* libnetworking/libc/res_comp.c,
libnetworking/netinet/igmp.c,
libnetworking/netinet/in_cksum.c,
libnetworking/netinet/in_proto.c,
libnetworking/netinet/tcp_debug.c,
libnetworking/netinet/tcp_input.c,
libnetworking/netinet/tcp_output.c,
libnetworking/netinet/tcp_timer.c:
Remove BSD "Add clause" (From FreeBSD).
* libnetworking/net/if_ethersubr.c, libnetworking/net/if_loop.c,
libnetworking/net/if_ppp.c, libnetworking/net/ppp_tty.c,
libnetworking/net/radix.c, libnetworking/net/raw_cb.c,
libnetworking/net/raw_usrreq.c, libnetworking/net/route.c,
libnetworking/net/rtsock.c, libnetworking/net/slcompress.c:
Stop using old-style function definitions.
* libcsupport/include/timerdrv.h: Rename timer driver methods to follow
RTEMS programming conventions.
* timerstub.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c, timer/timerisr.c: Eliminate empty function from every
benchmark timer driver. Fix spelling.
* timer/timer.c: Eliminate empty function from every benchmark timer
* timer/timer.c, timer/timerisr.S: Eliminate empty function from every
* console/console.c, include/m340timer.h, timer/timer.c: Eliminate
empty function from every benchmark timer driver. Fix spelling.
* support/src/tmtests_empty_function.c: New file.
* tmitronsem01/Makefile.am, tmitronsem01/init.c: Eliminate empty
* tm01/Makefile.am, tm01/task1.c, tm02/Makefile.am, tm02/task1.c,
tm03/Makefile.am, tm03/task1.c, tm04/Makefile.am, tm04/task1.c,
tm05/Makefile.am, tm05/task1.c, tm06/Makefile.am, tm06/task1.c,
tm07/Makefile.am, tm07/task1.c, tm08/Makefile.am, tm08/task1.c,
tm09/Makefile.am, tm09/task1.c, tm10/Makefile.am, tm10/task1.c,
tm11/Makefile.am, tm11/task1.c, tm12/Makefile.am, tm12/task1.c,
tm13/Makefile.am, tm13/task1.c, tm14/Makefile.am, tm14/task1.c,
tm15/Makefile.am, tm15/task1.c, tm16/Makefile.am, tm16/task1.c,
tm17/Makefile.am, tm17/task1.c, tm18/Makefile.am, tm18/task1.c,
tm19/Makefile.am, tm19/task1.c, tm20/Makefile.am, tm20/task1.c,
tm21/Makefile.am, tm21/task1.c, tm22/Makefile.am, tm22/task1.c,
tm23/Makefile.am, tm23/task1.c, tm24/Makefile.am, tm24/task1.c,
tm25/Makefile.am, tm25/task1.c, tm26/Makefile.am, tm26/task1.c,
tm27/Makefile.am, tm27/task1.c, tm28/Makefile.am, tm28/task1.c,
tm29/Makefile.am, tm29/task1.c, tmck/Makefile.am, tmck/task1.c,
tmoverhd/Makefile.am, tmoverhd/testtask.c: Eliminate empty function
* arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c,
arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c,
arm/s3c24xx/timer/timer.c, bfin/timer/timer.c,
m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* sh7032/timer/timer.c, sh7045/timer/timer.c, sh7750/timer/timer.c:
Rename timer driver methods to follow RTEMS programming conventions.
* mpc505/timer/timer.c, mpc5xx/timer/timer.c, mpc6xx/timer/timer.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, ppc403/timer/timer.c:
* timer/timer.c: Rename timer driver methods to follow RTEMS
* mcf5206/timer/timer.c, mcf5206/timer/timerisr.S,
mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Rename timer driver
* at91rm9200/timer/timer.c, lpc22xx/timer/timer.c,
mc9328mxl/timer/timer.c, s3c2400/timer/timer.c,
s3c24xx/timer/timer.c: Rename timer driver methods to follow RTEMS
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c,
tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c,
tmoverhd/testtask.c: Rename timer driver methods to follow RTEMS
* timer/timer.c, timer/timerisr.S: Rename timer driver methods to
* timer/timer.c, timer/timerisr.c: Rename timer driver methods to
* console/console.c, include/m340timer.h, timer/timer.c: Rename timer
* bootcard.c: Fix formatting.
* console-polled.c: Error if minor < 2 not just <= 2.
* posix/Makefile.am, rtems/src/tasksetpriority.c: Improve comments and
wrapping.
* libchip/network/sonic.c: Do not declare a variable just to hold an
ignored return value.
* acinclude.m4: Add mcf52235 and mcf5329. Regenerate.
* acinclude.m4: Add bf537Stamp. Regenerate.
* Makefile.am, startup/bspstart.c: Use default bsp_pretasking_hook().
* ftpd/ftpd.c: Fix prototype.
* Makefile.am: Remove another duplicate reference.
* Makefile.am: Remove duplicate reference.
* shared/vme/vme_universe.c: added implementation for
BSP_VMEResetBus().
* vmeUniverse/vmeTsi148.h, vmeUniverse/vmeTsi148.c:
added vmeTsi148ResetBusXX(), vmeTsi148ResetBus().
