Update #3993.
Fix the documentation.
Update #4181.
This directive has no implementation. It is documented in the RTEMS
Classic API Guide.
It was added by
commit 6c06288f6452da96fa630f1482aeaaba5d217531
Author: Joel Sherrill <joel.sherrill@OARcorp.com>
Date: Tue Jan 29 21:52:21 2008 +0000
without an implementation. The later change
commit fdc57ca4b6794dc17c7b7d94ae557da21e314d6a
Date: Mon Nov 23 14:53:04 2009 +0000
renamed the similar rtems_object_id_api_minimum_class() in
rtems_object_api_minimum_class().
The rtems_object_api_maximum_class() is documented and implemented. It
can be assumed that the rtems_object_id_api_maximum_class() is a
fragement left over from development.
Update #4181.
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If
this option is specified, then the Classic API initialization task is
constructed with rtems_task_construct().
Update #4181.
Replace a runtime check with a compile time assertion. This makes the
INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
Update #4181.
Change the _Per_CPU_Information declaration so that Doxygen can parse
it. This attribute placement is also in line with the _Alignas()
specifier of C11.
Update #3910.
The spintrcritical03-05 and psx12 tests are known to fail on Qemu when
the host system is heavily loaded. A single run of Qemu per core
during a testsuite run tends to yield positive results, but any
additional load on a system will result in test failures.
This patch also applies the correct expected test state for intermittent
failures so that those tests will still build.
This resolves a warning in the exception frame dump for AArch64 relating
to a missized printf format specifier.
The variety of expected test states are not currently applied to tests
with names containing '-' correctly due to a failure to replace '-' with
'_' before adding the CPPFLAGS to the environment for that test. This
ensures that all additions of CPPFLAGS have that replacement performed
so that the CPPFLAGS are applied properly during compilation.
Also start interrupt server tasks on processors which do not have a
scheduler. Applications may dynamically manage processors using
rtems_scheduler_remove_processor() and rtems_scheduler_add_processor().
It is only used by rtems_partition_create().
It is only used by rtems_partition_create(). Fix integer types.
It is only used by rtems_partition_create(). Move code directly into
directive which called the inline function. Add a comment.
the directive which called the inline function. Add a comment.
It is used only by rtems_partition_return_buffer(). Make the PTCB the
first parameter. Rename to _Partition_Is_address_on_buffer_boundary().
It is used only in one place. Make the PTCB the first parameter.
Rename it to _Partition_Is_address_a_buffer_begin().
Bug was introduced by 78baeb757957fa0807c30e6c4d21ae99c9639e6a.
Update #3199.
The SUBALIGN(4) required on rtemsroset and rtemsrwset for ILP32 builds
was previously present on LP64 builds and causes no issues within RTEMS,
but causes relocation/alignment issues when building libbsd. This
restricts those alignment changes to ILP32 builds.
These files are required for libbsd to build against the AArch64 A53
BSPs.
It was a trivial function call wrapper used only in one place.
It is only used by rtems_partition_return_buffer().
It is only used by rtems_partition_get_buffer().
This define was only used in one place.
Use a top-level implementation group to gather implementation related
files. The use of "Impl" is shorter and matches with the *impl.h file
names.
Update #4180
Update #4180
Update #4180
The following files have been imported:
cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.c nxp/boards/evkbimxrt1050
cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.h include/fsl_clock_config.h
cp ${SDK}/boards/evkbimxrt1050/project_template/dcd.c start/flash-dcd.c
cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.c nxp/boards/evkbimxrt1050
cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.h include/fsl_pin_mux.h
cp ${SDK}/boards/evkbimxrt1050/xip/evkbimxrt1050_flexspi_nor_config.h include/fsl_flexspi_nor_config.h
cp ${SDK}/devices/MIMXRT1052/MIMXRT1052.h include
cp ${SDK}/devices/MIMXRT1052/MIMXRT1052_features.h include
cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.c nxp/devices/MIMXRT1052/drivers
cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.h include
cp ${SDK}/devices/MIMXRT1052/fsl_device_registers.h include
cp ${SDK}/devices/MIMXRT1052/system_MIMXRT1052.h include/
cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c nxp/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c
cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.h include
Update #4180
Modify the MPU functions of the stm32h7 BSP to be table based and
available for all ARMV7M BSPs.
Update #4180
Update #4180
Update #4180
