* Makefile.am, configure.ac: Added new test loopback which shows how to
use the loopback interface. Thank you Eric Norum for a portable
target independent test which exercises the TCP/IP. This should
prevent massive failures in the TCP/IP stack from reaching the
street.
* loopback/.cvsignore, loopback/Makefile.am, loopback/README,
loopback/init.c, loopback/loopback.scn: New files.
street.
* setup.def, sparc-solaris-binutils.spec.in: Updated and
used to build sparc-solaris 3.2.1-1 C language only.
2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
2001-04-16 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Added missing files.
* setup.def: New shot using gcc 3.0.4 RPMs.
* sparc-solaris-binutils.spec.in: Switched to bz2 file.
* sparc-solaris-gcc.spec.in: Use gcc3 file naming for archive
and use find to pick up all files.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-02-08 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: New file.
2001-02-05 Joel Sherrill <joel@OARcorp.com>
* Makefile.am: New file, missed previously.
2004-02-05 Joel Sherrill <joel@OARcorp.com>
* ChangeLog, configure.ac, setup, setup.def,
sparc-solaris-binutils.spec.in, sparc-solaris-gcc.spec.in,
sparc-solaris-libs.spec.in: New files.
* i386-cygwin-gcc.spec.in, setup.def: Enabled building of GNAT for
revision 2.
* i386-cygwin-gcc.spec.in, i386-cygwin-mingw.spec.in, setup.def:
Updated to current Cygwin versions and fixed some minor nits in
the specifications.
2003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* setup.def: Update to binutils-20021117-1.
* i386-cygwin-binutils.spec.in: Reflect update to binutils-20021127-1.
Adaptations to RH-8.0/rpm-4.1.
Add autom4te*cache.
* i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in,
i386-cygwin-w32api.spec.in: Modified group.
2001-01-22 Joel Sherrill <joel@OARcorp.com>
* i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in,
i386-cygwin-w32api.spec.in, setup.def: Updated to reflect latest
versions and packaging.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-09-13 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Corrected for missing files.
2001-08-31 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Missed in previous commit.
2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in,
i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in,
i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def:
New files that support building RPMs for Linux hosted cross compilers
targeting Cygwin.
* buildalltar.in, setup.def: Tool update including binaries for Cygwin
with a special RTEMS user account.
* libc/getproto.c, libc/getprotoname.c: modification to call
getprotoent_static() if fopen() on /etc/protocols fails.
* stackchk/check.c: Fix problem where _Objects_Get_information()
will dereference a null pointer when checking the interrupt stack.
If there's something at 0, you may be ok at run time but it is wrong.
* monitor/mon-command.c: Correct two potential NULL references.
* src/ptimer1.c: Correct problem which could lead to overflow in time
math.
* src/blkdev.c: Per PR331 fix bug which is tripped by writing 512 byte
blocks to 512 byte aligned positions.
* index.html.in: Fix duplicate c4x entry.
* configure.ac: Add rtemsdoc.
* Makefile.ac: Add rtemsdoc.
* rtemsdoc/README: New.
* rtemsdoc/.cvsignore: New.
* rtemsdoc/Makefile.am: New.
* rtemsdoc/mkspec.in: New.
* rtemsdoc/rtemsdoc.spec.in: New.
* rtemsdoc/supplement.add.in: New.
* rtemsdoc/templ.add.in: New.
* index.html.in: Add c4x.
* c_user.texi: Set @setfilename c_user.info.
* template.texi: Set @setfilename template.info.
* sparc.texi: Set @setfilename sparc.info.
* sh.texi: Set @setfilename sh.info.
* powerpc.texi: Set @setfilename powerpc.info.
* mips64orion.texi: Set @setfilename mips64orion.info.
* mips.texi: Set @setfilename mips.info.
* m68k.texi: Set @setfilename m68k.info.
* i960.texi: Set @setfilename i960.info.
* i386.texi: Set @setfilename i386.info.
* hppa1_1.texi: Set @setfilename hppa1_1.info.
* c4x.texi: Set @setfilename c4x.info.
* arm.texi: Set @setfilename arm.info.
* started_ada.texi: Set @setfilename started_ada.info.
* started.texi: Set @setfilename started.info.
* rtems_gdb.texi: Set @setfilename rtems_gdb.info.
* rgdb_specs.texi: Set @setfilename rgdb_specs.info.
* relnotes.texi: Set @setfilename relnotes.info.
* posix_users.texi: Set @setfilename posix_users.info.
* posix1003_1.texi: Set @setfilename posix1003_1.info.
* porting.texi: Set @setfilename porting.info.
* new_chapters.texi: Set @setfilename new_chapters.info.
* networking.texi: Set @setfilename networking.info.
* itron.texi: Set @setfilename itron.info.
* filesystem.texi: Set @setfilename filesystem.info.
* develenv.texi: Set @setfilename develenv.info.
* bsp_howto.texi: Set @setfilename bsp_howto.info.
* ada_user.texi: Set @setfilename ada_user.info.
* FAQ.texi: Set @setfilename FAQ.info.
* configure.ac: Add c4x.
* project.am: Add version.texi hack.
* Makefile.am: Add c4x, cosmetical changes.
* Makefile.am: New.
* c4x.texi, cpumodel.t, timeBSP.t: Various minor changes to get them
building.
* configure.ac: Fix tests for GCC.
