* console/Makefile.am: Add PREINSTALL_DIRS.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* motorola/Makefile.am: Add PREINSTALL_DIRS.
* openpic/Makefile.am: Add PREINSTALL_DIRS.
* pci/Makefile.am: Add PREINSTALL_DIRS.
* residual/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* vme/Makefile.am: Add PREINSTALL_DIRS.
* consolex/Makefile.am: Add PREINSTALL_DIRS.
* irq/Makefile.am: Ditto.
* Makefile.am: Split the blob of *.o into cache.rel, page.rel and
score.rel. Add PREINSTALL_DIRS.
Use automake compilation rules.
* page.c, cpuModel.S: Remove stray blanks.
* configure.ac: Require automake >= 1.8.2.
Add AM_PROG_CC_C_O. Add subdir-objects to AUTOMAKE_OPTIONS.
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am:
* configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS.
* clock/Makefile.am, timer/Makefile.am: Remove.
* r46xx/Makefile.am: Built timer.rel, clock.rel.
* Makefile.am: Remove timer, clock.
* tx39/Makefile.am, mongoosev/Makefile.am, shared/Makefile.am:
* configure.ac: Reflect removing clock/Makefile.am,
timer/Makefile.am.
* Makefile.am: Unconditionally build subdirs sh7032, sh7045, sh7750.
* configure.ac: Merge-in sh7032/configure.ac, sh7045/configure.ac,
sh7750/configure.ac.
Add AM_CONDITIONALS sh7032, sh7045, sh7750.
* sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am:
Reflect changes above. Add PREINSTALL_DIRS.
* sh7032/configure.ac, sh7045/configure.ac, sh7750/configure.ac:
Remove.
* sh7032/.cvsignore, sh7045/.cvsignore, sh7750/.cvsignore:
PR 553/bsps
* custom/mrm332.cfg: Use OBJDUMP variable and turn invocation into a
comment.
PR 555/doc
* sample.t: Fix RTEMS_MAKEFILE_PATH reference.
* Makefile.am: Remove non-existing file "times" from EXTRA_DIST.
* startup/Makefile.am: Remove non-existing files setvec.c,
bspclean.c, exit.c from EXTRA_DIST.
* timer/Makefile.am: Remove non-existing file timer.c from EXTRA_DIST.
* Makefile.am: Remove non-existing times from EXTRA_DIST.
* start/Makefile.am: Remove non-existing cpuboot.c from EXTRA_DIST.
* configure.ac: Add AM_CONDITIONAL(HAS_FPSP).
* README: Fix minor typo.
* Makefile.am: Convert to automake compilation rules.
* configure.ac: Remove.
* .cvsignore: Reflect changes above.
* m68040/Makefile.am: Merge-in m68040/fpsp/Makefile.am.
Use automake-compilation rules.
* m68040/fpsp/Makefile.am: Remove.
* shared/Makefile.am: Use automake compilation rules.
* Makefile.am: Reflect changes above. Remove CPU_SUBDIR.
Remove CHECK_CUSTOM_BSP.
* clock/Makefile.am: Convert to using automake compilation rules.
* mongoosev/Makefile.am: Ditto.
* r46xx/Makefile.am: Ditto.
* shared/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* tx39/Makefile.am: Ditto.
* Makefile.am: Remove conditional subdirs.
* configure.ac: Add subdir-object to AUTOMAKE_OPTIONS.
Require automake-1.8.2. Add AM_PROG_CC_C_O.
* syscall/Makefile.am: Remove.
* reg_win/Makefile.am: Remove.
* cache/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.ams above. Use automake compilation
rules.
* Makefile.am: Remove times from EXTRA_DIST (Non-existant).
* startup/Makefile.am: Remove exit.c, setvec.c from EXTRA_DIST.
* console/Makefile.am: Remove console.c from EXTRA_DIST.
* startup/Makefile.am: Remove bspclean.c, exit.c, setvec.c from
EXTRA_DIST.
* Makefile.am: Remove gdbstub/rtems-stub-glue.c (Non-existent)
* Makefile.am: Remove AUTOMAKE_FILES.
Add ../scripts/setup.def ../COPYING to EXTRA_DIST.
Add rtems.html.in to EXTRA_DIST.
* Makefile.am: Add direct.t sample.t utils.t to EXTRA_DIST.
* Makefile.am: Add ata.t, ide_ctrl.t to EXTRA_DIST.
* Makefile.am: Add tversions.texi.in to EXTRA_DIST.
* startup/Makefile.am: Remove bogus EXTRA_DIST.
* timer/Makefile.am: Remove bogus EXTRA_DIST.
* clock/Makefile.am: Remove bogus EXTRA_DIST.
* gdbsci/Makefile.am: Remove bogus EXTRA_DIST.
* configure.ac: Require automake 1.8.2.
Add AM_PROG_CC_C_0.
* Makefile.am: Use automake compilation rules.
* aclocal/rtems-top.m4: Remove check for version.m4.
* automake/compile.am: Remove LINK_OBJS, LINK_FILES (Unused).
