* | Patches from Eric Norum | Joel Sherrill | 1998-08-20 | 60 | -363/+252 |
* | Added CVS Ids | Joel Sherrill | 1998-08-20 | 258 | -0/+812 |
* | Fixed many warnings. | Joel Sherrill | 1998-08-20 | 138 | -336/+644 |
* | changed version to 980820-BSD | Joel Sherrill | 1998-08-20 | 2 | -2/+2 |
* | Regenerated. | Joel Sherrill | 1998-08-20 | 0 | -0/+0 |
* | Changed to avoid use of gets(). | Joel Sherrill | 1998-08-20 | 4 | -32/+136 |
* | Updated to reflect TCP/IP stack transition. | Joel Sherrill | 1998-08-20 | 1 | -1/+3 |
* | Updated to reflect stack transition. | Joel Sherrill | 1998-08-20 | 3 | -5/+6 |
* | Temporarily leave strsep out of the build. | Joel Sherrill | 1998-08-20 | 2 | -4/+8 |
* | Added missing file. | Joel Sherrill | 1998-08-20 | 2 | -2/+2 |
* | Removed stub implementation | Joel Sherrill | 1998-08-20 | 3 | -13/+4 |
* | FreeBSD stack compiles for the first time (except libc/strsep.c) | Joel Sherrill | 1998-08-20 | 42 | -558/+832 |
* | FreeBSD stack compiles for the first time (except libc/strsep.c). | Joel Sherrill | 1998-08-20 | 54 | -24/+1356 |
* | Base files | Joel Sherrill | 1998-08-20 | 4 | -0/+190 |
* | Base files | Joel Sherrill | 1998-08-20 | 12 | -0/+584 |
* | Base version. | Joel Sherrill | 1998-08-20 | 2 | -0/+28 |
* | Base files | Joel Sherrill | 1998-08-19 | 859 | -0/+239233 |
* | First version produced. | Joel Sherrill | 1998-08-19 | 3 | -2/+3 |
* | Renamed files ... just about to produce the first copy of the manual. | Joel Sherrill | 1998-08-19 | 5 | -21/+21 |
* | Baseline | Joel Sherrill | 1998-08-19 | 9 | -0/+2321 |
* | changed version to 980819 | Joel Sherrill | 1998-08-19 | 2 | -2/+2 |
* | Patch from Eric Valette <valette@crf.canon.fr>: | Joel Sherrill | 1998-08-19 | 5 | -59/+94 |
| | | | | | | | - Use the "hlt" instruction for the Idle thread, - Optimise interrupt PATH leadding to thread wakeup, - Preparation for Intel exception management that should come before the end of the week... | ||||
* | Fixed obsolete reference to BSDINSTALL. | Joel Sherrill | 1998-08-19 | 2 | -2/+2 |
* | Patch from Aleksey <qqi@world.std.com>: | Joel Sherrill | 1998-08-19 | 2 | -10/+45 |
| | | | | | | | | | | | | This patch has same changes as one I sent to you earlier plus it fixes _heap_size problem for pc386 we had discussed earlier. Now, _heap_size is defined and set to 0 in pc386/startup/bspstart.c It can be patched to desireable value in binary image. If it is left unpatched, then startup code will determine size of memory (on the assumption that at least 2MB are present) and use max possible heap. | ||||
* | Patch from Aleksey <qqi@world.std.com>: | Joel Sherrill | 1998-08-19 | 11 | -67/+74 |
| | | | | | | It fixes netboot build problem, KA9Q configuration for pc386, some compiler wardning, it also removed some stuff ifdef'ed with '#if 0'. | ||||
* | Patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> and myself to | Joel Sherrill | 1998-08-19 | 18 | -27/+49 |
| | | | | | | | | | | | | | | | | | | | | | | | | make solaris target buildable. > 1. The ipc check fails since solaris does not define union semun. > The unix port code actually defines this type itself on solaris. Doing > the same thing lets it get configured. Then... > 2. It looks like BSDINSTALL is not defined properly. BSDINSTALL is defined in make/host.cfg.in as BSDINSTALL=@INSTALL@ @INSTALL@ is generated by autoconf's standard macro AC_PROG_INSTALL, which is widely used in almost any autoconf/automake configured package. In case there is really something wrong with it, then it must be considered a bug in autoconf. I can see a doubious fragment in AC_PROG_INSTALL, which is used when no appropriate bsd-install is found. Finally Ralf saw a problem with the find on solaris which I also saw and fixed. | ||||
* | Cleaned up the ka9q definition. | Joel Sherrill | 1998-08-19 | 1 | -4/+0 |
* | Added 68060 definition from Chris Johns. | Joel Sherrill | 1998-08-19 | 1 | -0/+17 |
* | If 0 out the code which touches the chip in questionable ways for processing | Joel Sherrill | 1998-08-14 | 1 | -0/+6 |
| | | | | a giant packet. | ||||
* | Changed tm27 clear interrupt macro on all PPC BSPs except the papyrus. | Joel Sherrill | 1998-08-14 | 1 | -0/+5 |
* | Added information on caching. | Joel Sherrill | 1998-08-14 | 1 | -0/+13 |
* | Updated. | Joel Sherrill | 1998-08-14 | 1 | -1/+1 |
* | Fixed version reference | Joel Sherrill | 1998-08-13 | 1 | -1/+1 |
* | Updated. | Joel Sherrill | 1998-08-13 | 1 | -181/+179 |
* | New times for 4.0.0-lmco | Joel Sherrill | 1998-08-13 | 5 | -269/+278 |
* | Fixed preinstall stanza so the prebuild works. | Joel Sherrill | 1998-08-13 | 2 | -6/+6 |
* | Switched from presenting timing data based on CPU models to presenting it | Joel Sherrill | 1998-08-13 | 19 | -155/+162 |
| | | | | based on board model. | ||||
* | New file | Joel Sherrill | 1998-08-13 | 1 | -0/+247 |
* | Added DMV177 times files and made this all regenerate with two timing | Joel Sherrill | 1998-08-13 | 10 | -59/+1726 |
| | | | | chapters. | ||||
* | Added text to clarify the queueing of multiple events. | Joel Sherrill | 1998-08-13 | 1 | -12/+12 |
* | Added bswap feature. | Joel Sherrill | 1998-08-13 | 2 | -4/+30 |
* | Updated version information. | Joel Sherrill | 1998-08-13 | 1 | -25/+25 |
* | Updated the disk space required. | Joel Sherrill | 1998-08-13 | 1 | -2/+2 |
| | | | | Fixed a typo in the hello world example. | ||||
* | Corrected name of build script and other minor things in the list of | Joel Sherrill | 1998-08-13 | 1 | -9/+13 |
| | | | | | | | | needed tools. Corrected path to patches. Added warning about putting the install point under the build tree. | ||||
* | Added a warning about positioning the INSTALL_POINT under the build | Joel Sherrill | 1998-08-13 | 1 | -0/+4 |
| | | | | tree. | ||||
* | Added RTEMS.src stanza dn commands to run it. | Joel Sherrill | 1998-08-13 | 2 | -2/+7 |
* | Changed settings for RPREFIX and DIRPREFIX. | Joel Sherrill | 1998-08-13 | 1 | -2/+2 |
* | Updated version number | Joel Sherrill | 1998-08-13 | 1 | -1/+1 |
* | Updated to include standard number. | Joel Sherrill | 1998-08-13 | 1 | -4/+7 |
* | Updated. | Joel Sherrill | 1998-08-13 | 1 | -3/+3 |
