Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Add default implementations for bsp_interrupt_get_affinity() and
bsp_interrupt_set_affinity() which are required to link all tests in SMP
configurations.
Update #3269.
Add rtems_interrupt_entry_remove(). Split up irq-generic.c into several files.
In particular, place all functions which use dynamic memory into their own
file.
Add optional macros to let the BSP customize the vector installation after
installing the first entry and the vector removal before removing the last
entry:
* bsp_interrupt_vector_install()
* bsp_interrupt_vector_remove()
Use these new customization options in the m68k/genmcf548x BSP so re-use the
generic interrupt controller support.
Update #3269.
This function is only used by one BSP.
Update #3269.
Return RTEMS_INCORRECT_STATE instead of RTEMS_INTERNAL_ERROR in case the
interrupt support is not initialized. This is similar to
rtems_timer_server_fire_after() for example.
Update #3269.
Update #3269.
Add RTEMS_INTERRUPT_ENTRY_INITIALIZER(),
rtems_interrupt_entry_initialize(), and
rtems_interrupt_entry_remove(). This allows to install interrupt
handlers using user-provided storage as an alternative to
rtems_interrupt_handler_install() which has to allocate memory.
Update #3269.
Update #3269.
Update #3269.
Return a status code for bsp_interrupt_set_affinity().
Update #3269.
Return a status code for bsp_interrupt_get_affinity().
Update #3269.
Return a status code for bsp_interrupt_vector_disable().
Update #3269.
Return a status code for bsp_interrupt_vector_enable().
Update #3269.
Add a default implementation which just returns RTEMS_UNSATISFIED.
Update #3269.
Add a default implementation which clears the attributes to zero and
just returns RTEMS_SUCCESSFUL for valid parameters.
Update #3269.
Add rtems_interrupt_raise_on() and rtems_interrupt_clear().
Add a default implementation which just returns RTEMS_UNSATISFIED for
valid parameters.
Update #3269.
valid parameters.
Update #3269.
Add RTEMS_FATAL_SOURCE_SPURIOUS_INTERRUPT as the fatal source for
spurious interrupts. Use the interrupt vector number of the spurious
interrupt for the fatal code.
Update #3269.
Update #3269.
Update #3269.
Add rtems_interrupt_vector_disable().
Update #3269.
Add a directive to query the attributes of an interrupt vector. This
can be used for generic tests and system diagnostics.
Update #3269.
Use <rtems/score/chain.h> which just provides the data types and avoid a
dependency on <rtems/chain.h> which contains the full chain
implementation.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3269.
Update #3899.
Update #3993.
Add rtems_interrupt_raise_on(). Document the currently not implemented
rtems_interrupt_clear(). Remove the not implemented and badly named
rtems_interrupt_cause() directive.
Update #3269.
Update #3269.
Bring the error conditions and status in line with
rtems_task_get_affinity() and rtems_task_set_affinity().
Update #3269.
Update #3269.
The LDFLAGS are placed after the static libraries in the standard waf link
command, see "waflib/Tools/c.py" in the waf sources.
The heap protection is conditional.
BSP family and BSP variant names may be equal. This prefix avoids
ambiguity in the enabled-by expressions.
When compiling the lwIP port for the TMS570, there
were issues with the BSP. Headers are expected in a folder
named ti_herc which did not exist. This fixes the issue.
Furthermore, there were multiple warnings about define redefinitions.
This was fixed as well.
These patches were submitted a few months ago, but it was found out
that the default-by-family: [] were missing in the GPIO .yml lines.
This was fixed in this patch.
This patch accounts for different pins for the ETH peripheral
on STM32H7 devices. For example, the Nucleo H743ZI has slightly
different pins than other STM32H7 boards.
The <leon.h> header file contains a lot of implementation details. Hide them
from <bsp.h>.
Prefer RTEMS_FATAL_SOURCE_EXCEPTION over
INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT since the fatal code
(rtems_exception_frame) provides more context.
