* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am:
* capture/config.h: New.
* capture/Makefile.am: Add config.h.
* cpuuse/config.h: New.
* cpuuse/Makefile.am: Add config.h.
* devnull/config.h: New.
* devnull/Makefile.am: Add config.h.
* dummy/config.h: New.
* dummy/Makefile.am: Add config.h.
* dumpbuf/config.h: New.
* dumpbuf/Makefile.am: Add config.h.
* monitor/config.h: New.
* monitor/Makefile.am: Add config.h.
* mw-fb/config.h: New.
* mw-fb/Makefile.am: Add config.h.
* rtmonuse/config.h: New.
* rtmonuse/Makefile.am: Add config.h.
* serdbg/config.h: New.
* serdbg/Makefile.am: Add config.h.
* shell/config.h: New.
* shell/Makefile.am: Add config.h.
* stackchk/config.h: New.
* stackchk/Makefile.am: Add config.h.
* untar/config.h: New.
* untar/Makefile.am: Add config.h.
* wrapup/Makefile.am:
* configure.ac: Merge-in libfs/configure.ac.
* Makefile.am: Add libfs to SUBDIRS.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, src/Makefile.am, src/dosfs/Makefile.am,
src/imfs/Makefile.am: Reflect having merged configure.ac into
../configure.ac.
* src/dosfs/config.h: New.
* src/dosfs/Makefile.am: Add config.h.
* src/imfsfs/config.h: New.
* src/imfs/Makefile.am: Add config.h.
Remove COMMON_C_FILES, DOC_FILES (Unused).
* src/dosfs/fat.c: include config-header "config.h".
* src/dosfs/fat_fat_operations.c: Ditto.
* src/dosfs/fat_file.c: Ditto.
* src/dosfs/msdos_conv.c: Ditto.
* capture/capture-cli.c: Add config-header support.
* capture/capture.c: Add config-header support.
* cpuuse/cpuuse.c: Add config-header support.
* devnull/devnull.c: Add config-header support.
* dummy/dummy.c: Add config-header support.
* dumpbuf/dumpbuf.c: Add config-header support.
* monitor/mon-command.c: Add config-header support.
* monitor/mon-config.c: Add config-header support.
* monitor/mon-dname.c: Add config-header support.
* monitor/mon-driver.c: Add config-header support.
* monitor/mon-extension.c: Add config-header support.
* monitor/mon-itask.c: Add config-header support.
* monitor/mon-manager.c: Add config-header support.
* monitor/mon-monitor.c: Add config-header support.
* monitor/mon-mpci.c: Add config-header support.
* monitor/mon-object.c: Add config-header support.
* monitor/mon-prmisc.c: Add config-header support.
* monitor/mon-queue.c: Add config-header support.
* monitor/mon-server.c: Add config-header support.
* monitor/mon-symbols.c: Add config-header support.
* monitor/mon-task.c: Add config-header support.
* mw-fb/mw_fb.c: Add config-header support.
* mw-fb/mw_uid.c: Add config-header support.
* rtmonuse/rtmonuse.c: Add config-header support.
* serdbg/serdbg.c: Add config-header support.
* serdbg/serdbgio.c: Add config-header support.
* serdbg/termios_printk.c: Add config-header support.
* shell/cmds.c: Add config-header support.
* stackchk/check.c: Add config-header support.
* untar/untar.c: Add config-header support.
* Makefile.am: Reflect having merged configure.ac into
../configure.ac.
* configure.ac: Merge-in libblock/configure.ac.
* Makefile.am: Add libblock to SUBDIRS.
* configure.ac: Merge-in ada/configure.ac.
* Makefile.am: Add ada to SUBDIRS.
../configure.ac.
* SUPPORT: Fix Mark Johannes' email address.
PR 417/rtems
* src/coresemsurrender.c: Correct incorrect check for maximum_count
reported by Sergei Organov <osv@topconrd.ru>.
* configure.ac: Remove RTEMS_BSP from RTEMS_CHECK_MULTIPROCESSING.
* VERSION: Updated to rtems-ss-20030703.
* aclocal/version.m4: Updated to rtems-ss-20030703.
rtems_termios_bufsize call.
* console-polled.c: Corrected comments in header.
* network/dec21140.c, network/elnk.c: Update to compile on i386.
PR414 - Fixed the global interupt vector register.
Linker command file to have the boot code in the first 8K.
The chip select remap needed to be volatile.
* bootstrap: Reflect having added config.sub.
* config.sub: New from subversions to accomodate c4x/tic4x.
* network/README.3com: New file missed in previous commit.
PR 405/bsps
PR 393/networking
* network/dec21140.c: Fix leak also known as PR393.
* network/elnk.c, network/if_media.h, network/mii.h: New files.
* network/Makefile.am: Reflect new files.
PR 405/bsps
PR 393/networking
PR 405/bsps
* bootloader/pci.c: Added support for configuring devices for pci
busses > 0
* pci/pci.c, pci/pci.h: Added FixupPCI() to store vectors in the
INTERRUPT_LINE register of pci devices any # of hops away
from the host processor.
* motorola/motorola.c, motorola/motorola.h: Added interrupt
routing tables in support of FixupPCI. This is board-specific,
each board will have to supply information for FixupPCI() to do
anything for it.
* startup/bspstart.c: Extended bat2 to cover entire PCI address space.
* irq/irq.c, irq/irq.h: Added support for shared interrupts.
Existing single hander vectors are undisturbed, a new function
added to allow adding/removing handlers from a vector.
PR 415/bsps
* include/bsp.h, pci/detect_raven_bridge.c, startup/bspstart.c:
Support enabling MCP exceptions on the host bridge. This can
be used for memory probing on the VME bus.
* src/threadloadenv.c: Removed warnings.
* pppd/chat.c: Removed warnings.
* console/console.c, startup/linkcmds: Removed warnings.
* startup/linkcmds: Removed warnings.
* psxchroot01/test.c, psxreaddir/test.c: Removed warnings.
* src/objectmp.c: Removed warnings.
* include/rtems/rtems/msgmp.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/semmp.h,
src/msgmp.c, src/partmp.c, src/regionmp.c, src/semmp.c: Removed
warnings.
* configure.ac: Remove "BLEEDING EDGE" warning.
Put docs into RTEMS_BUILD_CONFIG_SUBDIRS.
* acinclude.m4: Add AC_PREREQ(2.57).
Major overhaul (PR 412).
* aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM.
* aclocal/gcc-isystem.m4: New.
* Makefile.am: Add aclocal/gcc-isystem.m4.
PR 411/filesystem
* src/imfs/imfs_unlink.c: Fix bug where renaming a memfile and
then unlinking it causes a memory leak.
* bsp.mak: Remove support for profile-variant.
* configure.ac: Ditto.
* directory.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* make/README: Remove references to profile-variant.
PR 321:
* leaf.cfg: Remove support for profile-variant.
* main.cfg: Ditto.
* compilers/gcc-no_bsp.cfg: Ditto.
* compilers/gcc-portsw.cfg: Ditto.
* configure.ac: Remove support for profile-variant.
* automake/local.am: Remove $(ARCH), clean-local.
* pppd/system.h: Hack from Ralf to compile on all targets.
