* | 2009-02-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-27 | 5 | -0/+91 |
| | | | | | | | | * posix_users/preface.texi, shell/preface.texi: Add stock acknowledgement paragraphs that are required when excerpting and reusing text from POSIX standards per the agreement at * common/opengroup_manpage_acknowledgement.texi, common/opengroup_preface_acknowledgement.texi: New files. | ||||
* | Format. | Joel Sherrill | 2009-02-27 | 1 | -0/+1 |
* | 2009-02-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-27 | 2 | -7/+26 |
| | | | | | | PR 1387/doc * user/intr.t: Add Interrupt Manager services to list of services callable from ISR. | ||||
* | 2009-02-27 Daniel Hellstrom <daniel@gaisler.com> | Joel Sherrill | 2009-02-27 | 2 | -1/+7 |
| | | | | | | PR 1386/bsps * shared/start.S: Stack space not correctly initialized. Causes failures on unoptimized applications. | ||||
* | 2009-02-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-27 | 2 | -5/+29 |
| | | | | | * bspgetworkarea.c: Add check to determine if current stack pointer is in work area. | ||||
* | 2009-02-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-27 | 2 | -5/+25 |
| | | | | | * shared/startup/bspgetworkarea.c: Add check to determine if current stack pointer is in work area. | ||||
* | added missing files | Thomas Doerfler | 2009-02-27 | 9 | -0/+1676 |
* | * README: Added NCS. | Thomas Doerfler | 2009-02-27 | 23 | -124/+635 |
| | | | | | | | | | | | | | | | * Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot. | ||||
* | * bsp_specs: Added crtbegin.o and crtend.o to support global C++ | Thomas Doerfler | 2009-02-27 | 2 | -2/+7 |
| | | | | constructors and destructors. | ||||
* | Adapt to modified shell configuration | Thomas Doerfler | 2009-02-27 | 2 | -2/+6 |
* | PR 1356 | Thomas Doerfler | 2009-02-27 | 2 | -23/+260 |
| | | | | | * libchip/i2c/spi-sd-card.c: Added support for high capacity and MMC cards. | ||||
* | * rtems/powerpc/registers.h: Added Freescale Book E Implementation | Thomas Doerfler | 2009-02-27 | 2 | -0/+33 |
| | | | | | Standards (EIS) special purpose register definitions for MMU and L1 cache. | ||||
* | * libmisc/shell/shell.c, libmisc/shell/shell.h: Changed type for | Thomas Doerfler | 2009-02-27 | 4 | -60/+76 |
| | | | | | | | | | boolean values from 'int' to 'bool'. Added option 'login' to enable or disable a login prompt. Changed intialization of global shell environment to static initialization. Changed stack size type to 'size_t' conforming to classic API. * libmisc/shell/shellconfig.h: Fixed some typos. | ||||
* | 2009-02-26 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-26 | 2 | -7/+5 |
| | | | | * startup/cpu.c: Now compiles. Does not run. | ||||
* | 2009-02-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-26 | 4 | -10/+23 |
| | | | | | * shared/clock/ckinit.c, shared/start/start.S, shared/timer/timer.c: Run better on simulator. Timer is probably not right yet but | ||||
* | 2009-02-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-26 | 3 | -10/+16 |
| | | | | | * configure.ac, include/bsp.h: Run better on simulator. Timer is probably not right yet but | ||||
* | 2009-02-26 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-26 | 2 | -5/+16 |
| | | | | | * shared/startup/bspgetworkarea.c: Make debug messages same as standard. | ||||
* | 2009-02-26 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-26 | 2 | -1/+11 |
