* | samples/base_mp - Makefile.am did not set LINK_OBJS | Joel Sherrill | 2012-05-04 | 2 | -2/+2 |
| | | | | | | | | LINK_OBJS = instead of LINK_OBJS = $(mp01_node1_OBJECTS) | ||||
* | mptests - Makefile.am did not set LINK_OBJS | Joel Sherrill | 2012-05-04 | 28 | -28/+28 |
* | nfsclient: Add rename operation | Sebastian Huber | 2012-05-04 | 1 | -1/+45 |
* | nfsclient: Fix hard link operation | Sebastian Huber | 2012-05-04 | 1 | -1/+1 |
* | Filesystem: Use proper parameter in NFS | Sebastian Huber | 2012-05-04 | 1 | -1/+1 |
* | Filesystem: Remove pipe_lseek() | Sebastian Huber | 2012-05-04 | 3 | -35/+1 |
* | Filesystem: Remove per file descriptor semaphore | Sebastian Huber | 2012-05-04 | 13 | -47/+14 |
| | | | | | | | | | The per file descriptor semaphore (field of rtems_libio_t) is unused in RTEMS. There is a considerable memory overhead due to that. A semaphore needs roughly 124 bytes which is huge compared to the approximately 72 bytes for the file descriptor structure itself. Device drivers can create their own synchronization primitives in the open handler on demand. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 17 | -42/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 15 | -46/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -4/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 3 | -9/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -8/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 58 | -194/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 16 | -41/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 4 | -12/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 34 | -166/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 158 | -774/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 11 | -51/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 17 | -78/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 33 | -161/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 84 | -400/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 44 | -174/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 56 | -261/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 27 | -131/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 47 | -127/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 109 | -217/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 6 | -16/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 6 | -18/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 10 | -30/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 36 | -111/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 13 | -42/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 48 | -144/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 5 | -14/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 8 | -25/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 20 | -68/+0 |
