* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 11 | -51/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 17 | -78/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 33 | -161/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 84 | -400/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 44 | -174/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 56 | -261/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 27 | -131/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 47 | -127/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 3 | -9/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 109 | -217/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 6 | -16/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 6 | -18/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 10 | -30/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 36 | -111/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 4 | -12/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 13 | -42/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 48 | -144/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 5 | -14/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 8 | -25/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 20 | -68/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -8/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -7/+0 |
* | Remove. | Ralf Corsépius | 2012-05-04 | 1 | -0/+0 |
* | nds/linkcmds - Remove execute permission | Joel Sherrill | 2012-05-03 | 1 | -0/+0 |
* | libcpu misc m68k and sh - Correct formatting and remove weird Id strings | Joel Sherrill | 2012-05-03 | 6 | -59/+41 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 100 | -85/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | Libcpu misc files - Remove execute permission on source files. | Joel Sherrill | 2012-05-03 | 10 | -0/+0 |
* | rtems-message_queue.adb - Convert DOS to UNIX CF/LF | Joel Sherrill | 2012-05-03 | 1 | -245/+245 |
* | psxaio01/psxaio02 - Formatting corrections | Joel Sherrill | 2012-05-03 | 2 | -18/+18 |
| | | | | | The file header was moved over one space. These two were the only files in the testsuite which did this. | ||||
* | sp07/buffered_io.c add missing copyright | Joel Sherrill | 2012-05-03 | 1 | -1/+6 |
| | | | | Date and ownership determined from file history. | ||||
* | smdk2410 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 1 | -2/+0 |
* | gp32 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 1 | -3/+0 |
* | pc386 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 7 | -14/+0 |
* | libchip hcms29xx - Remove odd $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 5 | -17/+1 |
