* timer/timer.c: Eliminate uses of old benchmark timer names.
* bsp_howto/timer.t: Eliminate uses of old benchmark timer names.
* include/tm27.h: Do not use set_vector.
* preinstall.am: Regenerated.
* sh7750/score/ispsh7750.c, shgdb/score/ispshgdb.c: Fine tune
conditional so _CPU_ISR_install_vector is in CPU Kit now.
* cpu.c: Fine tune conditional so _CPU_ISR_install_vector is in CPU Kit
now.
* custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh4.cfg: Make all use
RTEMS_BSP_FAMILY.
* Makefile.am, preinstall.am: Add timer driver stub.
* acinclude.m4: simsh4 folded into shsim.
* Makefile.am, preinstall.am, include/bsp.h, include/tm27.h,
trap34/console-io.c: Now builds cleanly for runs for SH1, SH2, and
SH4.
* include/syscall.h: New file.
* include/gdbsci.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* start/startfor340only.S: Remove (Unused).
* include/tm27.h: Now links all tests.
* simsh4/.cvsignore, simsh4/ChangeLog, simsh4/Makefile.am,
simsh4/README, simsh4/bsp_specs, simsh4/configure.ac,
simsh4/preinstall.am, simsh4/clock/ckinit.c,
simsh4/console/console.c, simsh4/include/.cvsignore,
simsh4/include/bsp.h, simsh4/include/coverhd.h,
simsh4/include/ramdisk.h, simsh4/include/syscall.h,
simsh4/include/tm27.h, simsh4/start/start.S,
simsh4/startup/hw_init.c, simsh4/startup/linkcmds,
simsh4/startup/linkcmds-le, simsh4/startup/linkcmds-le.coff,
simsh4/timer/timer.c, simsh4/tools/.cvsignore,
simsh4/tools/ChangeLog, simsh4/tools/Makefile.am,
simsh4/tools/configure.ac, simsh4/tools/runtest.in: Removed.
* Makefile.am: Eliminate bsp.am. Cleanup.
* shgdb/score/ispshgdb.c: Add dummy _CPU_ISR_install_vector.
* Makefile.am, preinstall.am: Now links all tests.
* include/tm27.h: New file.
* include/tm27.h: Remove reference to set_vector.
* clock/clockdrv.c: Correct spelling error in comment.
* include/tm27.h: Delete duplicate #endif.
* mcf5206/timer/timerisr.S: Make compile again.
* clockdrv_shell.c: Empty file. Add warning to not use this file.
* clock_driver_simidle.c: include clockdrv_shell.h.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* liblnk/regs.S: Remove (Renamed into liblnk/regs.h).
* liblnk/regs.h: New (Renamed from liblnk/regs.S).
* Makefile.am, liblnk/pmon.S: Reflect renamer.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* clock/ckinit.c: include "../../../shared/clockdrv_shell.h".
* clock/clock-config.c: include "../../../shared/clockdrv_shell.h".
* clockdrv_shell.h: New (Copied from clockdrv_shell.c).
* console/defaultfont.c: Remove (Renamed into console/defaultfont.h).
* console/defaultfont.h: New (Renamed from console/defaultfont.c).
* Makefile.am, console/conio.c: Reflect renamer.
* Makefile.am: Remove build_date.c.
* startup/bspstart.c: Remove BSP_build_date.
