* | | Convert to DOS format. | Chris Johns | 2006-08-04 | 2 | -19/+19 | |
* | | Bump version. | Ralf Corsepius | 2006-08-03 | 1 | -1/+1 | |
* | | Use hard-coded %release. | Ralf Corsepius | 2006-08-03 | 1 | -2/+2 | |
* | | Use hard-coded %release. | Ralf Corsepius | 2006-08-03 | 11 | -30/+30 | |
* | | Remove (Obsolete) | Ralf Corsepius | 2006-08-03 | 1 | -50/+0 | |
* | | Remove | Ralf Corsepius | 2006-08-03 | 1 | -822/+0 | |
* | | Update to using newlib-1.14.0-rtems-20060707.diff | Ralf Corsepius | 2006-08-03 | 6 | -6/+6 | |
* | | Bump version. | Ralf Corsepius | 2006-08-02 | 1 | -1/+1 | |
* | | Use further shared spec-fragments. | Ralf Corsepius | 2006-08-02 | 2 | -0/+6 | |
* | | Split out target-autoconf.add | Ralf Corsepius | 2006-08-02 | 1 | -31/+2 | |
* | | Split out target-automake.add | Ralf Corsepius | 2006-08-02 | 1 | -30/+0 | |
* | | New. | Ralf Corsepius | 2006-08-02 | 2 | -0/+47 | |
* | | Add bsp_setbenv system call. | Eric Norum | 2006-08-01 | 2 | -1/+6 | |
* | | Add objc | Ralf Corsepius | 2006-07-25 | 2 | -2/+2 | |
* | | Remove sed -e /[@]tool_target[@]-newlib/d" | Ralf Corsepius | 2006-07-25 | 1 | -1/+0 | |
* | | Remove blank lines. | Ralf Corsepius | 2006-07-25 | 1 | -5/+5 | |
* | | More %if %build_newlib blocks. | Ralf Corsepius | 2006-07-25 | 2 | -0/+4 | |
* | | New. | Ralf Corsepius | 2006-07-25 | 1 | -0/+60 | |
* | | Fix rpmgroup. | Ralf Corsepius | 2006-07-25 | 2 | -26/+22 | |
| | | | | | | | | Cosmetics. | |||||
* | | Upgrade to gcc-3.4.4-2, cygwin-1.5.21-1 | Ralf Corsepius | 2006-07-25 | 1 | -2/+2 | |
* | | Bump version. | Ralf Corsepius | 2006-07-24 | 1 | -1/+3 | |
| | | | | | | | | Add AC_CONFIG_FILES([autotools/Makefile]) | |||||
* | | Add autotools. | Ralf Corsepius | 2006-07-24 | 1 | -0/+2 | |
* | | Add provisory/preliminary autotools support. | Ralf Corsepius | 2006-07-24 | 1 | -0/+2 | |
* | | Cleanup. | Ralf Corsepius | 2006-07-24 | 1 | -6/+3 | |
| | | | | | | | | Add note on autotools. | |||||
* | | New. | Ralf Corsepius | 2006-07-24 | 6 | -0/+235 | |
* | | Add Chris and Joel. | Ralf Corsepius | 2006-07-24 | 1 | -0/+8 | |
* | | 2006-07-23 Rename "*-base-*" packages into <tool>-common. | Ralf Corsepius | 2006-07-24 | 1 | -0/+5 | |
| | | | | | | | | | | | | Rename GCC's "*-<lang>" packages into "*-gcc-<lang>". Many small directory ownership fixes. Build all GCC packages with --enable-threads. | |||||
* | | Bump version | Ralf Corsepius | 2006-07-23 | 1 | -1/+1 | |
* | | Minor fixes. | Ralf Corsepius | 2006-07-23 | 1 | -2/+2 | |
* | | Let rpm Obsolete < %{binutils_version}-%{release} | Ralf Corsepius | 2006-07-23 | 1 | -2/+2 | |
* | | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 2 | -4/+8 | |
* | | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -9/+10 | |
| | | | | | | | | Rename *gfortran into *gcc-gfortran | |||||
* | | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -8/+9 | |
| | | | | | | | | Rename *g77 into *gcc-g77 | |||||
* | | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -4/+7 | |
| | | | | | | | | Rename *objc into *gcc-objc | |||||
* | | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -1/+2 | |
| | | | | | | | | Rename *gcj into *gcc-gcj | |||||
* | | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -4/+5 | |
| | | | | | | | | Rename *gnat into *gcc-gnat | |||||
* | | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -5/+8 | |
| | | | | | | | | Rename *c++ into *gcc-c++ | |||||
* | | Rename *base packages into gcc*-common | Ralf Corsepius | 2006-07-23 | 6 | -35/+69 | |
* | | Let rpm Obsolete < %{gdb_version}-%{release} | Ralf Corsepius | 2006-07-23 | 1 | -2/+2 | |
* | | Add --enable-threads. | Ralf Corsepius | 2006-07-23 | 1 | -0/+1 | |
* | | Elminate blank lines. | Ralf Corsepius | 2006-07-23 | 6 | -24/+24 | |
* | | Changes to the installer and an extra script to build all. | Chris Johns | 2006-07-22 | 3 | -0/+614 | |
* | | Eliminate white spaces. | Ralf Corsepius | 2006-07-22 | 10 | -50/+50 | |
* | | Rename rtems4.7-base-gdb into gdb-common | Ralf Corsepius | 2006-07-22 | 3 | -11/+14 | |
* | | Rename rtems4.7-base-binutils into binutils-common | Ralf Corsepius | 2006-07-21 | 3 | -7/+13 | |
* | | Remove --sources (Unused) | Ralf Corsepius | 2006-07-21 | 1 | -10/+0 | |
* | | Add %{gcclib}/@tool_target@/%{gcc_version}/include/ssp | Ralf Corsepius | 2006-07-21 | 1 | -0/+3 | |
* | | Make install-patches more verbose. | Ralf Corsepius | 2006-07-21 | 1 | -1/+2 | |
* | | Add install-patches. | Ralf Corsepius | 2006-07-21 | 1 | -0/+6 | |
* | | Add objc. | Ralf Corsepius | 2006-07-21 | 1 | -1/+1 | |
