* | Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-29 | 52 | -641/+3161 |
| | | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working) | ||||
* | Made sure POSIX would build with MP enabled. | Joel Sherrill | 1999-11-29 | 14 | -20/+254 |
* | Updated. | Joel Sherrill | 1999-11-29 | 3 | -276/+324 |
* | Removed bad descriptions of mount() and umount(). Added shell of an | Joel Sherrill | 1999-11-29 | 1 | -124/+25 |
| | | | | accurate description. | ||||
* | Fixed spacing. | Joel Sherrill | 1999-11-29 | 3 | -3/+3 |
* | Added chapter of list of routines provided by libm. | Joel Sherrill | 1999-11-24 | 4 | -17/+102 |
* | New file. | Joel Sherrill | 1999-11-24 | 1 | -0/+154 |
* | Added routines included by C library. | Joel Sherrill | 1999-11-24 | 4 | -2/+336 |
* | Added information on RTEMS Time/Date Representatin. | Joel Sherrill | 1999-11-24 | 3 | -2/+120 |
* | Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-24 | 124 | -2456/+3588 |
| | | | | which (among other things) converted the mptests to automake. | ||||
* | Added sem_timedwait to bullet list at front of chapter. | Joel Sherrill | 1999-11-23 | 1 | -0/+1 |
* | Added descriptions for bullet list and routine section headings. | Joel Sherrill | 1999-11-23 | 1 | -8/+8 |
* | changed version to 19991123-rc | Joel Sherrill | 1999-11-23 | 1 | -1/+1 |
* | Added Timer Manager Chapter. | Joel Sherrill | 1999-11-23 | 2 | -1/+8 |
* | Fixed line too long. | Joel Sherrill | 1999-11-23 | 1 | -2/+2 |
* | New file. | Joel Sherrill | 1999-11-23 | 1 | -0/+196 |
* | Readding files mistakenly removed. | Joel Sherrill | 1999-11-23 | 40 | -0/+2289 |
* | Patch rtems-rc-19991117-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-11-23 | 12 | -16/+32 |
| | | | | | | | * the PACKHEX etc problem * prevents the *.rels being removed inside the build-tree * a typo which only shows for when MP is activated * Alters some custom/*cfg files | ||||
* | Readding Makefile.in's accidentally removed. | Joel Sherrill | 1999-11-23 | 1 | -0/+33 |
* | *** empty log message *** | Joel Sherrill | 1999-11-23 | 1 | -27/+21 |
* | Moved pmacros.h to include not support/include. | Joel Sherrill | 1999-11-23 | 38 | -131/+42 |
* | Patch rtems-rc-19991117-15.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 4 | -132/+75 |
| | | | | to convert the tests/support directory from Makefile.in to Makefile.am. | ||||
* | Missed in previous automake conversion patches from Ralf Corsepius | Joel Sherrill | 1999-11-23 | 14 | -0/+492 |
| | | | | <corsepiu@faw.uni-ulm.de>. | ||||
* | Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 30 | -235/+1246 |
| | | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 16 | -36/+26 |
| | | | | to convert the libmisc directory from Makefile.in to Makefile.am. | ||||
* | Added clock06.c to the compile list. | Joel Sherrill | 1999-11-23 | 2 | -8/+4 |
* | Files only used by psxfile01, so moved there. | Joel Sherrill | 1999-11-23 | 9 | -11/+202 |
* | Test psxfile02 unused and removed. | Joel Sherrill | 1999-11-23 | 3 | -5/+2 |
* | Unused and removed. | Joel Sherrill | 1999-11-23 | 4 | -119/+0 |
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 81 | -2020/+2094 |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | ||||
* | Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 2 | -0/+46 |
| | | | | to convert the libtests directory from Makefile.in to Makefile.am. | ||||
* | Patch rtems-rc-19991117-13.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 28 | -589/+718 |
* | Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 95 | -2297/+2794 |
| | | | | to convert the tmtests directory from Makefile.in to Makefile.am. | ||||
* | Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 83 | -3219/+1126 |
| | | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib." | ||||
* | Added projects chapter to FAQ. | Joel Sherrill | 1999-11-23 | 3 | -2/+122 |
* | Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 236 | -535/+709 |
* | Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 78 | -78/+4 |
| | | | | to fix some minor bugs in the conversion to automake. | ||||
* | Patch rtems-rc-19991117-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 32 | -720/+928 |
| | | | | to convert the sample tests to automake. | ||||
* | Converted to automake. | Joel Sherrill | 1999-11-22 | 88 | -3004/+2240 |
* | Now replaced by an automake file. | Joel Sherrill | 1999-11-22 | 1 | -360/+0 |
* | Corrected. | Joel Sherrill | 1999-11-22 | 1 | -5/+1 |
* | Added ifndef around build_time so pmacros.h and tmacros.h could be included | Joel Sherrill | 1999-11-22 | 2 | -0/+4 |
| | | | | by the same application. | ||||
* | tmitrontests directory listed twice. | Joel Sherrill | 1999-11-22 | 1 | -1/+1 |
* | Fixed dispatching and cleaned up code. | Jennifer Averett | 1999-11-22 | 4 | -60/+28 |
* | + Corrected enable/disable of dispatch. | Jennifer Averett | 1999-11-22 | 2 | -46/+62 |
| | | | | + Cleaned up code. | ||||
* | + Updated comments. | Jennifer Averett | 1999-11-22 | 2 | -18/+40 |
| | | | | + Corrected enable/disable of dispatch. | ||||
* | + Corrected bug in error check. | Jennifer Averett | 1999-11-22 | 2 | -4/+2 |
* | + Added description of routine to comment. | Jennifer Averett | 1999-11-22 | 2 | -0/+8 |
* | + Corrected error processing code. | Jennifer Averett | 1999-11-22 | 2 | -28/+30 |
* | + Added checks for NULL and NULL string names (for sem_open & sem_unlink). | Jennifer Averett | 1999-11-22 | 2 | -2/+14 |
