* | Add lm32 | Ralf Corsepius | 2009-02-23 | 2 | -0/+5245 | |
* | Add lm32. | Ralf Corsepius | 2009-02-22 | 1 | -1/+2 | |
* | New. | Ralf Corsepius | 2009-02-22 | 6 | -0/+84 | |
* | Add lm32 | Ralf Corsepius | 2009-02-22 | 1 | -0/+1 | |
* | New. | Ralf Corsepius | 2009-02-22 | 2 | -0/+136 | |
* | Regenerate. | Ralf Corsepius | 2009-02-22 | 1 | -1/+4 | |
* | Bump version. | Ralf Corsepius | 2009-02-22 | 1 | -1/+1 | |
* | Add @SOURCES@, PATCH0. | Ralf Corsepius | 2009-02-22 | 1 | -1/+2 | |
* | Add automake-sources.add. | Ralf Corsepius | 2009-02-22 | 1 | -3/+5 | |
* | 2009-02-21 Michael Walle <michael@walle.cc> | Joel Sherrill | 2009-02-21 | 2 | -1/+8 | |
| | | | | * startup/linkcmds: Add new sections. | |||||
* | 2009-02-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-20 | 1 | -0/+4 | |
| | | | | * Makefile.am: Fix breakage introduced in 2009-02-13 changes. | |||||
* | New. | Ralf Corsepius | 2009-02-20 | 1 | -0/+2 | |
* | Regenerate. | Ralf Corsepius | 2009-02-20 | 1 | -0/+4 | |
* | 2009-02-20 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-20 | 1 | -0/+5 | |
| | | | | | * include/sys/priority.h: New. * Makefile.am: Add include/sys/priority.h | |||||
* | Add include/sys/priority.h. | Ralf Corsepius | 2009-02-20 | 1 | -0/+1 | |
* | Regenerate. | Ralf Corsepius | 2009-02-20 | 36 | -94/+94 | |
* | Split ttyname.c/ttyname_r.c | Ralf Corsepius | 2009-02-20 | 1 | -0/+651 | |
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 2 | -0/+5 | |
| | | | | * aclocal/bsp-alias.m4: Add simsh2e. | |||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 2 | -0/+22 | |
| | | | | * custom/simsh2e.cfg: New file. | |||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 4 | -41/+164 | |
| | | | | | * shared/irq/irq.c, shared/irq/irq.h, shared/irq/irq_asm.S: Add shared interrupt support to i386. | |||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 2 | -2/+6 | |
| | | | | * shared/irq/irq.c: Spacing. | |||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 3 | -13/+15 | |
| | | | | | * include/rtems/irq-extension.h, include/rtems/irq.h: Spelling errors and spacing. | |||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 2 | -0/+10 | |
| | | | | | | * libnetworking/rtems/rtems_bsdnet_internal.h: Re-add boolean when building BSD code. This is used by at least one of the BSD NIC drivers I am currently porting. I am trying out | |||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 3 | -2/+7 | |
| | | | | | * libchip/network/dec21140.c, libchip/network/elnk.c: Make sure this is enabled on x86. | |||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 2 | -0/+77 | |
| | | | | * shell/rtems.t: Add halt command. | |||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 4 | -6/+59 | |
| | | | | | | * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Add halt command to shell which results in the shutting RTEMS down. * libmisc/shell/main_halt.c: New file. | |||||
* | Regenerate. | Ralf Corsepius | 2009-02-19 | 14 | -72/+72 | |
* | Move %{?dist} handling to rtems4.10/*.am. | Ralf Corsepius | 2009-02-19 | 17 | -66/+66 | |
* | Update. | Ralf Corsepius | 2009-02-19 | 12 | -12/+12 | |
* | Bump GCC_RPMREL, NEWLIB_RPMREL. | Ralf Corsepius | 2009-02-19 | 12 | -24/+24 | |
* | 2009-02-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-19 | 1 | -0/+386 | |
| | | | | | | | | | * libc/sys/rtems/sys/param.h: Update copyright notice from FreeBSD. Remove HZ. Add #include <sys/priority.h> Remove priority handling (moved to sys/priority.h). Remove CLBYTES (Unused, abandoned in BSD). | |||||
* | 2009-02-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-17 | 2 | -2/+12 | |
| | | | | | | * rtems/score/sh.h: SH2E and SH3E have a DSP rather than an FPU. They are not compatible. We currently only support the FPU found on the SH3 and SH4. | |||||
* | 2009-02-17 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-02-17 | 2 | -17/+40 | |
| | | | | | PR 1371/bsps * network/network.c: mvme167 network driver buggy. | |||||
* | 2009-02-17 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-02-17 | 2 | -2/+6 | |
| | | | | | PR 1371/bsps * custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF. | |||||
* | 2009-02-17 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-02-17 | 2 | -4/+17 | |
| | | | | | | PR 1370/bsps * console/console.c: mvme167 console driver BSP_output_char fails to convert \n -> \n\r | |||||
* | 2009-02-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-17 | 2 | -2/+6 | |
| | | | | | | PR 1377/shell * libmisc/shell/main_netstats.c: Remove #if 0 which should not have been there anyway. | |||||
* | 2009-02-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-17 | 2 | -0/+6 | |
| | | | | * custom/uC5282.cfg: Add cvs Id. | |||||
* | 2009-02-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-17 | 2 | -9/+6 | |
* | 2009-02-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-13 | 3 | -15/+28 | |
| | | | | * Makefile.am, preinstall.am: Use stub tm27.h. | |||||
* | 2009-02-13 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-13 | 2 | -6/+6 | |
| | | | | * new-exceptions/cpu.c: Correct prototype of _CPU_Initialize. | |||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 2 | -1/+6 | |
| | | | | | * startup/setvec.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | |||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 3 | -2/+7 | |
| | | | | | * clock/clock.c, include/bsp.h: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | |||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 8 | -5/+24 | |
| | | | | | * startup/bspstart.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | |||||
| | | | | | * include/bsp.h, startup/bspstart.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | |||||
| | | | | | * shared/misc/m68kidle.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | |||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 4 | -5/+11 | |
| | | | | | | * sapi/include/rtems/config.h, score/include/rtems/score/thread.h, score/src/threadidlebody.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | |||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 2 | -3/+8 | |
| | | | | | * porting/idlethread.t: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | |||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 30 | -24/+74 | |
| | | | | | * cpu.c, rtems/score/cpu.h: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | |||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 4 | -3/+13 | |
| | | | | | * rtems/score/cpu.h: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | |||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 4 | -2/+12 | |
| | | | | | * cpu.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. |
