* | added "ifndef" to avoid redefinition warning. | Joel Sherrill | 1997-04-07 | 6 | -0/+12 |
* | added volatile to Switch_necessary structure member to avoid warning. | Joel Sherrill | 1997-04-07 | 1 | -2/+2 |
* | added test to avoid spurious error | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added prototype for missing routine. | Joel Sherrill | 1997-04-07 | 1 | -0/+4 |
* | added "return" to eliminate warning. | Joel Sherrill | 1997-04-07 | 2 | -0/+4 |
* | added "ifndef" to avoid redefinition warning | Joel Sherrill | 1997-04-07 | 13 | -0/+26 |
* | added prototypes for two assembly language routines to eliminate warnings. | Joel Sherrill | 1997-04-07 | 1 | -0/+9 |
* | commented out sccs_id to eliminate warning. | Joel Sherrill | 1997-04-07 | 6 | -18/+38 |
* | added plea for someone to implement software stack switching for m68000-ish | Joel Sherrill | 1997-04-07 | 1 | -0/+3 |
| | | | | cores. | ||||
* | Replaced warning message for cpus which do not have hardware support | Joel Sherrill | 1997-04-07 | 2 | -4/+6 |
| | | | | | for an interrupt stack. Hopefully this will encourage someone to implement software stack switching on the m68k. | ||||
* | initialized variable to eliminate warning | Joel Sherrill | 1997-04-07 | 1 | -1/+3 |
* | changed signed int to unsigned to eliminate warning | Joel Sherrill | 1997-04-07 | 2 | -2/+2 |
* | added "ifndef" for ASM to avoid redefinition warnings. | Joel Sherrill | 1997-04-07 | 2 | -0/+4 |
* | updated to put bsps in alphabetical order | Joel Sherrill | 1997-04-07 | 2 | -6/+16 |
* | corrected one of the references to an environment variable which | Joel Sherrill | 1997-04-02 | 1 | -1/+1 |
| | | | | is no longer used since autoconf is in place. | ||||
* | corrected printf format to avoid warning | Joel Sherrill | 1997-04-02 | 14 | -22/+22 |
* | initialized variables or removed unused variables to remove warnings | Joel Sherrill | 1997-04-02 | 6 | -8/+6 |
* | disabled posix api for the no_cpu-rtems configuration in configure.in | Joel Sherrill | 1997-04-02 | 2 | -2/+4 |
| | | | | and regenerated configure. | ||||
* | added Jiri for autoconf'ing | Joel Sherrill | 1997-04-02 | 1 | -0/+3 |
* | was checking for null cpu_table -- short have been checking configuration | Joel Sherrill | 1997-04-02 | 2 | -2/+2 |
| | | | | table. | ||||
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 461 | -241/+27181 |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | ||||
* | Fixed symbols. | Joel Sherrill | 1997-03-21 | 1 | -2/+6 |
* | added decrementer entry. | Joel Sherrill | 1997-03-21 | 1 | -0/+17 |
* | Removed Fake input ifdef code. | Joel Sherrill | 1997-03-21 | 1 | -15/+0 |
* | Fixed timerisr symbol. | Joel Sherrill | 1997-03-21 | 1 | -2/+2 |
* | Rewrote to avoid references to C symbols from assembly. This entirely | Joel Sherrill | 1997-03-21 | 1 | -5/+9 |
| | | | | circumvents the problem of leading underscores. | ||||
* | Fixes incorrect reference to start symbol. | Joel Sherrill | 1997-03-21 | 1 | -1/+1 |
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 2 | -0/+358 |
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 21 | -92/+778 |
* | modified _Chain_Insert_unprotected to have the form required to be used | Joel Sherrill | 1997-03-11 | 3 | -6/+6 |
| | | | | as the sole statement in an if or else statement | ||||
* | swapped increment of _ISR_Nest_level and _Thread_Dispatch_disable_level | Joel Sherrill | 1997-03-11 | 1 | -1/+1 |