| | | | | * irq/irq.c: Add bsp_interrupt_handler_default() so this BSP will link. | ||||
* | 2009-02-25 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-25 | 3 | -2/+6 |
| | | | | * clock/clock.c, include/bsp.h: Make bsp idle thread names match. | ||||
* | 2009-02-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-25 | 2 | -117/+24 |
| | | | | | * shared/clock/ckinit.c: Use shared Clock Driver Template and support fast idle on simulator. | ||||
* | 2009-02-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-25 | 2 | -0/+7 |
| | | | | * README: Add fast idle information. | ||||
* | 2009-02-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-25 | 4 | -3/+39 |
| | | | | | | | * Makefile.am, configure.ac: Add SIMULATOR_FAST_IDLE, BSP_PRESS_KEY_FOR_RESET, and BSP_RESET_BOARD_AT_EXIT. Use the standard bsp_cleanup code. * README: New file. Include instructions on gdb simulator. | ||||
* | 2009-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-25 | 1 | -0/+4 |
| | | | | * Makefile.am: Rework. | ||||
* | Regenerate. | Ralf Corsepius | 2009-02-25 | 1 | -1/+4 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-02-25 | 1 | -1/+1 |
* | Disable lm32 simulator on mingw32. | Ralf Corsepius | 2009-02-25 | 1 | -0/+3 |
* | Regenerate. | Ralf Corsepius | 2009-02-25 | 1 | -1/+6 |
* | Add gdb-6.8.50.20090224-rtems4.10-20090225.diff | Ralf Corsepius | 2009-02-25 | 1 | -0/+5 |
* | New. | Ralf Corsepius | 2009-02-25 | 1 | -0/+17143 |
| | | | | | | Rebase gdb-6.8-rtems4.10-20090122.diff patch against gcc-cvs HEAD. Add lm32 sim. Various fixes to get lm32 sim building. | ||||
* | Regenerate, fix spec file. | Ralf Corsepius | 2009-02-24 | 13 | -26/+65 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-02-24 | 13 | -13/+13 |
* | Regenerate. | Ralf Corsepius | 2009-02-24 | 13 | -76/+76 |
* | GCC_RPMREL = 8 | Ralf Corsepius | 2009-02-24 | 13 | -13/+13 |
* | newlib-1.17.0-rtems4.10-20090224.diff | Ralf Corsepius | 2009-02-24 | 13 | -13/+13 |
* | * libc/unix/ttyname.c: Sync with newlib-cvs. | Ralf Corsepius | 2009-02-24 | 1 | -0/+686 |
| | | | | * configure.host: Add -DHAVE_BLKSIZE to newlib_cflags. | ||||
* | Regenerate. | Ralf Corsepius | 2009-02-24 | 1 | -1/+1 |
* | Use "%{?suse}" >= "10.3" to detect suse | Ralf Corsepius | 2009-02-24 | 1 | -1/+1 |
* | New. | Ralf Corsepius | 2009-02-24 | 1 | -0/+223 |
* | Activate GDB. | Ralf Corsepius | 2009-02-24 | 1 | -6/+5 |
* | Use a gdb-snapshot. | Ralf Corsepius | 2009-02-24 | 1 | -2/+3 |
* | Disable python. | Ralf Corsepius | 2009-02-24 | 1 | -0/+3 |
* | 2009-02-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-23 | 1 | -0/+1 |
| | | | | * include/bsp.h: Conditionally include rtems/rtems_bsdnet.h. | ||||
* | Conditionally include rtems/rtems_bsdnet.h. | Ralf Corsepius | 2009-02-23 | 1 | -0/+6 |
* | 2009-02-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-23 | 1 | -0/+5 |
| | | | | | * configure.ac: Add RTEMS_CHECK_NETWORKING. * Makefile.am: Rework. | ||||
* | Rework. | Ralf Corsepius | 2009-02-23 | 1 | -14/+25 |
* | Add RTEMS_CHECK_NETWORKING. | Ralf Corsepius | 2009-02-23 | 1 | -0/+4 |
* | Regenerate. | Ralf Corsepius | 2009-02-23 | 2 | -0/+833 |
* | Update. | Ralf Corsepius | 2009-02-23 | 1 | -2/+2 |
* | binutils-2.19.51-20090222. | Ralf Corsepius | 2009-02-23 | 1 | -2/+2 |
* | Activate GCC-4.3.3 | Ralf Corsepius | 2009-02-23 | 1 | -12/+11 |
