* | Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to | Joel Sherrill | 1999-10-15 | 7 | -0/+399 |
| | | | | help build RPMs. | ||||
* | Reorganized a lot per Jennifer's suggestions. | Joel Sherrill | 1999-10-13 | 4 | -120/+120 |
* | Updated copyright date. | Joel Sherrill | 1999-10-13 | 6 | -5/+7 |
* | More manuals and a little reorganization. | Joel Sherrill | 1999-10-13 | 1 | -5/+25 |
* | First commit of miscellaneous tools and documentation for a procedure | Joel Sherrill | 1999-10-13 | 8 | -0/+343 |
| | | | | that can be used to produce an online bookshelf of the GNU tools. | ||||
* | Made many changes to turn the outline into something more like a manual | Joel Sherrill | 1999-10-12 | 9 | -448/+1854 |
| | | | | and less like a collection of notes. | ||||
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -35/+0 |
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -324/+0 |
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -339/+0 |
* | New file. | Joel Sherrill | 1999-10-12 | 1 | -0/+34 |
* | Spacing. | Joel Sherrill | 1999-10-12 | 4 | -0/+4 |
* | Split null handlers table to own file and renamed. | Joel Sherrill | 1999-10-12 | 26 | -238/+60 |
| | | | | Renamed IMFS handler tables to include IMFS prefix. | ||||
* | Added rtems_filesystem_freenode() macro and added calls at appropriate | Joel Sherrill | 1999-10-12 | 52 | -280/+209 |
| | | | | | places to make sure memory allocated for filesystem specifif nodes gets freed. | ||||
* | Fixed spacing. | Joel Sherrill | 1999-10-12 | 4 | -4/+4 |
* | Corrected mistakes in the IMFS file handlers table and added the missing | Joel Sherrill | 1999-10-12 | 13 | -31/+428 |
| | | | | routine imfs_fcntl.c | ||||
* | Added call to freenod to let each filesystem free its own internal | Joel Sherrill | 1999-10-12 | 46 | -208/+697 |
| | | | | node used to manage file access. | ||||
* | Changed bcopy to strncpy to stick to ANSI/ISO routines. | Joel Sherrill | 1999-10-12 | 3 | -3/+3 |
* | Fixed random cut and paste problem. | Joel Sherrill | 1999-10-11 | 1 | -23/+23 |
* | Added files generated by index process to clean stanza. | Joel Sherrill | 1999-10-11 | 3 | -1/+5 |
* | Changed link for bad PDF files to BAD.html. | Joel Sherrill | 1999-10-11 | 1 | -2/+2 |
* | Changed version information. | Joel Sherrill | 1999-10-11 | 2 | -2/+2 |
* | Changed release information. | Joel Sherrill | 1999-10-11 | 1 | -5/+5 |
* | New files. | Joel Sherrill | 1999-10-11 | 4 | -0/+0 |
* | New file. | Joel Sherrill | 1999-10-11 | 1 | -0/+22 |
* | Corrected spacing. | Joel Sherrill | 1999-10-11 | 1 | -1/+0 |
* | Added support for @appendix and @preface. | Joel Sherrill | 1999-10-11 | 1 | -0/+12 |
* | Corrected bullet with @bullet. | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
* | Generated concept and function index entries. | Joel Sherrill | 1999-10-11 | 19 | -1171/+2626 |
* | Added descriptions. | Joel Sherrill | 1999-10-11 | 2 | -61/+88 |
* | Updated to incldue descriptions and reformatted to wrap lines better. | Joel Sherrill | 1999-10-11 | 1 | -93/+396 |
* | Added descriptions of routines to section headings. | Joel Sherrill | 1999-10-11 | 3 | -80/+80 |
* | Added descriptions. | Joel Sherrill | 1999-10-11 | 3 | -38/+66 |
* | More cleanup. | Joel Sherrill | 1999-10-11 | 8 | -63/+65 |
* | Enabled index generation. | Joel Sherrill | 1999-10-11 | 1 | -4/+4 |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 24 | -107/+117 |
* | Added filesystem design guide and scaling directives for the images. | Joel Sherrill | 1999-10-11 | 1 | -72/+144 |
* | Added filesystem design guide. | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
* | Install all of the gif's in the common directory. | Joel Sherrill | 1999-10-11 | 1 | -0/+1 |
* | Changed install point and cleaned up. | Joel Sherrill | 1999-10-11 | 1 | -11/+2 |
* | Now build. | Joel Sherrill | 1999-10-11 | 3 | -175/+489 |
* | Added enough to let script find that this does not have descriptions. | Joel Sherrill | 1999-10-11 | 1 | -10/+10 |
* | changed version to 19991011 | Joel Sherrill | 1999-10-11 | 0 | -0/+0 |
* | Make sure directories are made before installing and install html, | Joel Sherrill | 1999-10-11 | 1 | -3/+4 |
| | | | | pdf, ps, and dvi into the html directory so they all can be browsed. | ||||
* | changed version to 19991011 | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
* | Turned on concept and function name indexing. | Joel Sherrill | 1999-10-11 | 23 | -154/+771 |
* | Fixed variable reference for RTEMS-RELEASE. | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
* | Moved RTEMS error and association from libmisc to libc support to | Joel Sherrill | 1999-10-11 | 8 | -14/+14 |
| | | | | | avoid cyclic dependencies generated when moving packages to the top level. | ||||
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-11 | 14 | -1428/+0 |
| | | | | | | | | | | | | | | and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-10-11 | 6 | -34/+18 |
| | | | | | | | | Removed all go32 configuration tests. This patch also comments out some special treatment for Cygwin from *.m4 macros. According to reports from David Fiddes. these should not be necessary anymore. | ||||
* | Added as part of moving librdbg to its own top level package. This was | Joel Sherrill | 1999-10-11 | 6 | -0/+141 |
| | | | | done as part of a patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. |
