Replace call to removed _Partition_Free() with a call to _Objects_Free().
Update #3373.
End the test on the processor which triggers the test condition. This avoids
endless power down loops in the sparc/leon3 BSP.
- Support all possible descriptors in a select call. Borrowed
from Christain and his mDNS change in LibBSD
- If select (or poll) fails pause for a bit rather than
locking up in a hard loop
- Wait for the tx holding register to empty in a tx flush
The Pi firmware added a wfe(wait for event), the cores 1-3 wait
for the start address being written to the mailbox register, followed
by a SEV poke to the mailbox that acts as a wfe wake-up event.
Closes #3373
confstr() style update
Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com>
This helps to write tests for _Thread_Wait_for_execution_stop().
Rename Thread_Zombie_control in Thread_Zombie_registry.
The _SMP_Fatal() is a no-return function, so the "break" statement is
superfluous.
Online processors have a scheduler assigned.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
Take the interrupt force register into account in all configurations.
Update #3269.
The NULL pointer check for the executing thread was introduced by
commit:
commit be3c257286ad870d8d1a64941cde53fd2d33a633
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Thu Jun 5 11:17:26 2014 +0200
score: Avoid NULL pointer access
Check that the executing thread is not NULL in _Scheduler_Tick(). It
may be NULL in case the processor has an optional scheduler assigned and
the system was not able to start the processor.
However, it is no longer necessary since now the clock interrupt is
distributed to the online processors.
In SMP configurations, on 64-bit architectures use plain atomic
operations to set/get the priority value of a scheduler node. On 32-bit
architectures use an ISR lock. Using a sequence lock has no real
benefit since it uses atomic read-modify-write operations for both the
read and the write lock. Simply use a ticket lock instead so that only
one SMP synchronization primitive is used for everything.
Use the new Priority_Group_order enum instead of a boolean to indicated if a
priority should be inserted as the first or last node into its priority group.
This makes the code more expressive. It is also a bit more efficient since a
branch in _Scheduler_Node_set_priority() is avoided and a simple bitwise or
operation can be used.
The rtems_partition_return_buffer() wrongly accepted which were exactly
at the buffer area end. Use the buffer area limit address for the range
checking.
Close #4490.
Do not continue execution on processors which are not configured to prevent the
use of arbitrary memory for the initialization stack.
the timer_create() method can use CLOCK_MONOTONIC
but there was no test for this.
Also it implements the functionality to
create a CLOCK_MONOTONIC timer and gettime() .
Closes #3888
Cloning under Cygwin turned off executable permission on these
files. This shows them as modified even though they have not
explicitly been touched. Executable permission should not have
been on for these files so this is just a minor clean up.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Place the group into the I/O Manager group. Add all source files to the
group.
Update #3899.
Update #3993.
Update #4482.
Remove obsolete CONFIGURE_MEMORY_PER_TASK_FOR_SCHEDULER application
configuration option which is unsupported since commit
69aa33490b1cd357519ab70b15ad150e11bb752e.
Directly call the handler on the executing processor instead of doing this
indirectly via a per-CPU job.
Use the processor control to specify the target processor since this is what
the callers have available.
Split up the SMP multicast action module since the use of the SMP multicast
action variants depend on the architecture and BSP.
Move _CPU_Fatal_halt() declaration to <rtems/score/cpuimpl.h> and make sure it
is a proper declaration of a function which does not return. Fix the type of
the error code. If necessary, add the implementation to cpu.c. Implementing
_CPU_Fatal_halt() as a function makes it possible to wrap this function for
example to fully test _Terminate().
Add percpujobs.c to contain the per-CPU jobs implementation.
Remove the unused _SMP_Send_message_multicast() and
_SMP_Send_message_broadcast().
The per-CPU states which control the SMP system initialization were added quite
early during the SMP support development. Replace this initial implementation
with a simplified one. There is no longer a global SMP lock required which
serialized the state changes of all processors. The new implementation better
integrates with the per-CPU jobs.
Remove _CPU_SMP_Processor_event_broadcast() and
_CPU_SMP_Processor_event_receive(). These functions are hard to use since they
are subject to the lost wake up problem.
Use the same function to output the '\r\n' combination produced by
rtems_putc(). Fix the format.
Change licence according to file history.
Update #3053.
Use the same function pointer value to check against NULL and call the
function (if non-NULL).
Fix format, add Doxygen comments, and reduce includes.
Users have access to the fatal error source and code though the fatal error
extension. The user-specific fatal error handling should be done in statically
initialized fatal error handlers. The _Internal_errors_What_happened was
updated after the fatal error extension. In addition, there was no API to get
the information stored in _Internal_errors_What_happened. In SMP
configurations, this object could contain a mix of different fatal errors.
Remove this object to save some bytes of storage.
Do not return a status code in bsp_interrupt_facility_initialize() since this
leads to unreachable code in bsp_interrupt_initialize(). Use RTEMS_DEBUG
assertions in bsp_interrupt_facility_initialize() if necessary.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
