* | moved from main include directory | Joel Sherrill | 1997-08-04 | 15 | -0/+1434 |
* | Fixed wildcard in copy command. | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | Added comments to help avoid editting generated file. | Joel Sherrill | 1997-08-04 | 2 | -0/+8 |
* | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1997-08-04 | 7 | -11/+57 |
* | Fixed node links. | Joel Sherrill | 1997-08-04 | 3 | -3/+3 |
* | removed binary files | Joel Sherrill | 1997-08-04 | 3 | -0/+0 |
* | Added these files to contain bodies for routines included in the API | Joel Sherrill | 1997-08-02 | 5 | -1/+203 |
| | | | | | but which did not have real bodies. This is necessary for languages like Ada95 which must have real entries in a library for bindings. | ||||
* | Added conditional for KA9Q. | Joel Sherrill | 1997-08-01 | 1 | -0/+4 |
* | Added include of termios.h which was accidentally left out. | Joel Sherrill | 1997-08-01 | 1 | -0/+2 |
* | Added consolex to wrapup | Joel Sherrill | 1997-08-01 | 1 | -0/+1 |
* | Corrected typo. | Joel Sherrill | 1997-08-01 | 1 | -1/+1 |
* | Added --enable-gmake-print-directory option and ods68302 bsp. | Joel Sherrill | 1997-08-01 | 1 | -1/+2 |
* | Corrected typo where "+ " was pasted in from another window. | Joel Sherrill | 1997-08-01 | 2 | -14/+20 |
| | | | | Added c/src/lib/libbsp/m68k/mvme162/consolex/Makefile to list. | ||||
* | Made to work. | Joel Sherrill | 1997-08-01 | 1 | -1/+1 |
* | Removed warnings. | Joel Sherrill | 1997-08-01 | 1 | -2/+2 |
* | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 1997-08-01 | 19 | -11/+1800 |
| | | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 90 | -0/+13689 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 14 | -20/+293 |
* | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 1997-07-31 | 8 | -0/+42 |
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 10 | -47/+246 |
* | Added comment to indicate what the commented out C_PIECES indicated. | Joel Sherrill | 1997-07-31 | 1 | -2/+3 |
* | Corrected bug in Makefile | Joel Sherrill | 1997-07-31 | 1 | -1/+1 |
* | Corrected problem where directories where not being properly created. | Joel Sherrill | 1997-07-31 | 3 | -7/+10 |
| | | | | Change path to indicate expected snapshot date. | ||||
* | corrected typos and changes LANGUAGE to RTEMS-LANGUAGE. | Joel Sherrill | 1997-07-31 | 23 | -39/+51 |
* | Added more info. | Joel Sherrill | 1997-07-31 | 6 | -272/+276 |
* | Added info on what data type is expected by the clock_get directive | Joel Sherrill | 1997-07-31 | 1 | -0/+36 |
| | | | | for the pointer to a "return area".. | ||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 1 | -5/+50 |
* | fixed typo | Joel Sherrill | 1997-07-18 | 3 | -12/+12 |
* | Fixed typo of "::" | Joel Sherrill | 1997-07-18 | 1 | -1/+1 |
* | Reordered specs. | Joel Sherrill | 1997-07-10 | 2 | -8/+8 |
* | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1997-07-10 | 2 | -22/+20 |
* | Added information on different MVME162 models. | Joel Sherrill | 1997-07-10 | 1 | -0/+11 |
* | Strip the trace bit from the SR register when dispatching a thread when | Joel Sherrill | 1997-07-10 | 1 | -3/+5 |
| | | | | | exiting from an ISR. This allows the trace bit to be set on a per task basis and tracing to be limited to that task. | ||||
* | Repository damaged -- file re-added | Joel Sherrill | 1997-07-09 | 3 | -0/+555 |
* | Repository damaged -- files readded. | Joel Sherrill | 1997-07-09 | 3 | -0/+625 |
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 5 | -5/+5 |
| | | | | Ada interface where entry is a keyword. | ||||
* | Used macro instead of hard coded number. | Joel Sherrill | 1997-07-09 | 2 | -2/+2 |
* | Added postswitch extension. | Joel Sherrill | 1997-07-09 | 3 | -0/+6 |
* | Added post switch extension. | Joel Sherrill | 1997-07-09 | 3 | -0/+15 |
* | Corrected typos and spacing. | Joel Sherrill | 1997-07-09 | 3 | -9/+9 |
* | Added mvme162lx bsp configuration. | Joel Sherrill | 1997-07-09 | 2 | -8/+14 |
| | | | | M68040 FPSP was already part of the tree but was not being built. | ||||
* | This code was in the tree but not actually being compiled. There | Joel Sherrill | 1997-07-09 | 34 | -140/+140 |
| | | | | | | | were a number of minor problems which had to be fixed to get it to compile including modifying the compile rule to handle C++ comments, changing the syntax of the include statement, and getting rid of "%" as part of register names. | ||||
* | Added sp, sfc, and fpcsr register defines. | Joel Sherrill | 1997-07-09 | 3 | -0/+12 |
* | Updated to the PowerPC. | Joel Sherrill | 1997-07-02 | 2 | -2/+70 |
* | updated to properly reflect powerpc | Joel Sherrill | 1997-07-02 | 6 | -228/+86 |
* | New files -- PowerPC supplement is based on the SPARC supplement. | Joel Sherrill | 1997-07-01 | 20 | -0/+3307 |
| | | | | | This version has had some initial work done to convert it to be PowerPC specific. | ||||
* | This commit was generated by cvs2svn to compensate for changes in r930, | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | base PDL 2 TEXI | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 |
* | | Initial revision | Joel Sherrill | 1997-06-16 | 7 | -0/+5348 |
* | | new file | Joel Sherrill | 1997-06-04 | 2 | -0/+90 |