* | added include of rtems.h so the proper macro definitions would be present. | Joel Sherrill | 1997-03-10 | 3 | -0/+6 |
* | made some of this conditional on unix lib | Joel Sherrill | 1997-03-10 | 1 | -2/+5 |
* | initialized a stack variable to avoid a warning. | Joel Sherrill | 1997-03-10 | 2 | -2/+2 |
* | created. Split getpid() from types.c to allow it to be overridden by | Joel Sherrill | 1997-03-10 | 2 | -0/+44 |
| | | | | | cxe1001 of the ACVC 2.0.1. This allows gnat/rtems to pass the partition tests. | ||||
* | Fixed bug where the initial detachstate was not being set properly | Joel Sherrill | 1997-03-10 | 2 | -2/+2 |
* | updated version to 4.0.0 | Joel Sherrill | 1997-03-08 | 2 | -2/+2 |
* | added support for posix tests | Joel Sherrill | 1997-03-08 | 1 | -1/+3 |
* | Larger Workspace when it is a POSIX API. Actually this is just to cover | Joel Sherrill | 1997-03-08 | 1 | -0/+4 |
| | | | | | the extra stack used when GNAT tasks are in the system. This needs to be cleaned up. | ||||
* | Modified calls to _Thread_Change_priority to take a third argument. The new | Joel Sherrill | 1997-03-08 | 9 | -29/+98 |
| | | | | | | | | | argument indicates whether the task is to be placed at the head or tail of its priority fifo when it is lowering its own priority. POSIX normally follows the RTEMS API conventions but GNAT expects that all lowering of a task's priority by the task itself will result in being placed at the head of the priority FIFO. Normally, this would only occur as the result of lose of inherited priority. | ||||
* | Modified calls to _Thread_Change_priority to take a third argument. The new | Joel Sherrill | 1997-03-08 | 2 | -2/+2 |
| | | | | | | | | | | | | argument indicates whether the task is to be placed at the head or tail of its priority fifo when it is lowering its own priority. POSIX normally follows the RTEMS API conventions but GNAT expects that all lowering of a task's priority by the task itself will result in being placed at the head of the priority FIFO. Normally, this would only occur as the result of lose of inherited priority. The RTEMS API always puts tasks at the end of their priority group except upon loss of inherited priority. | ||||
* | Removed getpid from this file and made it its own file. This lets it | Joel Sherrill | 1997-03-08 | 2 | -20/+0 |
| | | | | get replaced as required. | ||||
* | Added commit to indicate exepcted _Thread_Dispatch_disable_level. Hopefully | Joel Sherrill | 1997-03-08 | 2 | -0/+8 |
| | | | | no one will ever get confused here again and try to enable dispatching. :( | ||||
* | Modifications to make go32 build using new i386-go32-rtems toolset | Joel Sherrill | 1997-01-29 | 6 | -12/+21 |
| | | | | and gcc 2.8.x -specs options. | ||||
* | new file explaining issues related to this bsp. | Joel Sherrill | 1997-01-29 | 1 | -0/+38 |
* | Fixed this where it works. It includes the libpc.a and libc.a from | Joel Sherrill | 1997-01-29 | 1 | -6/+6 |
| | | | | djgpp v1.x. | ||||
* | erc32 bsp supercedes sis | Joel Sherrill | 1997-01-29 | 8 | -0/+1476 |
* | Made stopping for the pause an option which can be configured in the | Joel Sherrill | 1997-01-29 | 2 | -0/+24 |
| | | | | targopts.h file. | ||||
* | Minor change to eliminate incorrect use of unaligned register. | Joel Sherrill | 1997-01-29 | 1 | -1/+2 |
* | Merged newlib's libgloss support for rtems into this directory. This | Joel Sherrill | 1997-01-29 | 15 | -106/+254 |
| | | | | should simplify the build process. |
