* configure.ac, wrapup/Makefile.am: Remove RDBG.
* aclocal/check-rdbg.m4, aclocal/enable-rdbg.m4, librdbg/.cvsignore,
librdbg/Makefile.am, librdbg/preinstall.am,
librdbg/include/rdbg/rdbg.h, librdbg/include/rdbg/servrpc.h,
librdbg/include/rdbg/i386/rdbg_f.h, librdbg/include/rdbg/i386/reg.h,
librdbg/include/rdbg/m68k/rdbg_f.h, librdbg/include/rdbg/m68k/reg.h,
librdbg/include/rdbg/powerpc/rdbg_f.h,
librdbg/include/rdbg/powerpc/reg.h, librdbg/src/_servtgt.c,
librdbg/src/awk.svc, librdbg/src/excep.c, librdbg/src/ptrace.c,
librdbg/src/rdbg.c, librdbg/src/remdeb.x, librdbg/src/servbkpt.c,
librdbg/src/servcon.c, librdbg/src/servrpc.c, librdbg/src/servtgt.c,
librdbg/src/servtsp.c, librdbg/src/servutil.c,
librdbg/src/i386/excep_f.c, librdbg/src/i386/rdbg_cpu_asm.S,
librdbg/src/i386/rdbg_f.c, librdbg/src/i386/any/remdeb.h,
librdbg/src/i386/any/remdeb_f.x, librdbg/src/i386/any/remdeb_svc.c,
librdbg/src/i386/any/remdeb_xdr.c, librdbg/src/m68k/excep_f.c,
librdbg/src/m68k/rdbg_cpu_asm.S, librdbg/src/m68k/rdbg_f.c,
librdbg/src/m68k/any/remdeb.h, librdbg/src/m68k/any/remdeb_f.x,
librdbg/src/m68k/any/remdeb_svc.c, librdbg/src/m68k/any/remdeb_xdr.c,
librdbg/src/powerpc/excep_f.c, librdbg/src/powerpc/rdbg_cpu_asm.S,
librdbg/src/powerpc/rdbg_f.c,
librdbg/src/powerpc/new_exception_processing/remdeb.h,
librdbg/src/powerpc/new_exception_processing/remdeb_f.x,
librdbg/src/powerpc/new_exception_processing/remdeb_svc.c,
librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c: Removed.
* configure.ac: Remove RDBG.
* Makefile.am, configure.ac, develenv/direct.t: Remove RDBG.
* rgdb_specs/.cvsignore, rgdb_specs/Makefile.am, rgdb_specs/comm.t,
rgdb_specs/conclusion.t, rgdb_specs/daemon.t,
rgdb_specs/gdbinternals.t, rgdb_specs/interfacing.t,
rgdb_specs/intro.t, rgdb_specs/layers.eps, rgdb_specs/layers.jpg,
rgdb_specs/layers.txt, rgdb_specs/objectives.t,
rgdb_specs/process.eps, rgdb_specs/process.jpg,
rgdb_specs/process.txt, rgdb_specs/revision.t,
rgdb_specs/rgdb_specs.texi, rgdb_specs/seqbreak.eps,
rgdb_specs/seqbreak.jpg, rgdb_specs/seqbreak.txt,
rgdb_specs/seqdetach.eps, rgdb_specs/seqdetach.jpg,
rgdb_specs/seqdetach.txt, rgdb_specs/seqinit.eps,
rgdb_specs/seqinit.jpg, rgdb_specs/seqinit.txt, rtems_gdb/.cvsignore,
rtems_gdb/Makefile.am, rtems_gdb/commands.t, rtems_gdb/example.t,
rtems_gdb/intro.t, rtems_gdb/rtems_gdb.texi, rtems_gdb/started.t,
rtems_gdb/swarch.t, rtems_gdb/trouble.t: Removed.
* debug_ada/cmds, debug_c/cmds: Remove RDBG.
* shared/startup/bspstart.c: Split out ShowBATS() so it can be shared
by more BSPs.
* shared/showbats.c: New file.
* ide/pcmcia_ide.c: Added prototype of mpc5200_pcmciaide_dma_blockop to
eliminate warning.
* Makefile.am: Add shared ShowBATS().
* startup/cpuinit.c: Split out BAT initialization into subroutine
that is defined based upon conditionals set. More critically
added code to detect and correct for a buggy U-Boot found on
some Freescale LITE5200B boards which report Flash memory to
be for 32MB at 0xFF000000 instead of 0xFE000000. If we use
the reported information, the system gives an exception just
after the BAT is programmed.
