* | or1k: Send halt signal to or1k simulators when rtems terminates | Hesham ALMatary | 2015-04-02 | 2 | -1/+11 |
* | bsp/altera-cyclone-v: Fix define usage | Sebastian Huber | 2015-04-02 | 1 | -1/+1 |
* | capture: Define __rtld_tbg_lock | Sebastian Huber | 2015-04-02 | 1 | -0/+2 |
* | simsh*: Disable interrupt critical section tests | Joel Sherrill | 2015-04-01 | 4 | -0/+4 |
| | | | | These do not run reliably on this simulator. | ||||
* | jmr3904-testsuite.tcfg: New file | Joel Sherrill | 2015-04-01 | 1 | -0/+9 |
* | disable-intrcritical-tests.tcfg: New file | Joel Sherrill | 2015-04-01 | 1 | -0/+30 |
| | | | | | | This file contains the list of interrupt critical section tests. There are some simulators these are unreliable on so they should just be ignored. | ||||
* | psxtmtests: Use timeout in more distant future | Alexander Krutwig | 2015-03-31 | 1 | -2/+3 |
| | | | | Adds future compatibility with strict monontonic software timestamps. | ||||
* | fstests: Increase stack size for symlink loop test | Alexander Krutwig | 2015-03-31 | 1 | -1/+1 |
* | fstests/fssymlink: Typo | Alexander Krutwig | 2015-03-31 | 1 | -1/+1 |
* | testsuites: dl02 needs an FPU init task. | Chris Johns | 2015-03-31 | 1 | -1/+1 |
* | libmisc/shell: Add the rtrace command for buffered tracing support. | Chris Johns | 2015-03-31 | 7 | -2/+1051 |
| | | | | | The rtrace command interfaces to the RTEMS Trace Linker's trace buffering data allowing users to capture and report trace data. | ||||
* | TMS570: Add board reset code to bsp_reset | Martin Galvan | 2015-03-31 | 2 | -22/+34 |
* | TMS570: Enable FPU in makefile. | Martin Galvan | 2015-03-27 | 1 | -1/+1 |
* | libcsupport: Include missing header file | Sebastian Huber | 2015-03-26 | 1 | -0/+1 |
* | sparc: Ensure interrupt service after ISR enable | Sebastian Huber | 2015-03-25 | 1 | -1/+8 |
* | testsupport: Generate unique worker names | Sebastian Huber | 2015-03-25 | 1 | -1/+11 |
* | bsp/altera-cyclone-v: Typo | Sebastian Huber | 2015-03-25 | 1 | -3/+3 |
* | smpmigration01: Delete timing dependent assert | Sebastian Huber | 2015-03-25 | 1 | -3/+6 |
| | | | | | | The cycles per runner depends too heavily on the hardware timing making the assert unreliable. Delete runner tasks before we print out the status. | ||||
* | smptests/smpfatal08: Workaround for QorIQ BSPs | Sebastian Huber | 2015-03-24 | 1 | -0/+8 |
* | monitor: Fix notepad dump | Sebastian Huber | 2015-03-24 | 1 | -4/+7 |
* | score: Fix MrsP ISR/task sychronization | Sebastian Huber | 2015-03-24 | 1 | -9/+12 |
* | score: Add scheduler acquire/release | Sebastian Huber | 2015-03-24 | 9 | -32/+67 |
| | | | | | | | This is currently a global lock for all scheduler instances. It should get replaced with one lock per scheduler instance in the future. Update #2273. | ||||
* | score: Use a dedicated ISR lock for thread queues | Sebastian Huber | 2015-03-24 | 1 | -20/+34 |
| | | | | | | | | This makes it possible to use the standard thread queues in combination with objects using fine grained locking. There is no change for uni-processor configurations. Update #2273. | ||||
* | score: Add thread lock | Sebastian Huber | 2015-03-24 | 5 | -6/+209 |
