* aclocal/version.m4: Updated to rtems-ss-20021004.
* VERSION: Updated to rtems-ss-20021004.
* netinet/in_cksum.c, netinet/ip_icmp.h, netinet/ip_input.c,
netinet/tcp_input.c, netinet/tcp_subr.c, netinet/tcp_var.h,
sys/queue.h: Address alignment requirements for the ARM.
* cvsignore-add.sh: Script to append a specific file to all
.cvsignore files if the files exists is a specific directory.
* rtems/rtems_glue.c: Add IP aliasing ioctls SIOCAIFADDR and
SIOCDIFADDR.
* irq/irq_asm.S: Add FIQ support.
* rtems/score/cpu.h: Fix u16 and u32 swap routines.
* src/imfs/memfile.c: Fixed case where last close of unlinked file
did not remove the resources associated with that file. Reported
by Till Straumann <strauman@slac.stanford.edu> on the mailing list.
* rtems-stub-glue.c: Removed should only be common copy.
* custom/armulator.cfg: Remove reference to PowerPC arguments.
* kern/uipc_socket.c: Make sure that small non-zero delays work.
Suggested cleanup from Eric Norum.
* rtems/mkrootfs.c: As part of PR283, remove redundant code that
creates /etc/passwd and /etc/group.
* src/getpwent.c: Per PR283, reimplement to address reentrancy problems.
* src/getgrent.c: Removed as functionality is now just a wrapper for
common routines in src/getpwent.c.
* Makefile.am: Reflect file removal.
* netinet/Makefile.am, netinet/udp_usrreq.c: Back off some of
the IP_FORWARD patch as it appears to not compile in the
current tree.
* include/rtems/libio.h: Change rtems_filesystem_read_t and
rtems_filesystem_write_t to return ssize_t to match read(2)
and write(2) respectively.
* support/init.c: Included <unistd.h> for exit(2).
* support/test_support.adb: Eliminated warnings by commenting out
unused variables.
* serial/z85c30.c: Eliminated warning by clarifying statement.
* src/dosfs/fat.c, src/imfs/deviceio.c, src/imfs/imfs.h,
src/imfs/imfs_directory.c, src/imfs/imfs_fchmod.c,
src/imfs/memfile.c: Eliminated warnings. A lot of this focus
was on changing read and write entry points to return ssize_t
as read(2) and write(2) now do.
* cpu.c: Include declaration of variable i in ifdef USE_SPRG to
eliminate warning.
* src/dpmemcreate.c, src/dpmemident.c, src/msgqcreate.c,
src/msgqident.c, src/partcreate.c, src/partident.c,
src/ratemoncreate.c, src/ratemonident.c, src/regioncreate.c,
src/regionident.c, src/semcreate.c, src/semident.c, src/taskcreate.c,
src/taskident.c, src/timercreate.c, src/timerident.c: Added casts
to Objects_Name to eliminate warnings.
* gcc3newlib/base-gcj.add, gcc3newlib/gccnewlib.add,
gcc3newlib/target-gcj.add: First attempt at enabling Java support.
* clock/clock.c: Per PR257, remove reference to c3x_set_ie.
c4x variant should use c4x_set_iie().
* startup/bspstart.c: As part of fixing PR281 on gensh4, a review
of all calls to bsp_libc_init() resulted in some cleanup here.
* sp32/.cvsignore: New file.
* PR271 was not applicable against the current source but included
a nice test that Joel decided to add to the tree as sp32.
* sp32/Makefile.am, sp32/init.c, sp32/sp32.scn: New file.
* Makefile.am, configure.ac: Modified to reflect addition.
* kern/uipc_socket.c: Fix case on SO_RCVTIMEO and SO_SNDTIMEO where
conversion into ticks can result in a 0 ticks timeout which is
the same as requesting no timeout. Reported by Sergei Organov
<osv@javad.ru>.
* kern/uipc_mbuf.c, sys/mbuf.h, netinet/udp_usrreq.c: Add
optional UDP broadcast forwarding support.
* netinet/Makefile.am: Defined FORWARD_PROTOCOL to enabled UDP
broadcast forwarding.
* src/psignal.c: Remove duplication from rtems/posix/psignal.h.
* include/bsp.h, startup/Makefile.am, startup/bspclean.c:
Cleanup so the BSP works.
* rtems/score/cpu.h (_CPU_Initialize_vectors) Define to NULL
since it is not used.
* src/readdir_r.c: New file.
* Makefile.am: Reflect above.
* start/start16.S: Remove unwanted + at beginning of relative
numeric label.
numeric label.
* samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am:
Now appear to mostly compile.
* samples/hello/Makefile.am: Make sure init.c is compiled and
included. This test now runs.
* Part of addressing PR281.
* target.cfg.in: Removed remaining support for RTEMS_USE_GCC272
and RTEMS_LIBC_DIR.
* main.cfg: Added recognition of VARIANT=DEBUG on command line.
* compilers/gcc-target-default.cfg: Removed remaining support for
RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug
as one of the LDFLAGS when the debug variant is specified.
* configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* Makefile.am: Don't use RTEMS_TOPdir in ACLOCAL_AMFLAGS.
* Makefile.am: ACLOCAL_AMFLAGS = -I ../../../../../../aclocal.
* configure.ac: Remove duplicate mpc6xx/timer/Makefile from CONFIG_FILES.
* configure.ac: Remove duplicate timer/Makefile from CONFIG_FILES.
* clock/clock.c: Disabled use of fast idle since it seems broken
with gcc 3.2.
* samples/base_mp/config.h: New file previously missed.
