information split from libc/base_fs.c. * src/imfs/ioman.c: New file. Moved from lib/libc. Missed previously. * src/imfs/Makefile.am: Added imfs_config.c and ioman.c.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-244-6/+147
| | | | | | | | | * Makefile.am, acinclude.m4, configure.in: Introduce GNU canonicalization to libfs/. The approach is currently a bit of a hack as GNU canonicalization does not support the per-BSP build some of the other directories require. As more of the tree is converted, this will become less of an issue.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-247-4/+28
| | | | | | | | * Makefile.am, configure.in: Introduce GNU canonicalization to libfs/. The approach is currently a bit of a hack as GNU canonicalization does not support the per-BSP build some of the other directories require. As more of the tree is converted, this will become less of an issue.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-244-0/+20
* 2000-10-24 Alan Cudmore <alanc@linuxstart.com> andJoel Sherrill2000-10-245-4/+30
| | | | | | | | | | | | | | | | | Joel Sherrill <joel@OARcorp.com> * This is a major reworking of the mips64orion port to use gcc predefines as much as possible and a big push to multilib the mips port. The mips64orion port was copied/renamed to mips to be more like other GNU tools. Alan did most of the technical work of determining how to map old macro names used by the mips64orion port to standard compiler macro definitions. Joel did the merge with CVS magic to keep individual file history and did the BSP modifications. Details follow: * Makefile.am: Made clock and timer subdirectories conditional. * configure.in: Ditto. * clock/clock.S: Switch from using <idtmon.h> to <asm.h>. * clock/gettime.S: Switch from using <idtmon.h> to <asm.h>.
* 2000-10-24 Alan Cudmore <alanc@linuxstart.com> andJoel Sherrill2000-10-245-24/+48
| | | | | | | | | | | | | | | | | | | Joel Sherrill <joel@OARcorp.com> * This is a major reworking of the mips64orion port to use gcc predefines as much as possible and a big push to multilib the mips port. The mips64orion port was copied/renamed to mips to be more like other GNU tools. Alan did most of the technical work of determining how to map old macro names used by the mips64orion port to standard compiler macro definitions. Joel did the merge with CVS magic to keep individual file history and did the BSP modifications. Details follow: * console/led.S: Switch from using <idtmon.h> to <asm.h>. * console/start.S: Switch from using <idtmon.h> to <asm.h>. Added define of PMON stacksize. * console/idtmem.S: Switch from using <idtmon.h> to <asm.h>. Also reworked conditionals to use gcc predefines. * console/idttlb.S: Ditto.
* 2000-10-24 Alan Cudmore <alanc@linuxstart.com> andJoel Sherrill2000-10-2425-562/+1303
| | | | | | | | | | | | | | | | | | | | | | | | | | | Joel Sherrill <joel@OARcorp.com> * This is a major reworking of the mips64orion port to use gcc predefines as much as possible and a big push to multilib the mips port. The mips64orion port was copied/renamed to mips to be more like other GNU tools. Alan did most of the technical work of determining how to map old macro names used by the mips64orion port to standard compiler macro definitions. Joel did the merge with CVS magic to keep individual file history and did the BSP modifications. Details follow: * Makefile.am: idtmon.h in mips64orion port not present. * asm.h: MIPS64ORION replaced with MIPS. Frame setup macros added. * cpu.c: Comments added. * cpu_asm.S: Conditionals changed. MIPS ISA level 1 support added. First attempt at exception/interrupt processing for ISA level 1 and minus any use of IDT/MON added. * idtcpu.h: Conditionals changed to use gcc predefines. * iregdef.h: Ditto. * cpu_asm.h: No real change. Merger required commit. * rtems/Makefile.am: Ditto. * rtems/score/Makefile.am: Ditto. * rtems/score/cpu.h: Change MIPS64ORION to MIPS. * rtems/score/mips64orion.h: Change MIPS64ORION to MIPS. Convert from using RTEMS_CPU_MODEL to gcc predefines to figre things out.
* 2000-10-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-232-2/+11
| | | | * console/serial_mouse.c: Fixed typos introduced by removal of CR/LF.
* 2000-10-20 Rosimildo da Silva <rdasilva@connecttel.com>Joel Sherrill2000-10-202-37/+42
| | | | * console/serial_mouse.c: Added support for changing serial parameters.
* 2000-10-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-202-76/+14
| | | | | | | | | * mpc8xx/console-generic/console-generic.c: Avoid use of BSP definitions and rely on the new routine mbx8xx_console_get_configuration() to get information. This routine was formerly incorrectly called mbx8xx_console_use_maximum_buffer_size(). binding to the exception code.
* 2000-10-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-203-1/+25
| | | | | | | | | * configure.in, Makefile.am: Explicitly specify whether an RTEMS_CPU_MODEL is using old or new exception processing. This is important because when building multilib, you do not know the RTEMS_CPU_MODEL. So everything built in a multilib'ed RTEMS must be independent of the exception model and allow for late binding to the exception code.
* 2000-10-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-204-6/+31
| | | | | * console/console.c: Add mbx8xx_console_get_configuration() which returns either nvram configuration or a static equivalent.
* 2000-10-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-202-1/+6
| | | | | * console/console.c: Invoke BSP_uart_init() with enough arguments now that more communication parameters are settable.
* 2000-10-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-205-0/+23
| | | | * shared/ppc.h: For multilibs, derive PPC_HAS_FPU from _SOFT_FLOAT.
| | | | | * network/dec21140.c: Corrected attach to include "int attach" parameter.
* 2000-10-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-203-1/+17
| | | | | | * include/wd80x3.h: Added file header and logic to prevent multiple inclusions of this file. * wd8003/wd8003.c: Corrected attach to include "int attach" parameter.
