* | Use <sys/endian.h> | Sebastian Huber | 2017-01-24 | 4 | -39/+17 |
| | | | | Update #2803. | ||||
* | Provide <endian.h> for glibc compatibility | Sebastian Huber | 2017-01-24 | 3 | -0/+6 |
* | bsp/lpc32xx: Fix interrupt controller suppport | Kevin Kirspel | 2017-01-24 | 1 | -10/+14 |
| | | | | | | Enable/Disable vector routines now check for a valid vector. Without these guards, the Enable/Disable vector routines will not work with the interrupt server. | ||||
* | nfsclient: Fix suspicious condition | Sebastian Huber | 2017-01-23 | 1 | -1/+2 |
| | | | | Close #2700. | ||||
* | sys/endian.h: Document FreeBSD origin | Sebastian Huber | 2017-01-23 | 1 | -1/+1 |
* | libchip: Really fix high capacity detection | Sebastian Huber | 2017-01-20 | 1 | -1/+1 |
| | | | | Update #2239. | ||||
* | bsp/beatnik: Remove superfluous check | Sebastian Huber | 2017-01-20 | 1 | -1/+1 |
| | | | | Close #2874. | ||||
* | raspberrypi: fix math inside of sizeof | Gedare Bloom | 2017-01-19 | 1 | -1/+1 |
| | | | | | | | Move the subtraction of 1 for terminator outside of sizeof operator. Closes #2731. | ||||
* | raspberrypi: use signed int for return variable | Gedare Bloom | 2017-01-19 | 1 | -1/+1 |
| | | | | Closes #2873. | ||||
* | smdk2410: delete unused variables | Gedare Bloom | 2017-01-19 | 1 | -8/+1 |
| | | | | Closes #2868. | ||||
* | JFFS2: Fix typo | Sebastian Huber | 2017-01-19 | 1 | -1/+1 |
* | m68k/mcf5225x/*/mc525x5-testsuite.tcfg: Add cdtest | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | m68k/mcf52235/*/mc52235-testsuite.tcfg: Add cdtest | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | arm/lpc32xx/*/lpc32xx_mzx_stage_1-testsuite.tcfg: Add dl05 | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | powerpc/mpc55xxevb/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 6 | -0/+6 |
* | m68k/mcf5225x/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | m68k/mrm332/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | m68k/mcf52235/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | arm/stm32f4/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 2 | -0/+2 |
* | arm/lpc24xx/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 2 | -0/+2 |
* | arm/lpc32xx/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | arm/lpc176x/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 3 | -0/+3 |
* | arm/lm3s69xx/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 3 | -0/+3 |
* | rtems-test-check: Fix to properly process excludes | Stavros Passas | 2017-01-17 | 1 | -1/+5 |
| | | | | Closes #2867. | ||||
* | powerpc/shared/linkcmds.base: Add .rela.rtemsroset and .rela.rtemsrwset | Joel Sherrill | 2017-01-16 | 5 | -0/+10 |
* | atsam: Fix SC16IS752 documentation | Sebastian Huber | 2017-01-16 | 1 | -1/+2 |
* | classic: adjust names of RM postponed job functions | Gedare Bloom | 2017-01-13 | 4 | -15/+20 |
| | | | | closes #2795 | ||||
* | sptests: EDF scheduler overrun handling | Kuan-Hsun Chen | 2017-01-13 | 8 | -1/+316 |
| | | | | Update #2795. | ||||
* | sptests: rate monotonic scheduler overrun handling | Kuan-Hsun Chen | 2017-01-13 | 8 | -0/+349 |
* | Enhancement of the RMS manager for the overrun handling. | Kuan-Hsun Chen | 2017-01-13 | 4 | -9/+176 |
| | | | | | | | | | | | | | | | Three additional functions: rtems_rate_monotonic_postponed_job_count, _Rate_monotonic_Renew_deadline, and _Rate_monotonic_Release_postponed_job. Four refined functions: _Rate_monotonic_Activate, _Rate_monotonic_Block_while_expired, rtems_rate_monotonic_period, _Rate_monotonic_Timeout. Rate_monotonic_Control contains one counter for counting the postponed jobs and one for recording the recent deadline. Update #2795. | ||||
* | posix: shared memory support | Gedare Bloom | 2017-01-13 | 25 | -10/+1196 |
| | | | | | | | | | Add POSIX shared memory manager (Shm). Includes a hook-based approach for the backing memory storage that defaults to the Workspace, and a test is provided using the heap. A test is also provided for the basic use of mmap'ing a shared memory object. This test currently fails at the mmap stage due to no support for mmap. | ||||
* | posix: fix typo in mmap arguments | Gedare Bloom | 2017-01-13 | 1 | -2/+2 |
* | posix: add stub implementations for mman functions | Gedare Bloom | 2017-01-13 | 9 | -0/+222 |
* | posix: move sys/mman.h to newlib and test it in psxhdrs | Gedare Bloom | 2017-01-13 | 16 | -195/+323 |
* | configure: Remove __RTEMS_DO_NOT_INLINE_THREAD_* | Sebastian Huber | 2017-01-13 | 1 | -6/+0 |
* | configure: Remove __RTEMS_HAVE_DECL_SIGALTSTACK__ | Sebastian Huber | 2017-01-13 | 2 | -17/+0 |
* | configure: Remove HAVE_STRUCT__THREAD_QUEUE_QUEUE | Sebastian Huber | 2017-01-13 | 9 | -30/+0 |
* | configure: Remove envlock support | Sebastian Huber | 2017-01-13 | 3 | -124/+1 |
| | | | | This is provided by Newlib itself. | ||||
* | configure: Remove SIZEOF_PTHREAD_SPINLOCK_T | Sebastian Huber | 2017-01-13 | 6 | -65/+2 |
* | configure: Remove HAVE_THREADS_H support | Sebastian Huber | 2017-01-13 | 4 | -11/+1 |
* | configure: Remove HAVE_SEMAPHORE_H support | Sebastian Huber | 2017-01-13 | 4 | -170/+1 |
* | posix: Add pthread_getname_np(), ... | Sebastian Huber | 2017-01-13 | 9 | -0/+218 |
| | | | | | | Add pthread_getname_np() and pthread_setname_np(). Update #2858. | ||||
* | score: Add _Thread_Set_name() | Sebastian Huber | 2017-01-13 | 5 | -0/+53 |
| | | | | | | Add configuration option CONFIGURE_MAXIMUM_THREAD_NAME_SIZE. Update #2858. | ||||
* | score: Add and use _Thread_Get_name() | Sebastian Huber | 2017-01-13 | 7 | -37/+82 |
* | score: Add Thread_queue_Queue::name | Sebastian Huber | 2017-01-13 | 7 | -21/+46 |
* | score: Add and use _Objects_Name_to_string() | Sebastian Huber | 2017-01-13 | 2 | -27/+79 |
* | configure: Add RTEMS_TOOL_CHAIN_ERROR | Sebastian Huber | 2017-01-13 | 1 | -14/+13 |
| | | | | | Stop the build with a common error message in case the tool chain is seriously out of date. | ||||
* | GRETH: Interrupt Handler Uses Wrong Events | Christian Spindeldreier | 2017-01-12 | 1 | -1/+1 |
| | | | | closes #2796. | ||||
* | cpuuse: Call printer only once | Sebastian Huber | 2017-01-12 | 1 | -14/+7 |
* | Fix documentation comment | Sebastian Huber | 2017-01-12 | 1 | -4/+4 |
