* consolex/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
* tools/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Cosmetics.
* spurious/Makefile.am: Cosmetics.
* i2c/Makefile.am: Cosmetics.
* nvram/Makefile.am: Cosmetics.
* start/Makefile.am: Cosmetics.
* Makefile.am: Remove C_FILES (Unused).
* configure.ac: Remove shared/comm/Makefile, shared/irq/Makefile.
* irq/Makefile.am: Add preinstallation dirstamp support.
* Makefile.am: Merge-in comm/Makefile.am, irq/Makefile.am
* comm/Makefile.am: Remove.
* irq/Makefile.am: Remove.
* configure.ac: Remove shared/io/Makefile, shared/comm/Makefile,
shared/pci/Makefile, shared/irq/Makefile.
* io/.cvsignore: Remove.
* pci/Makefile.am, irq/Makefile.am, io/Makefile.am,
* Makefile.am: Merge-in Makefile.ams above.
* 3c509/Makefile.am: Cosmetics.
* console/Makefile.am: Add preinstallation dirstamp support.
* ide/Makefile.am: Cosmetics.
* ne2000/Makefile.am: Cosmetics.
* start/Makefile.am: Add compilation dirstamp support.
* wd8003/Makefile.am: Cosmetics.
* Makefile.am: Add dirstamps to preinstallation.
* Makefile.am: Add dirstamp support to preinstallation.
* erc32sonic/Makefile.am: Cosmetics.
* gnatsupp/Makefile.am: Cosmetics.
* leon_open_eth/Makefile.am: Correct paths to automake/*.am..
PR 538/bsps:
* wrapup/Makefile.am: Add leon_open_eth.rel
* Makefile.am: Remove include_rtems_score_HEADERS.
Reformat for preinstallation dirstamp support.
* Makefile.am: Reformat for preinstallation dirstamp support.
* start/Makefile.am: Remove empty lines.
* bootloader/Makefile.am: Put all files into EXTRA_DIST.
* vme/Makefile.am: Ditto.
* console/Makefile.am: Move H_FILES to include_bsp_HEADERS.
* irq/Makefile.am: Ditto.
* motorola/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* residual/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* Makefile.am: Remove empty lines.
* clock/Makefile.am: Ditto.
* include/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* configure.ac: Remove libchip/ide/Makefile, libchip/network/Makefile,
libchip/serial/Makefile, libchip/rtc/Makefile.
* ide/Makefile.am, network/Makefile.am, rtc/Makefile.am,
serial/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.am above.
Add preinstallation + compilation dirstamp support.
* Makefile.am: Add dependencies to $(ARCH)/$(dirstamp).
Reformat.
* target.cfg.in: Remove RTEMS_USE_MACROS.
* Makefile.inc.in: Remove RTEMS_USE_MACROS.
* aclocal/enable-inlines.m4: Removed.
* configure.ac: Remove RTEMS_ENABLE_INLINES.
* shmdr/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Remove all-local: $(ARCH).
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* gnatsupp/Makefile.am: Remove all-local: $(ARCH).
* leon_open_eth/Makefile.am: Remove all-local: $(ARCH).
* erc32sonic/Makefile.am: Remove all-local: $(ARCH).
* gdbsci/Makefile.am: Remove all-local: $(ARCH).
* scitab/Makefile.am: Remove all-local: $(ARCH).
* trap34/Makefile.am: Remove all-local: $(ARCH).
* hw_init/Makefile.am: Remove all-local: $(ARCH).
* PCI_bus/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
* nvram/Makefile.am: Remove all-local: $(ARCH).
* pci/Makefile.am: Remove all-local: $(ARCH).
* universe/Makefile.am: Remove all-local: $(ARCH).
* irq/Makefile.am: Remove all-local: $(ARCH).
* motorola/Makefile.am: Remove all-local: $(ARCH).
* openpic/Makefile.am: Remove all-local: $(ARCH).
* residual/Makefile.am: Remove all-local: $(ARCH).
* vme/Makefile.am: Remove all-local: $(ARCH).
