PR 681/doc
PR 682/doc
* buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable
binutils link again.
* user/overview.t: Chapter numbering in preface was wrong.
* libmisc/stackchk/check.c: Spacing.
PR 680/bsps
* network/if_hdlcsubr.c: Add missing #include <rtems/rtems_bsdnet.h>.
PR 606/bsps
* bootloader/pci.c: Fixed IO remapping so buses >= 1 are remapped.
Reduced PCI space to match bat2. Fixed incorrect region size
calculation in pci_read_bases. Set PCI latency timers to known
sane values. Changed bridge PCI settings to minimum sane instead
of whatever sounded neat in the PCI spec. Force pf regions to
memory mapped to preserve byte access.
PR 607/networking
* libchip/network/dec21140.c: Made PCI configuration minimum sane
instead of fully specifying unused PCI features.
PR 608/bsps
* pci/pcibios.c: Added BusCountPCI()
* libnetworking/Makefile.am: Don't include subdirs.am.
* configure.ac: Add score/cpu/avr/Makefile.am.
* score/cpu/Makefile.am: Add avr.
* aclocal/rtems-cpu-subdirs.m4: Add avr.
* aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* * configure.ac: Remove RTEMS_CPU_SUBDIRS.
* librpc/src/xdr/xdr_float.c: Add __AVR__.
* binutils/binutils.add: Rename package from binutils-collection to
binutils. Cleanups.
* binutils/target-binutils.add: Reflect changes above.
* binutils/Makefile.am: Add avr. Reflect changes above.
* autotools/autoconf-rtems.spec.in: Cleanup for chroot'ed builds.
* autotools/automake-rtems.spec.in: automake-1.9.2.
* gcc3newlib/Makefile.am: Add avr-rtems*gcc.
* gcc3newlib/gccnewlib.add: Disable c++ for avr.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
PR 677/misc
* libmisc/dumpbuf/dumpbuf.h, libmisc/fsmount/fsmount.h,
libmisc/rtmonuse/rtmonuse.h, libmisc/serdbg/serdbg.h,
libmisc/serdbg/serdbgcnf.h, libmisc/serdbg/termios_printk.h,
libmisc/serdbg/termios_printk_cnf.h, libmisc/untar/untar.h: Add
extern C wrappers.
PR 676/networking
* libnetworking/nfs/bootp_subr.c: /etc/resolv.conf contains NTP instead
of DNS servers.
* README, times, network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5272.c, startup/linkcmds: Use CVS Id.
* FAQ/build45.t: Misc. corrections.
PR 671/bsps
* rtems/score/cpu.h: Fixed bug in _CPU_ISR_Set_level, where input param
was always ignored.
PR 673/make_build
* config-ml.in: Quote 'cd "${ml_origdir}"'.
Quote 'cd "${ML_POPDIR}"'.
PR 673/make_build
* aclocal/rtems-top.m4 (RTEMS_TOP): Add further quotes.
* aclocal/ppc.m4 (RTEMS_PPC_EXCEPTIONS): Quote ac_popdir uses.
* aclocal/target.m4 (_RTEMS_POP_BUILDDIR): Ditto.
* acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses.
* custom/csb360.cfg: New file.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, console/.cvsignore, console/console-io.c, include/.cvsignore,
include/bsp.h, include/coverhd.h, include/tm27.h, network/network.c,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspclean.c, startup/bspstart.c, startup/init5272.c,
startup/linkcmds: New files.
* Makefile.am, configure.ac: Added CSB360 BSP
* mcf5272/.cvsignore, mcf5272/ChangeLog, mcf5272/Makefile.am,
mcf5272/clock/.cvsignore, mcf5272/clock/ckinit.c,
mcf5272/include/.cvsignore, mcf5272/include/mcf5272.h,
mcf5272/timer/.cvsignore, mcf5272/timer/timer.c,
mcf5272/timer/timerisr.S: New files.
* rgdb_specs/layers.txt, rgdb_specs/process.txt,
rgdb_specs/seqbreak.txt, rgdb_specs/seqdetach.txt,
rgdb_specs/seqinit.txt: New.
* rgdb_specs/comm.t, rgdb_specs/conclusion.t,
rgdb_specs/gdbinternals.t: Use @image for
ASCII figures (Reflect changes above).
* common/rtems.texi.in, FAQ/basic.t: Remove RTEMSSNAPSHOTS,
RTEMSSNAPSHOTSSUBSCRIBE.
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi,
FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi,
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/tools.texi,
FAQ/version.texi, FAQ/stamp-vti: New.
FAQ/version.texi: New.
* networking/networkflow.txt, networking/PCIreg.txt,
networking/recvbd.txt: New.
* networking/decdriver.t, networking/networktasks.t: Use @image for
* network/network.c: Changes to network driver to get it to compile
again.
* autotools/automake.spec.in: automake-1.9.
* VERSION: Updated to rtems-4.6.99.1.
* aclocal/version.m4: Updated to rtems-4.6.99.1.
* release_support: Have a user name.