* | score: Add thread priority change handler | Sebastian Huber | 2015-03-24 | 7 | -71/+133 |
| | | | | | | | | | | Since the thread current priority change and thread queue requeue is performed in one critical section it is possible to simplify the thread queue requeue procedure. Add a thread queue agnostic thread priority change handler so that we are able to use alternative thread queue implementations. Update #2273. | ||||
* | cpukit/libmisc/utf8proc/utf8proc.c: Avoid overflow | Joel Sherrill | 2015-03-24 | 1 | -0/+5 |
* | libdl/rtl-shell.c: Adjust printf() format for off_t based on target | Joel Sherrill | 2015-03-24 | 1 | -6/+8 |
* | testsuites/sptests/sp54/init.c: Add cast to avoid warning | Joel Sherrill | 2015-03-24 | 1 | -1/+1 |
* | samples/minimum/init.c: Add cast to avoid warning | Joel Sherrill | 2015-03-24 | 1 | -1/+1 |
* | libdl/rtl-mdreloc-moxie.c: Fix printf() format warnings | Joel Sherrill | 2015-03-24 | 2 | -5/+5 |
* | moxie machine type not supported by rtems-syms. See #2213 | Joel Sherrill | 2015-03-24 | 1 | -0/+1 |
| | | | | updates #2313. | ||||
* | tools/cpu/nios2/ptf.c: Add include of <ctype.h> | Joel Sherrill | 2015-03-24 | 1 | -0/+1 |
* | mrm332/console/sci.c: Make routines static | Joel Sherrill | 2015-03-24 | 1 | -4/+4 |
* | nds/libnds/source/arm9/image.c: Add needed cast | Joel Sherrill | 2015-03-24 | 1 | -1/+1 |
* | nds/libnds/source/arm7/clock.c: Avoid over indexing array | Joel Sherrill | 2015-03-24 | 1 | -1/+1 |
* | lpc176x/console/console-config.c: Conditionalize code to avoid unused warnings | Joel Sherrill | 2015-03-24 | 1 | -0/+4 |
* | tools/build/binpatch.c: Include <unistd.h> for getopt() | Joel Sherrill | 2015-03-24 | 1 | -0/+1 |
* | sptls03/init.c: Make type and constants uint32_t to avoid overflow warnings | Joel Sherrill | 2015-03-24 | 1 | -4/+4 |
* | sptls01/init.c: Use larger data types for values | Joel Sherrill | 2015-03-24 | 1 | -5/+5 |
* | rtems/score/tls.h: Add casts to eliminate warnings on some targets | Joel Sherrill | 2015-03-24 | 1 | -3/+9 |
* | sptests/spwatchdog/init.c: Avoid integer overflow | Joel Sherrill | 2015-03-24 | 1 | -2/+8 |
* | sptests/spedfsched02: Reduce stack space usage to fix on smaller targets | Joel Sherrill | 2015-03-24 | 2 | -3/+1 |
* | sptests/spatomic01/init.c: Avoid integer overflow | Joel Sherrill | 2015-03-24 | 1 | -8/+11 |
* | sptests/sp34/changepri.c: Correct printf() warning | Joel Sherrill | 2015-03-24 | 1 | -4/+5 |
* | sptests/sp33/init.c: Correct printf() warning | Joel Sherrill | 2015-03-24 | 1 | -2/+3 |
* | sptests/sp20: Reduce memory requirements | Joel Sherrill | 2015-03-24 | 2 | -3/+1 |
| | | | | | This was checked on sparc/sis. If this fails on other targets, then the task stack sizes needs to be reevaluated. | ||||
* | sptests/sp13/system.h: Fine tune message buffer configuration to avoid ↵ | Joel Sherrill | 2015-03-24 | 1 | -13/+17 |
| | | | | integer overflow | ||||
* | sptests/sp12/pritask.c: Correct printf() warning | Joel Sherrill | 2015-03-24 | 1 | -3/+4 |
* | psxconfig01/init.c: Correct pointer/integer size warning | Joel Sherrill | 2015-03-24 | 1 | -1/+1 |
* | psxtests/psx15/init.c: Correct printf() warning | Joel Sherrill | 2015-03-24 | 1 | -1/+3 |
