* compilers/gcc-no_bsp.cfg, compilers/gcc-target-default.cfg,
custom/bare.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg,
custom/default.cfg, custom/haleakala.cfg, custom/mbx8xx.cfg,
custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg,
custom/posix.cfg, custom/ss555.cfg, custom/virtex.cfg: Eliminate
START_BASE and START_FILE.
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Eliminate definitions of BSP_LIBIO_MAX_FDS since this
is NOT used anywhere.
PR 1314/bsps
* custom/mvme3100.cfg: Remove old stuff.
* user/conf.t: Add CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM and
CONFIGURE_APPLICATION_DISABLE_FILESYSTEM.
* libfs/src/devfs/devclose.c, libfs/src/devfs/devfs_eval.c,
libfs/src/devfs/devioctl.c, libfs/src/devfs/devopen.c,
libfs/src/devfs/devread.c, libfs/src/devfs/devwrite.c: Fix warnings.
* Doxyfile.in, rtems/mainpage.h, score/include/rtems/system.h: Move to
generating Doxygen for more of CPU Kit.
* rtems/Doxyfile, score/Doxyfile, score/mainpage.h: Removed.
* configure.ac: Add generated Doxyfile which can process entire set of
preinstalled .h files.
* Doxyfile.in: New file.
* include/timesys.h: Rename STACK_CHECKER_ON to more appropriate
CONFIGURE_STACK_CHECKER_ENABLED.
* fileio/system.h: Rename STACK_CHECKER_ON to more appropriate
* stackchk/system.h: Rename STACK_CHECKER_ON to more appropriate
* compilers/gcc-no_bsp.cfg: Eliminate some obsolete junk.
* sapi/include/confdefs.h: Rename STACK_CHECKER_ON to more appropriate
* shell/rtems.t, user/conf.t, user/stackchk.t: Rename STACK_CHECKER_ON
to more appropriate CONFIGURE_STACK_CHECKER_ENABLED.
* startup/linkcmds: Add start symbol to eliminate warning.
* libfs/src/devfs/devclose.c, libfs/src/devfs/devfs_init.c,
libfs/src/devfs/devfs_show.c, libfs/src/devfs/devioctl.c,
libfs/src/devfs/devopen.c, libfs/src/devfs/devread.c,
* user/conf.t: Fix typo.
* minimum/init.c, unlimited/system.h: Add support for optionally having
a unified work area. In other words, the RTEMS Workspace and C
Program Heap are the same pool of memory.
* preinstall.am: Regenerated.
* bootcard.c: Add support for optionally having a unified work area. In
other words, the RTEMS Workspace and C Program Heap are the same pool
of memory.
* libcsupport/src/free.c, libcsupport/src/malloc.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h,
libcsupport/src/malloc_sbrk_helpers.c,
libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/mallocfreespace.c,
libcsupport/src/mallocinfo.c, libcsupport/src/realloc.c,
libcsupport/src/rtems_memalign.c, sapi/include/confdefs.h,
score/inline/rtems/score/thread.inl: Add support for optionally
having a unified work area. In other words, the RTEMS Workspace and C
* user/conf.t: Add support for optionally having a unified work area.
In other words, the RTEMS Workspace and C Program Heap are the same
pool of memory.
* startup/linkcmds: Work Area should start on 16 byte boundary.
* optman/Makefile.am, optman/preinstall.am: Merge GSOC project code to
add simple device only filesystem (devfs), optionally completely drop
out filesystem, and to clean up disabling newlib reentrancy support.
This dropped 17K from the minimum.exe for sparc/sis and arm/rtl22xx_t
now has a 15K code space.
* optman/no-console.c, optman/no-filesystem.c, optman/no-libio.c:
Removed.
* bsplibc.c, bsppost.c: Merge GSOC project code to add simple device
only filesystem (devfs), optionally completely drop out filesystem,
and to clean up disabling newlib reentrancy support. This dropped 17K
from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K
code space.
* startup/bspstart.c: Merge GSOC project code to add simple device only
filesystem (devfs), optionally completely drop out filesystem, and to
clean up disabling newlib reentrancy support. This dropped 17K from
the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K code
space.
* Makefile.am, preinstall.am, libcsupport/Makefile.am,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio.h, libcsupport/src/base_fs.c,
libcsupport/src/libio_init.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/newlibc_init.c, libcsupport/src/sync.c,
libfs/Makefile.am, libfs/src/imfs/deviceio.c,
sapi/include/confdefs.h: Merge GSOC project code to add simple device
code space.
* libcsupport/src/__usrenv.c, libcsupport/src/newlibc_reent.c,
libfs/src/devfs/devclose.c, libfs/src/devfs/devfs.h,
libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devfs_init.c,
libfs/src/devfs/devfs_mknod.c, libfs/src/devfs/devfs_node_type.c,
libfs/src/devfs/devstat.c, libfs/src/devfs/devwrite.c,
libfs/src/imfs/deviceerrno.c: New files.
* libcsupport/src/newlibc.c: Removed.
* hello/system.h, minimum/Makefile.am, minimum/init.c: Merge GSOC
project code to add simple device only filesystem (devfs), optionally
completely drop out filesystem, and to clean up disabling newlib
reentrancy support. This dropped 17K from the minimum.exe for
sparc/sis and arm/rtl22xx_t now has a 15K code space.
* sapi/include/confdefs.h: Revert previous patch. Does not apply to
head.
* bspgetworkarea.c: New file. This implementation should be useable
by most BSPs if they provide the proper support in their linker script.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* shared/m68kbspgetworkarea.c: Removed.
* Makefile.am, startup/bspstart.c, startup/linkcmds: Use top level
shared bsp_get_work_area() implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds_ROM: Use top level
* Makefile.am, startup/linkcmds, startup/linkcmdsflash: Use top level
* Makefile.am, startup/linkcmds, startup/linkcmdsflash,
startup/linkcmdsram: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, start/start.S, startup/linkcmds: Use top level shared
* Makefile.am, startup/linkcmds, startup/linkcmds.flash: Use top level
* Makefile.am, startup/bspstart.c, startup/init548x.c,
startup/linkcmds, startup/linkcmds.m5484FireEngine.flash: Use top
level shared bsp_get_work_area() implementation.
* Makefile.am, include/bsp.h, startup/init68360.c, startup/linkcmds,
startup/linkcmds.bootp, startup/linkcmds.prom: Use top level shared
* startup/bspgetworkarea.c, startup/linkcmds.base: Do some prep work in
anticipation of gen5200 and gen83xx being able to shared
