* rtems_gdb.texi: Set @setfilename rtems_gdb.info.
* rgdb_specs.texi: Set @setfilename rgdb_specs.info.
* relnotes.texi: Set @setfilename relnotes.info.
* posix_users.texi: Set @setfilename posix_users.info.
* posix1003_1.texi: Set @setfilename posix1003_1.info.
* porting.texi: Set @setfilename porting.info.
* new_chapters.texi: Set @setfilename new_chapters.info.
* networking.texi: Set @setfilename networking.info.
* itron.texi: Set @setfilename itron.info.
* filesystem.texi: Set @setfilename filesystem.info.
* develenv.texi: Set @setfilename develenv.info.
* bsp_howto.texi: Set @setfilename bsp_howto.info.
* ada_user.texi: Set @setfilename ada_user.info.
* FAQ.texi: Set @setfilename FAQ.info.
* configure.ac: Add c4x.
* project.am: Add version.texi hack.
* Makefile.am: Add c4x, cosmetical changes.
* Makefile.am: New.
* c4x.texi, cpumodel.t, timeBSP.t: Various minor changes to get them
building.
* configure.ac: Fix tests for GCC.
* BSP_TIMES, bsp.t, c4x.texi, callconv.t, cpumodel.t, cputable.t,
fatalerr.t, intr_NOTIMES.t, memmodel.t, preface.texi, timeBSP.t:
New files. These should have been added long ago.
* configure.ac: Add check for weak function attribute.
Remove AM_CONDITIONAL([RTEMS_LIBSHELL].
Add AM_CONDITIONAL(LIBSHELL), AM_CONDITIONAL(LIBSERDBG).
* capture/Makefile.am: Use *.a instead of *-tmp.a.
* cpuuse/Makefile.am: Use *.a instead of *-tmp.a.
* devnull/Makefile.am: Use *.a instead of *-tmp.a.
* dummy/Makefile.am: Use *.a instead of *-tmp.a.
* dumpbuf/Makefile.am: Use *.a instead of *-tmp.a.
* monitor/Makefile.am: Use *.a instead of *-tmp.a.
* mw-fb/Makefile.am: Use *.a instead of *-tmp.a.
* rtmonuse/Makefile.am: Use *.a instead of *-tmp.a.
* serdbg/Makefile.am: Use *.a instead of *-tmp.a.
Build iff LIBSERDBG is true.
* shell/Makefile.am: Use *.a instead of *-tmp.a.
Build iff LIBSHELL is true.
* stackchk/Makefile.am: Use *.a instead of *-tmp.a.
* untar/Makefile.am: Use *.a instead of *-tmp.a.
* supplements.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF.
* main.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF.
Append -I $(top_builddir) to TEXI2WWW_ARGS.
* project.am: Add AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF.
Override automake's .dvi.ps:-rule.
* automake/local.am: Remove distclean-local.
Remove PROJECT_TOOLS.
* supplements.am: Use automake rules to build ps, pdf, info.
Various minor changes.
* project.am, main.am: Use automake rules to build ps, pdf, info.
* build45.t: Fix typo in previous patch.
* build45.t: Several fixes and additions.
* project.am: Append $($(PROJECT)_TEXINFOS) to
html-dependencies.
* FAQ.texi: Rename section "Building RTEMS 4.5" into "Building
RTEMS".
build45.t: Remove references to 4.5. Several minor updates.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* wksheets.texi: Remove from CVS.
* timing.texi: Remove from CVS.
* configure.ac: Require autoconf-2.57.
Require automake-1.7.2.
Remove started/pictures/Makefile.
* started/Makefile.am: Merge-in pictures/Makefile.am
* started/pictures/Makefile.am: Remove.
* wrapup/Makefile.am: Fix typo in CPU_PIECES handling.
* automake/compile.am: Remove CLEAN_DEPEND (Unused).
Remove CLOBBER_DEPEND (Unused).
* custom/m2m332.cfg: Fix path to linkcmds_ROM.
* console/sci.c, include/mrm332.h, startup/linkcmds,
startup/linkcmds_ROM: Various updates to make this run properly
from ROM.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/linkcmds-le, startup/linkcmds-le.coff: Add FreeBSD sysctl()
sections.
* startup/linkcmds.rom, startup/linkcmds.rom2ram: Add FreeBSD sysctl()
sections.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add
* startup/linkcmds.dl: Add FreeBSD sysctl() sections.
* ChangeLog: Add FreeBSD sysctl() sections.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* include/Makefile.am: Removed.
* include/erc32.h: Remove (Unused).
* include/.cvsignore: Remove (Obsolete).