* vectors/vectors_init.c: Turn off message unless verbose is on.
* Makefile.am: ShowBATS() split out to helper routine so sharable by
more BSPs.
* Makefile.am, startup/bspstart.c: Use shared ShowBATS() method.
* Makefile.am, preinstall.am: You need main() to link all applications.
There is no C++ specific way to link currently.
PR 1248/networking
* libnetworking/rtems/rtems_glue.c: Luke Stras <luke@spacequest.com>
reported that when no interfaces are successfully attached, the
default route is broken and may result in a jump to an illegal
address.
PR 1249/build
* configure.ac: Jerry Needell <jerry.needell@unh.edu> reported that the
leon3 was left out of the cache enable logic. Thus the cache
management support code was empty on LEON3 CPUs.
* cpu_asm.S, rtems/score/cpu.h, rtems/score/m68k.h:
Replace M68K_COLDFIRE_ARCH with __mcoldfire__.
* score/inline/rtems/score/priority.inl: Use size_t instead of
uint32_t for array index.
* libnetworking/netinet/in_cksum_m68k.h: Use __mcoldfire__ to
identify coldfire cpus.
* shttpd/log.c: Add preliminary version of SPLIT_SNPRINTF to
work-around bug m68k/coldfire -fomit-frame-pointer bug
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=32307.
* README, build-rpms.sh, rtems.ini, build-exes.sh,
rtems-tools.nsi: Updated to the new 4.8 build plus a new
installer.
* autoconf.def, automake.def, ba-wrap.sh, build-autotools.sh,
msys-path.nsi, rtems-autotools.nsi, target-section-text,
upload.sh, version: New to version 4.8. Autotools is built when
installing.
* custom/Linux-posix.cfg: Use -O2.
* custom/rbtx4938.cfg: Add missing -O2.
* custom/rtl22xx.cfg: Adjust indentation.
* custom/virtex.cfg: Use -O2.
* nfsclient/src/dirutils.c: Use PATH_MAX instead of MAXPATHLEN.
* wrapup/Makefile.am: Create archive from a file for hosts
with a limited command line size.
* wrapup/Makefile.am: Create archive from a file for hosts with
* include/rtems/bspIo.h, include/rtems/pci.h:
Add extern "C" guards. Reported by
Robert S. Grimes <rsg@alum.mit.edu>.
* nfsclient/src/rpcio.c: Use size_t instead of uint32_t for message
sizes.
* configure.ac: Add nfsclient.
* nfsclient/Makefile.am: New.
* nfsclient/proto/Makefile, nfsclient/Makefile,
nfsclient/src/Makefile: Remove.
* nfsclient/ChangeLog: Remove (Rename into ChangeLog.slac).
* nfsclient/ChangeLog.slac: New (Renamed from ChangeLog).
* nfsclient/README, nfsclient/proto/nfs_prot_xdr.c,
nfsclient/proto/mount_prot.x, nfsclient/proto/mount_prot_xdr.c,
nfsclient/proto/Makefile, nfsclient/proto/mount_prot.h,
nfsclient/proto/nfs_prot.h, nfsclient/proto/nfs_prot.x,
nfsclient/Makefile, nfsclient/ChangeLog, nfsclient/src/dirutils.c,
nfsclient/src/nfsTest.c, nfsclient/src/rpcio.h,
nfsclient/src/nfs.modini.c, nfsclient/src/xdr_mbuf.c,
nfsclient/src/cexphelp.c, nfsclient/src/Makefile,
nfsclient/src/sock_mbuf.c, nfsclient/src/nfs.c,
nfsclient/src/librtemsNfs.h, nfsclient/src/rpcio.modini.c
nfsclient/src/rpcio.c, nfsclient/rtems-filesystem-patch,
nfsclient/rfc1094.txt, nfsclient/LICENSE: Import from rtems-nfs-1.5.
which included commits to RCS files with non-trunk default branches.
* libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuusagereset.c,
score/src/timespecdivide.c: Fix various math and reporting bugs. Now
the time appears to be reported correctly and add up to what is
expected.
* cpuuse/init.c: Do not delete the Init task. Leaving it suspended lets
the CPU Usage Report include it. If it is deleted, the CPU time it
had consumed is not listed later in the report.
