* aclocal/enable-multiprocessing.m4: enable_multiprocessing=no.
* aclocal/prog-cc.m4: Remove obsolete comments.
Comment out GCCSED.
* aclocal/check-multiprocessing.m4: Reworked.
* aclocal/enable-multiprocessing.m4: Remove RTEMS_HAS_MULTIPROCESSING.
* automake/multilib.am: Remove.
* Makefile.am: Reflect change above.
* Makefile.am: Pickup libbsp.a from build directory.
* intr_NOTIMES.t: Per PR70 incorporate the posting by
Zoltan Kocsi <zoltan@bendor.com.au> explaining a m68k vectoring trick.
* aclocal/version.m4: Updated to rtems-ss-20020628.
* tverstions.texi: Updated to reflect newer versions.
* buildc.t, gdb.t: Per PR54, updated to reflect multiple compression
schemes including bzip2.
* preface.texi, procenv.t, process.t, signal.t, stamp-vti,
version.texi: Updated as part of starting a sweep on the POSIX
User's Guide.
* src/__times.c: Cleaned up comments, return more information,
and eliminated the fatal error on clock not set since it cannot
occur.
* userext.t: Per PR228, correct the prototype of the task create
user extension to indicate it returns a boolean and augment the
documentation to explain the purpose of the boolean return value.
* Addition of a ftp client filesystem, comparable to the tftp one.
* lib/ftpfs.c, rtems/ftpfs.h: New files.
* lib/Makefile.am, rtems/Makefile.am: Modified to reflect above.
* Makefile.am: genoffsets must be built before the executive.
* tools/Makefile.am: Build the cpu dependent tools as well.
* With the addition of serdbg, the standard polled I/O functions
for gdbstub and/or printk are optionally routed to any termios-aware
device driver, that supports polled mode. See libmisc/serdbg/README.
* serdbg/Makefile.am, serdbg/README, serdbg/serdbg.c, serdbg/serdbg.h,
serdbg/serdbgcnf.h, serdbg/serdbgio.c, serdbg/termios_printk.c,
serdbg/termios_printk.h, serdbg/termios_printk_cnf.h,
serdbg/.cvsignore: New files.
* configure.ac, Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
* Makefile.am, bsp_specs: Now this target almost compiles again.
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue thus adding a directory at the
top shared level.
* shared/gdbstub: New directory.
* configure.ac: Modified to reflect above.
* Makefile.am, cpu.c, cpu_asm.S, rtems.S: Modified to make
this all compile again. It has been a while since we have
had a semi-working hppa1.1-rtems cross compiler. :)
support to the shared gdb stub glue thus moving some of the
gdbstub support to a higher level.
* startup/Makefile.am: Modified to reflect above.
support to the shared gdb stub glue necessitating a move up.
* Makefile.am: Reflect new gdbstub directory.
* ChangeLog, Makefile.am, .cvsignore: New file.
* rtems-stub-glue.c: Moved from mips/shared/gdbstub and
m68k/shared/gdbstub.
support to the shared gdb stub glue thus adding a directory.
* startup/Makefile.am: Compile the m68k gdb stub and glue.
* gdbstub: New directory.
* Makefile.am: Modified to reflect above.
* Added m68k serial stub that is thread aware.
* ChangeLog, gdb_if.h, m68k-stub.c, Makefile.am: New files.
* configure.ac: Add RTEMS_PROG_CCAS
* aclocal/prog-ccas.m4: New.
* aclocal/canonicalize-tools.m4: Remove AS, OBJCOPY, NM, SIZE, STRIP.
RTEMS_GCC_PRINT
* aclocal/check-multiprocessing.m4: Fix typo.
* automake/compile.am: Remove CXX support.
Replace AS by CCAS. Remove LINK_LIBS, LINK_OBJS, LINK_FILES.
RTEMS_GCC_PRINT
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* configure.ac: Use AC_CONFIG_AUX_DIR(..).
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..).
Add AC_PROG_RANLIB.
* autotools/automake-rtems.spec.in: Update to automake-1.6.2.
* wrapup/Makefile.am: Build libnetapps.a.
Don't preinstall libnetapps.a
* Makefile.am: Pickup libnetapps.a from build directory.
* wrapup/Makefile.am: Don't preinstall libmisc.a.
* Makefile.am: Pickup libmisc.a from build directory.
Remove libxdr.a.
* ChangeLog: Fix bogus changelog entries.
* wrapup/Makefile.am: Don't preinstall libnetworking.a.
* wrapup/Makefile.am: Don't preinstall libfs.a.
* src/Makefile.am: Don't preinstall libblock.a.
* configure.ac: Remove references to RTEMS_BSP.
* src/Makefile.am: Add libposix.a.
* src/Makefile.am: Add libitron.a.
* aclocal/check-multiprocessing.m4: Remove references to RTEMS_BSP.
Allow building w/ --enable-multiprocessing --enable-multilib.
Eliminate RTEMS_HAS_MULTIPROCESSING.
* wrapup/Makefile.am: Remove libxdr.a.
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Fix stupid typo in previous patch.
* configure.ac: Add librpc. AC_PROG_RANLIB.
* wrapup/Makefile.am: Add librpc.
Use relative path to lib*.a for
POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS.
* configure.ac: Remove librpc.
