* gnatsupp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* erc32sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdbsci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
* trap34/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hw_init/Makefile.am: Remove AUTOMAKE_OPTIONS.
* bootloader/Makefile.am: Remove AUTOMAKE_OPTIONS.
* motorola/Makefile.am: Remove AUTOMAKE_OPTIONS.
* openpic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* residual/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PCI_bus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nvram/Makefile.am: Remove AUTOMAKE_OPTIONS.
* universe/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dlentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* flashentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* canbus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scv64/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* liblnk/Makefile.am: Remove AUTOMAKE_OPTIONS.
* fatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
* consolex/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spurious/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i2c/Makefile.am: Remove AUTOMAKE_OPTIONS.
* debug_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* debug_c/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dos_sup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/adasockets/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/listener/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/tcprelay/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ts_1325_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* comm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* io/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 3c509/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ne2000/Makefile.am: Remove AUTOMAKE_OPTIONS.
* wd8003/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tty/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR161
* rtmon.t: Add rtems_ prefix to directives in the example.
* PR144
* nfs/bootp_subr.c bootpc_init(): Performs a write to memory address
0 when called for the first time. This is done when trying to clear
the variable "dhcp_hostname".
* io.t, conf.t: PR 160. Added the IO Manager's register and
unregister interface documentation.
* PR162
* net/if_ppp.c ppp_txdaemon(), net/if_pppvar.h pppstart(): Local
variables must not be used in a device write routines. Now
ppp_softc structure have own character for writing to device
(sc_outchar). I think that converting local variables to static
is not a right solution, because problems will occur in the case
of two or more ppp instances.
* net/ppp_tty.c pppstart(): Type of the ioffset variable must be
u_long, otherwise in the case of the big output packet endless
loop may occur.
* ChangeLog: Undo incorrect addition of entry.
* net/if_ppp.c, net/ppp_tty.c: Initial preparations for multiple
PPPD connections.
* src/bdbuf.c (avl_insert, avl_remove): Reimplemented from scratch
to avoid using GPLed sources in RTEMS core.
* src/bdbuf.c, include/rtems/bdbuf.h: Remove "binary tree"
implementation which was used for debugging only.
* PR158
* libc/rcmd.c, libc/rcmd.c: Enable the rcmd() library call by
commenting out the parts that deal with signals. This enables
RTEMS to 'rsh' command to a server connecting fd to remote stdio.
The 'server-side' parts of this file which deal with authentication
are disabled since they are not needed.
* PR137
* buildc.t: Now provides more explicit requirements on $PATH
after building binutils.
* cpu_asm.S: Now compiles on 4600 and 4650.
* PR143
* lib/include/rtems/termiostypes.h: Removed unneeded volatile on
"theBuf" since no byte is read more than once anyway.
* PR145.
* sp04/task1.c, sp04/tswitch.c: Test fails if other tasks present
in system (e.g. driver tasks). Also exit on minimum number of
switches not precise number.
* PR148.
* monitor/mon-prmisc.c: Fixed to print task states correctly.
